08-31-2006, 12:26 PM
#21
2003 25' Safari
Yakima
tires
FWIW, aircraft tires are still mostly natural rubber due to its higher heat rejection/dissapation properties. Downside, they don't wear as long as the synthetic compounds i.e. most over-the-road tires nowadays....can't have everything
08-31-2006, 03:51 PM
#22
2004 30' Land Yacht Gas 30
, OH
wood paneling
During a factory tour in Jackson Center, late 1987 we saw huge stacks of oak paneling from USSR in the manufacturing area. Guess they used wood from USSR back then.....
gonagn
09-02-2006, 08:25 AM
#23
1963 19' Globetrotter
Orion
for Nick
Second week of' ' 06 on the tire code. Love the service from Tire Rack!
09-02-2006, 04:31 PM
#24
63air, that's good. Just what I needed to know. Many thanks.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
09-03-2006, 11:16 PM
#25
Salem
, Oregon
09-05-2006, 09:10 AM
#26
Moderator dude
1966 26' Overlander
Phoenix
Originally Posted by AZstreamin
… So I got new rubbers for pennies and they are now perfectly balanced and they track like a dream now.
My AS is back in storage or I'd post a photo for identification..
Now that you have made that investment. Make sure your tires are covered. The sun out here is brutal. If your storage place covers the tires from ALL sun throughout the day right on! If not get some tire covers. About $20 for two wheels. Or at least get a piece of wood or cloth to keep that sun off the tire. And another issue might be to park the tires on wood if it is a concrete slab that your baby rests on, to keep the tires out of contact with the concrete.
>>>>>>>>>>>>>>>>>>>>>>Action
09-21-2006, 07:32 PM
#27
2007 28' Safari
Orcutt
Marathon blowout on 2007.
I just purchased a new 2007 Safari. Took it on our first trip and within 500 miles had a blow out! Was very surprised as my other Safari had same tires. Put on the spare and it is a Marathon same size etc. The spare tire itself looks different on the outside but is the same Marathon. Went to tire shop where we were camping and asked for a replacement to have a backup for return trip. He put on a used for now until I could get in touch with the dealer. He commented, the side wall on the Marathon blown out seemed on the thin side for a trailer this size. Trailer is a 28ft. at 7300 GVWR. The Marathons on it are a 6 ply which seems to be low based on what others are writing in the forums. I also noticed on 2005 unit and the 2007 that there are waves in the side walls as mentioned in other posts. I will surely look in to this. The dealer is currently checking in to the matter for me.
09-21-2006, 08:33 PM
#28
Huntington Beach
Safety
Pimprnel,
I'll bet you were glad you had a tandem axle AS. Sorry to hear the tire only made it 500 miles.
John
09-22-2006, 08:59 AM
#29
2004 30' Classic Slideout
Fenton
, Missouri
As noted earlier it's not unusual to see wave's in the radial tires. It is part of the construction process. You just don't want the bulges in the sidewalls which indicate a sidewall failure.
Just a couple of questions, did you check out your tire pressures before you left on your first trip, or did you assume your dealer did this for you? Second and third questions relate to the tires themselves. Did you check whether you had a load rated D tire and did you look at the manufacturing date of the tire that failed? I 've seen a situation where a new Classic trailer was found to have a C rated tire in its mix of 4. That C rated tire blew.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
09-22-2006, 10:15 AM
#30
More than one rivet loose
Los Alamos
, New Mexico
Goodyear is the only American "owned" company left. Firestone; Japan, Michelin; French a good reason to boycott Michelin.
Michelle TAC MT-0
Sarah, Snowball
09-22-2006, 10:32 AM
#31
1978 24' Argosy 24
Woodinville
Cooper is also American owned. But, if supporting the US economy is the goal or a perceived quality inherent in US products it might be more important to look at who actually manufactures tires in the US.
-Bernie
09-27-2006, 09:53 PM
#32
Round on both ends
1979 31' Excella 500
1975 28' Argosy 28
Rutledge
, Georgia
Hi, Bernie,
Marathons made in New Zealand complicate the picture.
I had a tire bumping on I-20 today that scared me, and back to the Goodyear shop crept I. The (inherited) Lincoln now has a new "Eagle GA Touring" sitting on the front left.
This tire has even *more* scripture on the sides of it to read than than the last set.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
