Old 04-22-2014, 07:50 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Got a flat, where do I jack?
I have a 75 Argosy 26 and the back right tire is flat when I hitched up. Underneath, the axle that the PO had installed by Andy a few years back is clearly visible and I assume it is where I should jack but I am second guessing that.
Before I ruin the axle, if someone could shed some light I'd appreciate it.
Thx
Dan
Dan S is offline   Reply With Quote
Old 04-22-2014, 07:54 PM   #2
Dan S's Avatar
1975 Argosy 26
Forgot the pic
ID:	210291   Click image for larger version
Old 04-22-2014, 08:06 PM   #3
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Don't jack on the axle! Jack on the axle mounting plate, if you have to. Easier way with a dual axle trailer is to run the two wheels of the "good" axle up onto ramps so it lifts the wheel you need to remove off the ground.
Old 05-25-2014, 07:37 AM   #4
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
After using this product, I will never try and jack up my AS to change a tire. It is the only way to go. Inexpensive, safe and light weight. AS ought to have them as an option from the factory, IMHO.
Trailer Aid - Free Shipping on Orders Over $99 at Genuine Hotrod Hardware
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 05-25-2014, 08:05 AM   #5
Why spend any money ??
Changing tires on any tandem or triaxle Airstream, is easier than a piece of cake.
Sinply pull the good tire up on a couple of 2 X 6's.
The flat tire will now hang in the air.
Cheap? You bet.
Safe? You bet.
Can a mistake be made? How??
Old 05-25-2014, 08:19 AM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
What Pappy 19 Said
Fast, safe, efficient and non-destructive.
Why damage an axle or punch a hole in your shell with a misplaced jack?
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 05-25-2014, 08:44 AM   #7
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I am not sure about Arogosy but on Airstream there are small squares that provide a pinpoint of where to jack, that and the fact that there are words that say JACK with and arrow pointing to it as well. Mine are located behind the rear wheel area from the side about a foot or so. (guessing). Naturally if you have those ramps and the trailer hitched up you can follow the previous suggestions.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-25-2014, 10:27 AM   #8
Those are by FAR, the worst places to jack an Airstream or Argosy trailer.
WHY???
If you don't have the jack placed exactly "CORRECT", it will slip off and punch a hole in the underbelly and sometimes the floor.
How do I know??
Having serviced those products for almost 50 years, gives a person considerable experience with all kinds and types of issue's.
The only real safe place to jack up any Airstream or Argosy trailer is from the axle mounting plate.
Old 05-26-2014, 09:58 AM   #9
pappy19's Avatar
Why don't you use the Trailer Aid, Andy? If I was in your position, I's sell them by the dozen.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Old 05-26-2014, 10:11 AM   #10
richw46's Avatar
Lexington , Kentucky
WHY???
How do I know??
Hi Andy, if I want to store my tandem axle trailer on jack stands, do I jack up on the axle mounting plates then put the jack stand at the jacking point or vice versa? Is there a better way to keep the tires off the ground?
thanks
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-26-2014, 10:38 AM   #11
thanks
I have always recommended 6 jack stands.
2 on the A-frame just forward of the banana wraps, 2 on the axle mounting plates between the tires and 2 at the rear frame as it enters the banana wraps.
You can adjust the jack stands so that the tires don't even touch the ground.
That system works even when high winds hit the trailer.
How do you know you've got a flat? Gringo On The Road... 56 12-23-2011 03:09 PM
Got a new axle on my and I am not sure what I got rustyrivet Axles 3 11-26-2008 08:44 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Got to ask.. Have I got Frame seperation? JohnG Repairing/Replacing Floor &/or Frame 7 07-23-2004 11:21 AM
'77 Argosy, should I jack because tires flat? saxonsraven1 Mechanics Corner - Engines, Transmission & More... 1 01-26-2004 02:18 PM
