Old 04-15-2009, 08:59 AM   #1
Elf1's Avatar
1990 34' Limited
Proud to be , an American
HELP- Please- 73' 25' needs tires- need size
My father has been towing an airstream for 40+ years and we can't figure this one out-
I just bought a 73' 25'. The previous owners put Liberators (sp) on them - hey are a Walmart brand- very cheap tire- problem is that Walmart codes their tires so you can't easily replace them . Side wall states 30x9.50 R15. I am looking for Goodyear Radials- any help would be appreciated. feel free to PM me or eglisems@hotmail.com Heading x-country next week and need to get these taken carae of ASAP- All the best-
Elf1 is offline   Reply With Quote
Old 04-15-2009, 09:18 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Any good tire shop could measure the tire Dia. and give you a size. Your limiting factor is the clearance to the top of the wheel well. If the axles are old and have a positive angle keep this in mind.
2004 Excursion 4x4
Old 04-15-2009, 09:28 AM   #3
1986 31' Sovereign
Miami , Florida
Tires are one of the "3rd Rail" subjects on the Forums -- touch it and you die! (Well, almost). Fundamentally there has been enormous bandwidth expended extolling and condemning various brands/sizes. Do a search on "tires" and you will have a couple of days reading.
I have had Carlisles, Power King (both Chinese) and Goodyears. The Carlisles were fine for 25000 miles and then 3 out of 4 failed (catastrophically) within 2000 miles of each other so, maybe not.
The others were unremarkable one way or the other.
For what it's worth my trailer wears ST 225/75 R15 tires.
mike
n2916s is online now   Reply With Quote
73' Argosy Waste Tank Sundance Waste Systems, Tanks & Totes 12 07-22-2008 06:17 AM
Size of Blackwater Holding Tank 1999 Safari 25' Aluminumb 1999 Safari 0 12-17-2007 11:04 AM
73' Dometic Sundance Refrigerators 3 04-16-2007 07:14 PM
Size of Hitch Ball on 25' 1996 Excella? Streamer1 Hitches, Couplers & Balls 5 09-07-2006 04:50 PM
what size tires? please respond within 22 hours and 46 min..... Whistling_Gypsy Tires 5 01-07-2004 04:31 PM
