Old 07-12-2007, 12:57 PM   #43
1984 31' Excella
Norfolk , Virginia
Images: 11
Maybe, just maybe I was right.
I see some tire failures in the forums here but these are not showing up as complaints on the National Highway Transportation Safety Administration's web site.
If you experience a tire failure report it. We are paying these people to investigate these things.
Go to the NHTSA website:
IVOQ - File a Complaint
And report the failure. Help us all.
Beginner
Beginner is offline   Reply With Quote
Old 07-12-2007, 01:26 PM   #44
RossFam05BH's Avatar
2005 30' Safari
Pfafftown , North Carolina
Originally Posted by Beginner
Who did you talk to in the NHTSA. I still have the ST tires that failed on me.
I would be happy to donate them to the cause.
Beginner
Hi Beginner,
I spoke with a data entry specialist at NHTSA who said I would get a call within a couple of weeks from an investigator. I will update when I hear back from NHTSA. The data entry person has already called back once and requested more information. Are your tires still on rims and inflated? I think that our situation is unique in that I have two separated Marathons still on rims and inflated. I'm sure that if we now drove another 10 miles they would destruct. A shredded tire is probably not very useful because how could the investigator tell whether the tire separated and shredded or the tire was first punctured with a nail, deflated, and flew apart? I don't think a tire manufacturer should be responsible for tires destroyed by foreign object punctures. But tire belt separation, as in our case, is a totally different animal.
Paul
2005 30' Bunkhouse "Nedapedalua"
2002 Ford Excursion 7.3L Diesel 2WD
WBCCI #5182
AIR # 6050
RossFam05BH is offline   Reply With Quote
Old 07-12-2007, 01:31 PM   #45
1984 31' Excella
Norfolk , Virginia
Images: 11
Tread Seperation
I will call tomorrow as it is late today.
One tire is off the rim. It did not shread but the steel belt is hanging out between two of the tread lugs. Other than that and the fact that it will not hold air, its looks like an ok tire.
The other one is mounted, I lowered the air pressure in it incase it decided to let go.
Beginner
Old 07-12-2007, 01:34 PM   #46
Blu_Hwy_Lady's Avatar
1972 23' Safari
Placitas , New Mexico
I'd like to see this a permanent thread
that is always floating in the main list because it's so important. This is not only about saving property, it's about saving lives. A blow-out on a single axle is a much more dangerous scenario than on a double axle. Plus, if you follow the links I provided you see that putting Goodyears on your TV could put you at risk as well. And, for those with MoHos there's issues with those tires too. As for the NTSB...another useless agency probably ulitmately controlled by the corporations it should be protecting us from. I filed a complaint and heard nothing. Sadly, at some point, the only way change will happen is with a high profile tragedy or a super-ballsy lawfirm garnering lots of media publicity for a class action suit.
Airylle 1972 Safari featured for 5 nanoseconds in the movie Wild Hogs
and
Jupiter (the Golden Retriever)
Blu_Hwy_Lady is offline   Reply With Quote
Old 07-12-2007, 01:38 PM   #47
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by peegreen
Are you doing anything with the spare?
At the moment I will keep one of the 15 in. tires with an original wheel as a spare. I don't go any fearther on a spare than to the next tire shop. $250.00+ to hang under the trailer is a bit much.
2004 Excursion 4x4
Old 07-12-2007, 01:44 PM   #48
1976 25' Caravanner
Campton , New Hampshire
If anyone knows of an independent testing lab for tires I would like to know . I have 2 BF Goodrich Commercial TA tires that are 18 years old . They look perfect but I don't have xray vision . According to all the Sage's , they should have been cracked, bulged , seperated , and blown apart by now .
ticki2 is offline   Reply With Quote
Old 07-12-2007, 02:16 PM   #49
2005 30' Safari
Beginner
Hi Beginner,
Just so you know, I did not call the NHSTA until 8 pm ETZ last night. My wife was amazed that I was able to talk to a government bureaucrat so late in the evening. I put the bad tires back on the trailer so I could lower the jack. I've already heard from Sam's club , and our order of 4 Michelins have already arrived; now we are just waiting for the wheels to arrive by UPS. In the back of my mind I waiting to hear an explosion coming from the direction of the trailer. I'm scared/chicken to walk by the trailer with that tire ballooned to such a degree. But I don't want to mess with the pressure until I talk with the NHTSA investigator. I hope I've made the right decision?
Paul
WBCCI #5182
AIR # 6050
Old 07-12-2007, 03:09 PM   #50
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by RossFam05BH
Hi Beginner,
Paul
Paul a minor question. You are getting new tires from Sam's and it sounds like you are taking the trailer there to get them mounted. I heard that Sam's will not mount any tire unless the vehicle is inside the facility. I figured if I used them for tires, I'd have to pull the wheels and drop them off for them to do.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-12-2007, 08:42 PM   #51
2005 30' Safari
Hi Jcanavera,
I will be taking the rims, sans trailer, to Sam's. The trailer will stay at home waiting for the new tires. I've had problems with warehouse clubs doing a good job in the past. For example, a couple years ago I took our Honda Odyssey minivan to Costco for new tires. The next day we took the van to the mountains of Western North Carolina for a day trip. Coming back down the hill we experienced teeth rattling vibration while applying the brakes. Come to find out that the tire techs tightened the lug nuts to around 200 ft./lbs. and warped the rotors. Consequently, I do the important stuff on our vechicles and trailers, like torqueing the lug nuts to spec, myself.
Paul
WBCCI #5182
AIR # 6050
Old 07-12-2007, 10:51 PM   #52
jcanavera's Avatar
Fenton , Missouri
Images: 143
Hi Jcanavera,
Paul
I know our local Sam's is doing a pretty good job. They state what they will torque the lugs to. I watch them use a torque wrench to hit the proper torque. Then another tech goes back and does a double check. I like that. Glad to hear you are only bringing rims. Obviously when it's tire time for me, I'll probably end up taking one wheel off of each side. Get those two done. Mount the tires back and pull the other two, again one off each side. Not the most speedy process but it will work.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-13-2007, 05:52 AM   #53
1976 25' Caravanner
My experience with Sam's is they will not do a trailer but will put tires on if you bring them the wheel . If they did they would probably jack on the axle ( ouch ) or any other convienent place ( ouch ouch ). I was waiting and watching at the door , didn't see any torque wrenches being used . Maybe your Sam's is better at that .
Old 07-13-2007, 07:19 AM   #54
HowieE's Avatar
Images: 12
A torque wrench is far to time consuming and expensive for any shop to use. At best they will use a Torque Stick with an impact wrench.
A torque stick is an extension used with an impact wrench that limits the force the wrench can tranmit to the lug nut. These sticks are calibrated to different torques and color coded. I do not know the code off hand so i will not suggest one. If you see a tech using an impact wrench without and extension you can assume he is doing it wrong.
For my new wheels I will buy and carry my own torque stick for use at home and if needed on the road.
2004 Excursion 4x4
Old 07-13-2007, 07:28 AM   #55
jcanavera's Avatar
Fenton , Missouri
Images: 143
Interesting. I figured if they did this at mine, they did it at all. They even have a spot on the receipt that they write in what they torqued to and two techs initial it has been checked. They do use actual torque wrenches. I've seen them use wrenches and truly two different guys do the check. Wish more tire dealers were like this.
Also a few other tidbits if you didn't know this. They also fix flats for free for members (even if you didn't buy the tire from them). If you didn't buy your tires from them, they will rotate and balance your tires for a flat $15. A nice perk.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-13-2007, 08:38 AM   #56
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
FWIW, I carry my torque wrench with me on every trip.
