Old 03-24-2014, 10:53 AM   #1
1990 32' Excella
jonesboro , Arkansas
Greeenball tires
Has anyone put the green all tow master tires on . I have allways used light truck, but since they have lowered the wt rating on the tires I have to change. I still have the 15 in wheels. I have visited all the local tire stores and there are very few options in the 15s.
joel is offline   Reply With Quote
Old 03-24-2014, 12:44 PM   #2
1986 31' Sovereign
Miami , Florida
Tire talk is a subject of great contention on the Forums. My personal experience with Carlisle and Greenball (both imports) was poor with numerous catastrophic failures despite my obsessive/compulsive attention to my tires.
I ended up with GYM's which are routinely trashed on this forum yet have worked fine for me for three years and about 18000 miles so far.
So, it is tough to make a recommendation one way or the other. Kind of like choosing a religion...
Whatever you choose, I highly recommend a TPMS. Mine saved my bacon more than once.
Mike
Old 03-24-2014, 01:34 PM   #3
1990 32' Excella
green ball
Unfortunatly i am at a loss.I cant find a d rated light truck.or an e rated in a 15month in wheel.sny one with ideas welcome.
Old 03-24-2014, 01:44 PM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Buy 16' wheels for the truck?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-24-2014, 01:44 PM   #5
m.hony's Avatar
2013 30' Classic
..or trailer..
or get Good Year Marathons...
TAC #MS-10
Airforums #70955
Old 03-24-2014, 02:13 PM   #6
1990 32' Excella
For the trailor. With all the links about marathon failure at high temps andth fact that our trips are mostly out west. I am not sure about them.
Old 03-24-2014, 02:56 PM   #7
m.hony's Avatar
2013 30' Classic
My plan is to get 16' wheels and use Firestone TransForce HT 225/75R16 tires.
TAC #MS-10
Airforums #70955
Old 03-25-2014, 06:01 AM   #8
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by joel View Post
Unfortunately, Ii am at a loss.I cant find a D rated light truck tire or an E rated in a 15" mounted on a wheel. Anyone with ideas welcome.
Could you be a little more definitive? What tire size do you currently have? Are you really looking for a tire already mounted?
Just a note: There are some alternatives that will work, but we need to get specific.
CapriRacer is offline   Reply With Quote
Old 03-25-2014, 06:18 AM   #9
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
How about these?
http://www.tirerack.com/tires/tires....omCompare1=yes
Depending on the load you typically carry, I would also recommend these-
Or these-
Lance
Top is offline   Reply With Quote
Old 03-25-2014, 06:22 AM   #10
m.hony's Avatar
2013 30' Classic
My previous trailer had 15" wheels. In June of 2012 I was able to get some 8-ply load range D tires for it through Dunlap & Kyle, a tire distributor in Batesville, MS.
TAC #MS-10
Airforums #70955
Old 03-25-2014, 06:24 AM   #11
m.hony's Avatar
2013 30' Classic
Just getting new radial tires for the trailer improved its road manners tremendously.
It may be the difference in bias ply and radial tires, too.
Tightening the bearings 1/4 turn each on the curb side helped, too.
For some reason the bearings on the street side were snug, but the ones on the curb side were a little loose. Go figure.
TAC #MS-10
Airforums #70955
Old 03-25-2014, 07:50 AM   #12
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
What TOP said...I use em on all my stuff....except the 700 x 15's I use on one.
Old 03-25-2014, 01:46 PM   #13
1990 32' Excella
greenball problem solved
Thanks for all the help. I went with 16sand transforce 225/75/16.wheels were only50 apiece andpiece of mind priceless
Old 03-25-2014, 01:55 PM   #14
m.hony's Avatar
2013 30' Classic
Woohoo!
Go 'head on, wit yo bad sef!
TAC #MS-10
Airforums #70955
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
