Old 07-29-2005, 10:52 PM   #1
d , South Dakota
Send a message via MSN to mshea
High profile tires for 73 Overlander?
Hey,
I have a 73 overlander that is 27'. The tires are dry rotted such that I can't determine the size. I also don't see a tire size listed in the manual.
My question is what is the standard size trailer tire for this trailer?
My second question is whether there is any leeway on tire sizes to allow for a higher than normal tire wall i.e. high profile tire as opposed to low profile. The reason being we have put a gravel parking pad at the end of our driveway. In order to get it up the driveway, I must back it up an incline with a relatively sharp angle as driveways go. I did get it up the driveway, but I had to lay boards down on the driveway and drive over them to increase the distance between the bottom of the trailer and the driveway. Otherwise it scraped on the way up. I'd prefer not to have to do this again.
Thanks in advance!
Mike
mshea is offline   Reply With Quote
Old 07-29-2005, 11:24 PM   #2
AIR #6370
hmsteader's Avatar
2001 27' Safari
Bella Vista , Arkansas
High profile tires
Before you do this, did you consider dropping your tongue a few inches? For instance, did you remove the spring bars from your equalizer hitch before backing up? It might be just enough to make the difference. Just a thought.
Good luck.
Originally Posted by mshea
Hey,
Thanks in advance!
Mike
hmsteader is offline   Reply With Quote
Old 07-30-2005, 08:07 AM   #3
RichardT's Avatar
Are you from Sylmar CA? I had a neighbor named Mike Shea when I was a kid
or are you a weather spotter for channel 13? I saw someone with your name on it too!
Richard
Welcome to the forums
The correct tire size is 700X15
RichardT is offline   Reply With Quote
Old 07-30-2005, 08:31 AM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Check your axles as well. The torsion arms should slightly point down with a loaded trailer. Maybe your suspension has sagged.
A search in the axle forum will answer those questions.
A 7x15 bias ply tire is about as tall as they come. It was original equipment on your trailer. You should have load range D installed.
Uwe
www.area63productions.com
Old 07-30-2005, 09:31 AM   #5
d , South Dakota
Yes, I have an adjustable hitch that uses a socket to lower. I brought it all the way down and it still dragged. Thanks!
Old 07-30-2005, 09:38 AM   #6
d , South Dakota
No, that's not me. But I believe I met you last summer when looking for an AS
Old 07-30-2005, 09:39 AM   #7
d , South Dakota
Hey Uwe,
I'll check this out.
Mike
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
sky high prices overlander Our Community 17 10-09-2002 03:52 PM
tires and UV ALANSD Airstream Motorhome Forums 0 05-04-2002 03:31 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
