Old 04-10-2016, 01:52 PM   #29
richw46's Avatar
Lexington , Kentucky
[QUOTE=tjdonahoe;1774700]
Originally Posted by Mrjkq View Post
You should read the post from rtaylor 537 about twainese maxis tires.....
From what I read at Wikipedia, Maxxis is a wholly owned subsidiary of Cheng Shin tire manufacturer, which made only bicycle tires until 2009 when they started making tires for other applications, including Maxxis brand tires.
Like most things in life, your mileage may vary with the products you purchase. I have always tried to research as much as I can before I buy anything of consequence, for quality, safety and price. My own personal experience with a product determines if I am a repeat customer. I've run Goodyear tires on my cars and SUV for years, never had a problem. I've run GYMs on my boat trailer and now the AS I purchased a couple years ago. The AS had GYMs purchased by the original owner as replacements.
The only problem I've had so far was a GYM on my boat trailer, it blew out when I was going 75 on a 95 degree day and the tire was about 12 years old, maybe more. It was not a Chinese made tire but the new ones are.
If these GYMs give me a problem I will probably switch, but the ones on the AS are due for replacement this year and I've not had any issues, neither did the original owner. No problems on the boat trailer either. Maybe it's the size that is the issue. At NHTSA the majority seem to be 16" where mine are 14" and max inflation is 50 psi compared to 65 for others. My boat GYMs are about the same size and they are also max 50 psi.
I think to have any kind of meaningful comparison of ST tires you need to have more than just anecdotal data and more than a single survey from a single trailer manufacturer that put mostly the same brand/type of tires on all of its products. You need researched data about the tires manufactured for a specific application, like ST tires. You can't have a comparison among LT and ST tires because not all LT tires are used on trailers, most are used on light trucks. You'd have to compare only ST tires, you'd have to determine the number of failures per some figure of manufacture to determine a failure rate, like 1 out of 1,000 tires manufactured. You'd have to do the comparisons by year and note any change in the process, such as Goodyear moving production to China. There are so many things that would need to be included in a REAL research project for it to be meaningful.
In the meantime, I'll do like I've done all my life, stick with the good products and reject the ones that have caused me grief. I think that's all that any of us can do.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-10-2016, 02:01 PM   #30
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
GYMs from China or not?
Careful using Wiki as a source of fact. It can be almost as unreliable as Airforums. 😜
MICHAEL
Old 04-10-2016, 03:20 PM   #31
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
[QUOTE=richw46;1774624]
Thanks, Joe, I appreciate the offer, but I don't buy used tires.
Don't blame you Rich, I wouldn't either. Funny thing, this morning I had the GYM's switched out & the dealer/installer could not believe that I actually switched out new (looking) tires for new tires. I asked him what brand of ST tires he sell's most of, he said Goodyear Marathons. Maybe it's just me but since day 1 I've had a thing for these tires, probably from having had a blow out with Carlisle tires on a previous trailer and reading about GYM's on this forum.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 04-10-2016, 03:41 PM   #32
richw46's Avatar
Originally Posted by AWCHIEF View Post
Careful using Wiki as a source of fact. It can be almost as unreliable as Airforums. ��
I misunderstood, Maxxis has been around since 1967, but was acquired by Cheng Shin Rubber. [https://torquepost.wordpress.com/201...who-owns-who/]. It is a wholly owned subsidiary.
The Wikipedia article has its references linked to the article:
http://www.dealernews.com/dealernews...n-rebrands-cst
-Rich
Rich & Yvonne
2004 4Runner SE
Old 04-10-2016, 03:59 PM   #33
richw46's Avatar
[QUOTE=Mrjkq;1774805]
I've always had good luck with tires.... except with Carlisles on my old boat trailer. Other than the Carlisles, I can recall only 2 blowouts in my entire driving career. That one on the Ranger boat trailer and a Yokohama on my '91 Camry. I owned an '89 Toyota pickup (new) until 2003 and never even had a flat in 193,000 miles. I sold that and bought a 2004 4Runner and had a flat on the first day I took it to work. I've had 2 tires with slow leaks since then, same SUV. I had 2 Dunlops (Goodyear) that developed tread separation bulges but held together for over 800 miles, towing my Ranger boat in summer heat. They were pretty old, 10 years at least, with 60,000 miles on them.
Maybe I'm just "Tire Charmed"???
Peace of mind is worth a lot. If someone doesn't feel comfortable with a particular brand of tire then every mile is torture. Might as well change them out for something that puts your mind at ease so you can enjoy your travels.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 04-10-2016, 04:07 PM   #34
richw46's Avatar
Who owns Whom
Found this while poking around the Interweb this afternoon:
https://torquepost.wordpress.com/201...-who-owns-who/
The following is a list of major tire companies. There are many many other tire brands in existence, however these are some of the more common ones and the other most common brands that they own. The list also features the country and year of founding.
  • Bridgestone – Japan 1931 – also owns Firestone, Fuzion, and Uniroyal Australia.
  • Cheng Shin Rubber Ind. Co. Ltd. – Taiwan 1967 – owns Maxxis Tire
  • Continental Corporation – Germany 1871 – also owns Dunlop Malaysia, Singapore and Brunei, General Tire, and Uniroyal (outside of NAFTA region and Colombia, and Peru)
  • Cooper Tires – USA 1974 – also owns Avon tyre.
  • GoodYear – USA 1898 – also owns Dunlop.
  • Michelin Group – France 1889 – also owns BFGoodrich and Uniroyal North America.
  • Sumitomo Rubber Industries – Japan 1909 – also owns Dunlop Japan, Falken Tire, and GoodYear Japan.
  • Toyo Tire And Rubber Company – Japan 1943 – also owns Nitto Tire
-Rich
Rich & Yvonne
2004 4Runner SE
Old 04-11-2016, 09:05 AM   #35
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I have had GYM ST tire failure on the twin axle Harley hauler of my past as well as the current single axle rail motorcycle trailer. Even though the spare tire was covered from the sun on the rail trailer, the spare just delaminated the tread and it had never been on the ground.
I ended up putting 13" Michelin car tires on the single axle trailer since the loaded weight was under 1,300 pounds for the trailer with my Gold Wing aboard. The trailer does not bounce and rattle with the Michelin tires.
Old 04-11-2016, 11:17 AM   #36
richw46's Avatar
I've read that passenger tires on a trailer is not recommended because passenger tire sidewalls are soft for a smoother ride. They don't provide the lateral support to prevent swaying/fishtailing. It may not be an issue on your motorcycle trailer but I wouldn't put them on my AS or boat trailer.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 04-11-2016, 07:59 PM   #37
2014 27' Flying Cloud
Stowe , Vermont
Our first AS 2007 25ft. Safari with GYMs, 60,000 miles no problem. Current 2014, 27 ft. Flying Cloud with 28,000 miles on GYMs- one tire down at the end of the first year - 6" bolt thru it.
VT Wanderer is offline   Reply With Quote
Old 04-12-2016, 10:37 AM   #38
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
Have been running car tires on trailers since the sixtys , we ran P235/75R15 inch Generals on our 66 Airstream , and ran Cooper P235/75R15s on the 2005 Airstream for years including an 11,000 mile trip to Alaska and back . Have replaced them with the same size p rated Michelins 2 years back .
There is defiantly no problem whatsoever in the handling of these trailers and the shocks that are absorbed instead of being transferred to the trailer makes for a much smoother ride.
dannydimitt is offline   Reply With Quote
Old 04-13-2016, 07:47 AM   #39
switz's Avatar
2014 31' Classic
Images: 8
I have towed my two Airstreams with the 15" Michelin LTX (P) 235/75R15 XL tires installed and set to 44 psi and both were attached to the Mercedes ML320 CDI diesel with a Hensley Arrow weight distribution hitch. I had no sway issues or was not blown around when the trucks passed going 25 to 30 mph faster than I was driving. There have been a couple of occasions where thunderstorms were generating significant cross winds and the trailer tracked true.
So the proper setup of the Hensley Arrow prevented the sway issues on the two smaller trailers and the ProPride does the same for the 31' Classic using 16" Michelin LT225/75R16/E LTX M/S2 tires as installed by the factory on the newer Classics and Eddie Bauer models and offered as an option at the factory service center.
Old 04-13-2016, 08:19 AM   #40
Ravenna , Ohio
Originally Posted by cbrittan View Post
Our AS was delivered from the factory to CANAM with stock tires. On delivery we specified "Michelin HEAVY LOAD" P235/75 R15 LTX M/S with carry capacity at 50lbs (max) inflation of 2183 lbs. These tires have Michelin in white letters and are available from most if not all Michelin dealers in North America.
As we understand it, these tires carry a heavier load at a lower air pressure, which is said to improve the AS ride, stress on components and contents. We also hear these tires may have an improved ability to deal with "scrub" caused by turns.
In our opinion, these tires have a slightly different appearance, in that the sidewalls appear to be thicker. There will be other differences not known to ourselves, but we can say these tires have held 47 lbs air pressure without loss of even a single pound, over the past 8 months in Florida winter climate.
These tires are monitored for failure by USDOT and I have found no reported evidence as to failures. Needless to say, we are pleased so far with Michelin performance and enjoy not having to debate the merits of tire country of origin.
Clarification. USDOT or more correctly NHTSA collects complaints on tire failures. A significant issue with using the NHTSA complaint database is that a very small percentage of RV owners know they can file complaints. Another problem is that many ST type tires are made in batches small enough such that the MFG is not required to report failures to NHTSA. So if the only complaining done is on RV forums or around campfires there will be no data at NHTSA. With no data there will be no investigation and no investigation menas no recall or pressure on tire company to make a better tire.
We have identified the enemy and it is the failure to act on the part of the RV community.
Tireman9 is offline   Reply With Quote
Old 04-13-2016, 08:30 AM   #41
Ravenna , Ohio
Originally Posted by Jacob D View Post
The "horror stories" are just that.....stories. I run nothing but Good Year tires on my TV and vintage AS. I once ran a set of Canadian made GYM's for 13 years with only one flat because of a nail. That'w what woke me to the age of the tires and I replaced them with a set of China tires which have been on for two years with no issues. I run them with 43 psi pressure on a tandem axle trailer which is the pressure indicated for the weight of my trailer on the Good Year chart.
You can buy spray treatment to prevent UV degradation and cracking which some folks call "dry rot".. I spray mine once a month with Armor All Tire Foam and keep them covered if idle for more than a month. Storage in my drive way is on pavement which I think helps. To find out the correct pressure to use, weigh your trailer one axle at a time and consult the manufacturer's weight chart. Better yet, weigh one wheel at a time and use the pressure indicated for the highest weight on all wheels.
RE "pavement" be sure that is not asphalt as the oil in the tar can attack the rubber.
Covering tires especially with white covers is a good idea as it lowers the tire temperature significantly which slows the aging (dry-rot) process. See my blog post of June 16, 2011 "Tire Covers - Do they do any good?" for test data.
Trailers are not the same as on motorized units (Motorhomes) as the tires of a trailer do not rotate about the center of a turn radius but are dragged around every corner and turn. This results is a significant increase in "Interply Shear" which is the force in the tire structure that is trying to tear the tread off the body of the tire. You can learn about more with Google of "Interply Shear Tires"
To lower this force trailers should always run the max inflation shown on the tire sidewall.
You still should get the TT weighed to be sure you are not overloading your tires as a majority of RVs have a tire and/or axle in overload when checked.
Old 04-13-2016, 08:46 AM   #42
Ravenna , Ohio
[QUOTE=richw46;1774755]
Originally Posted by tjdonahoe View Post
snip
snip
Until late 2015 all ST type tires had a MAX speed rating of 65 mph. That is not an average. Think of it like the engine redline. You can run an engine bast that speed but not without suffering consequences.
Max speed recommendations in print from some tire companies for any tire in RV application is 75 no matter what the tire says. RV application is much tougher than car application due to constant high load.
With data showing that a majority of RVs are operating with one or more tire/axle in overload and the side loading placed on TT application I would stick with 65 as a MAX no matter what the tire says. That is what I do as a tire engineer w/40 years experience. Never had a "blowout" or tire failure while running down the road.including on RVs or 1Ton dually w/26' enclosed trailer with Camaro race car inside going cross country.
Replaced 7 year old GYMs Antique Pedaler Tires 13 04-21-2015 12:52 PM
China Cabinet Light Switch? MarkExc500 1978- 1979 Excella 500 8 10-08-2007 06:52 PM
