Old 08-27-2012, 05:09 PM   #41
2005 19' Safari
GLENDALE , AZ
For discussion purposes, how does one explain a failure rate of 55% when running 15-inch ST tires, that drops to zero after switching to 16-inch wheels and LT tires, when nothing else is changed?
Old 08-27-2012, 07:01 PM   #42
Ag&Au's Avatar
Port Orchard , Washington
The extra 1/2 inch in height allows more air to flow under the trailer, thus keeping the tires cooler, thus avoiding blowouts? You didn't thinlk anyone was going to come up with a reason, did you?
Ken
PS, I am convinced mine is more that 1/2 inch higher. However I'm not going to swap back in order to measure it.
Old 08-27-2012, 07:36 PM   #43
2006 25' International CCD
hobe sound , Florida
Just purchased an 06 25ccd, and replaced the original tyres, due to age. Had 5 goodyear marathons installed. After about 500 miles we blew a left rear.
All tyres were at proper inflation, and not run over 65mph. After about another thousand miles, we found another tyre starting to seperate.
Needless to say we are looking for another set of tyres, that will hold up for more than 1500 miles. Would like to use michelin, but can not seem to find anything in the 225/17/15 range.
Any suggestions would be helpful.
summer44 is offline   Reply With Quote
Old 08-27-2012, 07:49 PM   #44
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Well that pretty much blows the "maybe they are making them better now idea" that has been floating around here lately. 235/75/15 will fit. 16" wheels is an option. You need to look at your load ratings and whether you need c, d, or e rated tires.
Bill M. is online now   Reply With Quote
Old 08-27-2012, 07:56 PM   #45
r carl's Avatar
Lin , Ne
These aren't a cheap china tire, give them a try.
Continental*Vanco 2
Old 08-27-2012, 09:24 PM   #46
Goal15's Avatar
Holly Lake Ranch , Texas
we got our new to us 2003 Safari 23 a year ago in April.
Took a couple of short trips on what I believe were the original 14 inch GYMs. Had one tire that picked up a nail and i took it to local (not national chain) tire guy to see if i could get it plugged. He took one look at it and said he would not repair it because it was showing signs of tread separation.
I looked around and in 14 inch tires didn't have a lot of choice, so i went back with 14 GYM's mostly because I wasn't sure that 15's would fit. So long story short we have taken about 6 trips of 200 miles or less as well as two of about 1500 miles in that period of time, running the GYM's at the specified 50 lbs and even sitting in storage for a couple of months at a time, haven't lost more than a lb of air.
Not sure if that proves anything one way or the other, but just our anecdotal information.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 08-27-2012, 10:28 PM   #47
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Our next set of tires will be Goodyear Marathons!
Dana
Thanks Dana for your anecdotal information.
We also have a 23' Safari with the original 14" Goodyear Marathon tires that are now going on 6 years old and will be replacing them with a new set of GYM's by next month before we resume our typical fall-winter-spring camping season.
Our tires have done well with our routine of going on monthly 200 mile round-trips, mostly from San Diego to our nearby desert areas, from October through April, and one last trip of the season to a nearby state beach in May. And like you, I make sure they are at the specified pressure of 50 psi cold just before starting and I continuously monitor them with PressurePro tire sensors. When the trailer is parked, the tires are immediately covered (sun protection). We typically travel at the stated speed limit for vehicles towing trailers in California (55 mph) and rarely go over 62 mph. Upon return to San Diego, our trailer and tires rest on plywood boards placed on top of the cement pavement and the tires are covered.
So... knock on wood.. we will continue to rely on Goodyear Marathons... and take the usual precautions!
SilverGate is offline   Reply With Quote
Old 08-27-2012, 10:55 PM   #48
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by r carl View Post
Ya, who in their right mind would think that a tire made in china is junk.
Hi, just to mention that of the four Goodyear Marathons that went bad on my trailer, [two in about three years and the other two in about seven years] were all made in Canada. So far so good with the three Chinese Goodyear Marathons that I have on the ground now. [I have one Carlisle that I bought in Alaska]
Note: spare tire has never been used.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 08-28-2012, 05:00 AM   #49
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
15" Michelin
Summer44,
The only 15" Michelin that might work for you is the Michelin LTX M/S2 P235/75/15XL. I have these on my trailer that has the same GVWR as your 25' CCD. There are many threads about them here for you to read. The Continental Vanco 2 is a very good tire as well.
Lance
Lance M is offline   Reply With Quote
Old 08-28-2012, 07:50 PM   #50
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Here's what we put on our 27 FB a year ago with good results so far:
BF Goodrich Radial Long Trail T/A Tour
P235/75R15/XL 108T
Tire Size: Side Wall: Service Description: Mileage Warranty: UTQG:
P235/75R15/XL OWL 108T 60,000 580AB
XL means extra load.
SuperTrouper is offline   Reply With Quote
Old 08-28-2012, 07:56 PM   #51
Goal15's Avatar
guess i had 3's on the mind... ours is a 2006 model so the original tires were 5 years old when we got them.... rest of story remains the same.
Dana and Olga
2006 Safari 23
Old 08-28-2012, 08:21 PM   #52
K.C. , Missouri
Originally Posted by GettinAway View Post
Good info, thanks.. Wasn't sure what tire to go to when I replaced the 14" GYMs.
These sound perfect..
In 14" you might be able to get a Michelin dealer to order Agilis:
Agilis | Michelin Tires
Also in that size you could use Hankook RA08 or the above mentioned Kumho 857. All of these mentioned are rated as light truck tires, so they have a higher speed rating than ST tires.
gmw photos is offline   Reply With Quote
Old 08-29-2012, 04:28 AM   #53
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Thanks gmw, I hope to get a few more years out of the GYMs. But I'm definitely going to get away from them.. Eventually
GettinAway is offline   Reply With Quote
Old 08-29-2012, 08:53 AM   #54
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I think the bottom line here is: Most people are having blow outs with ST tires (NOT ALL) I didn't on my Carlise's and they are 7 years old and over 10,000 miles. But they have some bad wear on them.
So why would you want to take a chance on a blow out and $$$$ for repair, when people running LT tires are not reporting BLOW OUTS..
I an switched to 16" rims with Michelins. It cost me just over $1300.00 but I won't be shelling out a deductible to get the trailer fixed when An ST tires does blow.
I also have a tire monitoring system for $260.00 To me this is all worth the money. I have hundreds of hours into my remodel and don't want to have to fix the trailer due to a tire separation at 65 mph
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-29-2012, 09:42 AM   #55
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Well, you guys have got to me. Perfectly good GYM's on new wheels from the factory without any trouble, but I'm believing Airstream installed these for general weekend, vacation use. Over the total production it keeps prices down and still serves most customers well. That makes sense.
But we travel extensively to places (mountains, deserts, narrow back roads with little shoulder, long bridges, costal highways) where a blowout not be good. I'll call it insurance and sell the like new 15" wheel/GYM combo we have (anyone interested?).
I want the Eddie Bauer Michelin on Sendel T02 wheels (6 bolt, 0 offset) to keep the original FC appearance. Is the correct tire LTX M/S LT225/75 R16E ?
doug k
Old 08-29-2012, 09:57 AM   #56
purman's Avatar
1968 28' Ambassador
doug k
Yep, thats the tires.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-29-2012, 12:00 PM   #57
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Michelin LTX M/S LT225/75 R16E is the tire that we put on Lucy in November of 2010. Since that time they have logged right at 35,000 miles. We have experienced no tire problems, and they never seem to lose any air pressure. They also have no discernible tread wear. After my horrible ST tire experiences, I could not be more pleased.
I took this photo of the tread wear a few moments ago.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 08-30-2012, 05:48 AM   #58
fred bartlet's Avatar
2001 31' Excella
Bluffton , South Carolina
Say, have you noticed the new A/S Eddie Bower edition has 16" Michelins on them.
Fred Bartlett
30' S/O 01 Excella, maple floors in Galley, HA Hitch, Hyd. Disc Brakes, P3 Controller, SS Kit. Bk Splash, LED RL's, 2K/Tri Fuel Gen's & RV on TT
04 Chevy HD, CC, D/A, Curt Magnum V Rec., Full Amsoil Syn.,Dual Filters, ARE, MX Topper with lift Gate Door, Bed Rug, TPS & Bk.up Camera.
fred bartlet is offline   Reply With Quote
Old 08-30-2012, 06:34 AM   #59
Skater's Avatar
1995 30' Excella
Bowie , Maryland
We have Carlisle 15" tires on ours. Our long-term plan is to buy 16" wheels and LT tires for it, just to avoid the headache, and our wheels aren't in great cosmetic shape anyway. We've had two flat tires in the one year we've owned the trailer, but neither of those were due to poor tire manufacturing - one was due to a screw in the tread, the other was a blowout on a tire that turned out to be 8 years old instead of the 3 we were led to believe (I hate it when the date codes are on the inside).
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-30-2012, 01:25 PM   #60
purman's Avatar
1968 28' Ambassador
I am taking my old rims and Carlisle tires off today, and putting the new 16" rims and Michelin tires on.. I had no problems with my Carlisle's and they are 7 years old with well over 10,000 + miles. There is some wear on them though. I to didn't want to have to worry about tires again either.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
