Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 04-30-2005, 03:28 PM   #43
Anon
Profile:
Originally Posted by markdoane
Guess I'm not sure what this formula has to do with the discussion. Can you let us know where you were going to go with this?
See my last post.
Anon is offline   Reply With Quote
Old 04-30-2005, 04:36 PM   #44
markdoane
Profile:  , Minnesota
Images: 59
Originally Posted by pattersontoo
See my last post.
I'm working my way back up to see what the topic was before we started talking about incorrect geometry formulas.
Your post on tire roundness was the last one before it got sidetracked.
Even if the forumla was incorrect, I thought you were going to make some point about tire roundness and hot tires. Were you? And what was it?
Non-contributing deadbeat.
Old 04-30-2005, 06:37 PM   #45
Anon
Profile:
Thanks for putting me back on track.
I totally lost where I was going.
Now that you mention it, I used to hear old fellas talk about tires that sat too long developing "flat spots". Not sure if there is any truth to this but I would think that if a tire sat in one spot too long it could become "out of round".
I am just wondering if this could be a problem. The age of the tire, coupled with the "roundness".
I am just throwing out food for thought. Not really looking to get jumped about this being fact or fiction.
Old 04-30-2005, 08:14 PM   #46
gotair
gotair's Avatar
Profile:
What Are You Guys Talk'n Bout
C x pi x radious = A BETTER AXEL FOR LESS MONEY
Life's short...take your kid camping
gotair is offline   Reply With Quote
Old 04-30-2005, 10:55 PM   #47
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
That is from when most tires were bias ply, if the vehicle sat overnight, the belts would take a "set" in the part of the tire that was on the ground.This would cause a "thump, thump, thump" and a vibration until the tires had warmed back up, and the nylon belts had become flexible enough to smooth out the flat spot.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 04-30-2005, 11:03 PM   #48
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
FWIW, I keep the Safari at 65psi regardless of how full or empty the Safari is. Also I keep 80 back and I think it's 80 front...going by what's on the tire for the Suburban, though it makes sense it might be less, but I figured, it's less rolling resist leading to better MPG....and ride quality isn't all that bad, or I just have not yet been bothered by it yet.
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Whitewall Tires 66whitebread Tires 0 09-17-2002 06:29 PM
LT versus ST tires on a trailer 76Argosy Tires 16 08-21-2002 06:15 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
Best wheels & Tires... Andy R Wheels 4 04-15-2002 10:41 AM
