Old 11-30-2015, 10:35 AM   #43
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Originally Posted by graysailor View Post
Great. Another project. How can you tell if you have the two piece nuts.
I wasn't able to find any pictures so I'll try to describe the difference.
Two-piece refers to the fact that the steel nut (the part with the threads and the tapered section that mates to the wheel) is wrapped inside a chrome outer shell. The problem with this design is the fact that the chrome outer shell comes loose from the base nut and falls off. When the chrome shell falls off you see the base steel lug nut but it will be a different size (smaller) than the chrome plated outer shell. At that point your lug wrench will be too big and you cannot remove the nuts.
The common fix it to determine your thread size and buy replacement (solid steel, chrome plated) lug nuts. The solid steel lug nuts will be uniformly chrome plated on the exterior surfaces including the tapered portion that mates to the wheel.
The two piece designs can be deceiving and you may think you have solid steel lug nuts. The two piece designs are lighter than solid steel and typically the tapered section that mates to the wheel is not "wrapped" with the chrome plated shell so you'll see the underlying steel lug nut.
Hope that helps.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 11-30-2015, 11:50 AM   #44
batman's Avatar
1964 22' Safari
modesto , California
LOL, this thread is getting better.
batman is offline   Reply With Quote
Proper torque for lug nuts. ole-red Off Topic Forum 9 05-31-2014 08:58 AM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
Correct Torque for wheel lug nuts? Cracker Wheels, Hubs & Bearings 2 05-30-2004 09:24 AM
