Old 11-04-2011, 06:07 PM   #1
2008 28' Safari SE
Punta Gorda , Florida
Hercules Tires
Although my 15" Goodyear Marathon's have not yet failed, they have some visual signs to be very concerned about. After reading this forum as well as other sources it appears the options for replacement are: Marathons, Carlisles, Towmasters, Hercules and Michelin LT tires. From what I read, the first choice would have been the Michelin's, however the tire well clearance was pretty close comparing the 235 to the 225. I was introduced to Hercules which made me pause. First of all, they are the same size as the present tire; then 10 ply with an E rating. My research to date has not discovered anything objectionable. Has anyone had experience with this brand - good or bad - for me to consider. I am told my 7,300 GVRW should allow the PSI to be 65ish rather than the 80LB max.
John Dibble
2008 Safari 28
mysecondjoy is offline   Reply With Quote
Old 11-04-2011, 07:10 PM   #2
r carl's Avatar
Lin , Ne
If the Hercules tires are made in china they are junk like the rest of the stuff made there.
r carl is online now   Reply With Quote
Old 11-04-2011, 07:23 PM   #3
SteveH's Avatar
Common Sense , Texas
I've not used the Hercules tires, or heard of them before for that matter, but I've had two sets of Towmasters, have a set now, and have not had troubles with them. From what I've witnessed of friend's troubles with Carlisle's and Marathon's, I would not have them on my trailer.
Regards,
Steve
Old 11-04-2011, 08:38 PM   #4
1969 27' Overlander
Albuquerque , New Mexico
Commodores?
I just bought a set of 10 ply ST225/75R15 Commodores, load range E, for $116.00 each, from Big O Tires. They assured me the tires were made in the Phillipines, not China. 12 month warranty on them.
Can't find anything on the net about them either, but the tire guys told me they hadn't had any warranty/returns.
I'll see how they hold up.
Hope I didn't get snookered.
edglenn is offline   Reply With Quote
Old 11-05-2011, 06:15 AM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink Junk stuff...
Everything made in NY, CA and TX is also junk.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-05-2011, 07:27 AM   #6
r carl's Avatar
Lin , Ne
Is thate true Steve?
Old 11-05-2011, 07:46 AM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I don't take the made-in-China thing too seriously. They'll make anything you want, from cheap to expensive (in terms of both price and quality), though if it's going to be expensive anyway, it seems that some of the companies that order up these products then choose to have them built elsewhere.
We have Hercules tires on our Airstream. Big ol' bias ply things. As usual, they usually begin to rot in the NM sun before we get that many miles on them. That's when I recycle them over to our gravel trailer (same size wheels) and wear them out. They're kind of hard to get to hold air (tubes recommended) and to balance (Centramatics recommended), though that may as much a function of our wheels as of the tires themselves.
Lynn
WBCCI 21043
Old 11-05-2011, 08:08 AM   #8
I installed Michelin P 235 R 75 15 LTX XL on my 2004 25 Safari. There is little difference in the size of these tires compared to the ST 225 R 15 factory tires. There is plenty of wheel well clearance for even a do it yourself tire change which I had to do when I ran over a screw.
I travel in hot weather and blew up lots of ST tires of various brands all over the sun belt.
Good Year Marathons and all the no names I purchased at various small town tire stores are of the same dubious quality.
The bottom line is that all will fail driven at freeway speeds (65 mph or under) at 100 + temperature. ST tires are rated at 100 degrees max.
I did have slightly better luck with Maxxis E's. A set lasted three years before I replaced all of them due to a tread seperation of one tire.
E rated tires inflated to 75 pounds made my trailer ride like an oxcart and hobby horsed even my stiffly sprung Excursion over whoop de doos.
My Michelins are extra load, each tire carries over 2000 pounds. My trailer's gvw is 6300 lbs (300 on the hitch) so I have plenty of capacity. There is still sufficient capacity for a 7300 gvw trailer.
I can now travel at 70 mph in 100 degree + weather all day with safety. At 50 lbs inflation the ride is much smoother.
Cost was 140 per tire, not much more than ST tires.
handn is offline   Reply With Quote
Old 11-05-2011, 09:07 AM   #9
1969 27' Overlander
Tire clearance: 225 vs 235
Hmmm.... I didn't know 235's would fit easliy in the wheel wells. That's why I stayed with 225's, which are no longer available in "LT"'s.
I would have preferred truck tires over trailer tire, for all the obvious reasons. Maybe I'll try them next time.
Does anyone know if there's a clearance issue on mid 60's Overlanders with 235's?
Old 11-05-2011, 09:28 AM   #10
2008 28' Safari SE
Isn't this whole tire thing crazy? We are forced to chose our tires from what we determine to be the best of the bad choices. On Monday I am going to go with blind faith and install the Hercules on my Silver Manatee. I just added Centramatics which should help (or not hurt) and I am going to install metal valves. In my mind, I take the fact that there are few bad experiences reported to be a good thing. It was a toss up between Towmasters and Hurcules. Hercules won the flip of the coin without any convincing facts to support the decision. Not the way I normally do business!
My thought at present is to reduce the tire pressure from the 80 LB Max. to 65 LB due to the approx. 1,800 - 1,900 weight per wheel (without a reduction for the tungue weight). Are there any recommendations on my tire pressure thoughts?
John Dibble
2008 Safari 28
Old 11-05-2011, 09:43 AM   #11
Maniacal Engineer
barts's Avatar
Menlo Park , California
I also have been quite happy with Michelin 15" LTX tires on the Tin Pickle.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 11-05-2011, 12:33 PM   #12
r carl's Avatar
Lin , Ne
John Dibble
2008 Safari 28
The only thing crazy is putting a cheap tire on an airstream that you love. Just put on these tires if they will fit, they are a high quality japanese LT tire that looks good on an older trailer.
Yokohama RY215
Old 11-05-2011, 10:43 PM   #13
1969 27' Overlander
Stupid question...
So, if a LOT of RV owners seem to be having difficulty finding good quality tires to put on their Airstreams and wanting to avoid using utility trailer tires, then why isn't there a tire manufacturer catering to this demographic? Why should we have to go to "LT" tires?
RV's, especially Airstreams, are a good market. Why aren't the tire companies jumping through hoops to get our business?
It's not like the economy is so great that they can ignore a good market potential.
Am I missing something?
Old 11-06-2011, 04:21 AM   #14
I'm tyre'd of this...
PFC
RLC
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
