Old 11-02-2010, 12:06 PM   #29
dznf0g's Avatar
Oswego , Illinois
Jack,
What is the load on your axles, loaded and ready to go? I thought a 30 slide was about 900 lbs heavier than a non-slide overall.
Old 11-02-2010, 12:06 PM   #30
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Originally Posted by jcanavera View Post
I would concur with 2air that running E's rather than D's or C's because they are stronger is not the real reasons why you should go to E's. I went to E's due to the weight of my heavy slide out and I felt that the reserve capacity I get (I think it was approx 300 lbs or so per tire @ 80 psi) was worthwhile. If it wasn't for that fact I'd still be using D's.
I did pick Maxxis over other brands due to the nylon cap that wraps the belts and is distinctive in Maxxis in that it minimizes belt squirm and its resultant heat generation. It's a concept used in high speed tires produced for Europe where speed limits are much higher.
So far we finished year 3 of service with no issues. My Canadian built Marathon's almost lasted four with one tire throwing a chunk of thread after 3 years and 10 months of service. End of next year will be a decision point for me as to either replace the Maxxis set for 2012 or go one last season and get 5 years out of them. We will see.
Jack
When I tell folks how much these S/O's weigh they are in total disbelief... They say...how can an Airstream weight that much? There is an ad showing a guy towing one with a bicycle..
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 11-02-2010, 12:14 PM   #31
dznf0g's Avatar
Oswego , Illinois
AND, just what load rating and belt material are those bicycle tires and at what pressure?
Old 11-02-2010, 12:17 PM   #32
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
When I have compared some ST and LT tires and various load ranges one of things I look at is tread depth. So far as I can see tread ranges from 9/32 to 17 or 18/32. The Load Range E tires generally have more tread depth than C and D tires. This may provide a little more cushioning, but mainly it provides longer wear.
It also, in the case of LT mud and snow tires, means better performance in bad weather. Given that towing in snow is not enjoyable, using a snow tire adds some safety. You can't, so far as I know, get an ST tire with mud and snow tread.
These are 2 factors in choosing a tire.
Another factor is manufacturer. Some make better tires than others and some make some good tires and some bad ones. Checking ratings is helpful, but not always. Personal experience, while anecdotal, can be helpful—for more than 40 years I have almost always chosen on brand and had excellent performance and wear—better over the years and better than other brands I have bought or were OEM tires.
So, I knew what brand I wanted. I knew I wanted a mud and snow tire. I knew there are lots of reports—all anecdotal and a little (18,000 miles) experience—stating ST tires are bad tires, but little else to go on. There are also reports ST tires are fine. Some people who appear to understand the hazards of underpressure and otherwise treat their tires well, have had tread separation and blowouts as well as excessive wear.
I was probably moved along by my OEM wheels looking bad—clear coat coming off in splotches and the fact I was going to JC soon anyway.
I was also looking for a tire that would last 5 years with the amount of towing I do—I estimate 60,000 to 75,000 miles in that period of time. With 5 tires on nice wheels, rotated regularly, a tire rated at 60,000 miles means almost 75,000 miles of travel.
I also considered whether differences in sidewalls between ST and LT tires was an important factor. So far as I could tell, unless you are consistently backing at severe angles, it did not, and if it did, that was something I could control. If LT's perform better at highway speeds, that was a definite plus. That's another safety issue.
Some tires ride better than others. There are benefits to firmer or softer. Firmer could mean less sway, softer could mean less trailer trauma. People argue about this all the time and I cannot determine what is correct in the sense that differences in many cases may not be significant. It did seem to me a commercial truck tire was too firm. It was important to me that Michelin aims to make better riding tires—my experience is that, but it is based on a small sample. That experience includes Goodrich Load Range C OEM tires on my truck compared to the Michelin Load Range E tires I replaced them with—the difference in ride was significant. I don't know how the trailer rode on the Marathons or the Michelin tires I replaced them with, but I assume it's a better ride.
The Load Range E tires do not necessarily have more plies, but should be stronger. That seems like a good thing, but may be conventional wisdom.
While ST tires are not speed rated, LT's are. If the ST's were speed rated, many people assume it's 65 mph, or 75 if you add more air. This is based on assumptions and some statements on the Goodyear website that lead to more assumptions. But there is no use, so far as I know, of the government specs for speed rating. If the assumptions are true, a much higher speed rated tire, is a good thing.
Weighing all these factors, on almost all of them Michelin LTX was the winner. On fewer factors, it was a tie or I could not tell. The selection was a compromise because the evidence is never conclusive when it comes to trailer tires. The LTX A/T 2 was overkill—longer wear, more money, might have a lot of tread at 5 years.
This was a decision I agonized over, also thinking about the substantial amount of money involved.
I had no problems with the Marathons in 18,000 miles except they regularly lost air. Was it the valve stems? I replaced the original rubber ones with metal ones—but all 4 tires lost air before and after. The metal ones had seals on the outside and inside of the wheel (some don't), so it's unlikely the stems were the problem. I find it hard to believe it seeps through the rubber. Some claim nitrogen is a larger molecule than oxygen and oxygen leaks, nitrogen doesn't. But air has a lot of nitrogen in it and if you keep adding air, it would seem you have a larger and larger percentage of nitrogen, but the leaks stay the same. Was it the wheel? Maybe. Since I changed tires and wheels, and the wheels are a different brand, I have no basis to compare, but do know I don't lose air anymore.
I have had one leaking Michelin (trailer) and one flat (truck) this summer on the road to and in Alaska. The leak was caused by a screw (it sealed pretty well for a week and thousands of miles) and half a tire chain link caused a flat. I could blame the tires because a deeper tread does pick up things, primarily gravel. But when I examined the tires, I couldn't see the spaces between the tread blocks caused the problems—it's just fate and the roads you drive on.
I also know we both feel better. And a pretty worn Michelin tire performs just about as well as a new one—we've experienced that over and over.
Like dzn', I'd like more data and fewer war stories, but there doesn't seem to be much else. A lot of the "data" is largely customer reviews or Consumer Reports and I don't see the CR data to be that good. There are also manufacturer specifications which are data, but don't always tell me what I want to know.
As for heat, a thicker Load Range E tire may retain more heat and consequently may be built to resist it. I check pressure frequently and can't tell whether there is more pressure build up with the LT's than I had with the ST's. I don't know what causes a higher speed rating, but I imagine heat is part of it, and if so, a higher speed rating (LT's) may mean less heat. Pressure should be directly related to heat, probably or maybe, so a Load Range E tire, rated to 80 psi maximum, should build up less heat than a D tire with a 65 psi maximum. I don't know if my conclusions about heat are nonsense or a good guess.
There are a lot of variables and a lot of poor data, so tire selections leave plenty of room for opinions and lengthy, inconclusive threads.
Gene
Old 11-02-2010, 01:54 PM   #33
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by dznf0g View Post
Jack,
Typical load without water is around 8,600 lbs. My axles are rated at 9,100 so when I load in 60 gallons of fresh water (like we do for the Moraine View rally), I'm pretty close to max axle load. The newer slide outs were load rated for just over 10,000 lbs. The center bath units like mine only have a half closet (single door). So I really don't have much more room to stash any more cargo. The side bath slide outs have the double door closet which gives you a lot more room for stuff.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-02-2010, 02:00 PM   #34
dznf0g's Avatar
Oswego , Illinois
Jack
That's about what I thought, as I am at 7640 w/o slide. I don't run with much water in the tank tho. Just enough to water the dog, wash up, and use the rest room.
So why did you feel the E's would benefit you? D's take you to 10,160 lbs. at 65psi. E's give you another 1200 lbs. at 80 PSI. Are you running at 80 PSI or 65 PSI with your E's. Sorry, but your prior post confuses me.
Old 11-02-2010, 02:09 PM   #35
jcanavera's Avatar
Fenton , Missouri
Images: 143
Gene
While I'll never know the reason why my Marathon peeled off a chunk of tread, I know it wasn't due to a lack of maintenance to air pressure. I was always a fanatic regarding checking tires before I pulled out and I know those tires were 65 psi cold.
I do think one additional factor you have to be cognitive of is the speed at which you tow. The faster you tow the more the tire has to flex. That in itself is why you have to understand that there is a point in speed where the tire and wheel cannot dissipate heat quickly enough to prevent the belts from separating thus causing more heat and eventual tire failure. Throw in under inflation to the mix, and you have a recipe for early tire failure.
The question becomes how hot does the tire have to get to cause failure? Obviously high speed towing in very hot conditions is rough on the tire. At a tire safety seminar that I went to sponsored by RVSelf, they talked a lot about speed being a large contributor to tire failure. Once the belts start to squirm in the early stages of separation, you are on the road for an eventual failure. It's just a matter of time at that point.
I've often thought of getting each wheel off the ground prior to a tow and doing a test spin to see if I see any variation in the tire dimensions. That might give you a heads up in catching belt slip prior to the point of failure.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-02-2010, 02:11 PM   #36
_
Originally Posted by mwells4654 View Post
... I think I will stay with Dz and now try to figure out which is the best tire for the $$$$$. I am gong to install a TPMS with the external sensors (metal valve stems). I think the "being able to change out the battery myself" instead of the internal sensor is my choice. Also, I can move them from TV to TV and TT to TT without going to the tire shop.
mwells'
i am not making any specific tire recommendation, we each must reach our own rollin' rubber nirvana...
but this thread (starting around post #20) may offer you some insight
http://www.airforums.com/forums/f438...f-c-64182.html
being able to use the external tpms on multiple vehicles is nice,
as is being able to monitor spare tires or anything else with a shrader valve stem.
Originally Posted by SteveH View Post
,,,TowMaster ST tires also have this nylon belt...
the GYMs also have this reinforced nylon belt (for the last 4 years)
the maxxis have a nylon CAP that extends from bead to bead, not a belt.
the cap IS important on low profile high performance tires (z, w, or y rated) but i doubt it does much on a tall, ST tire.
_________
this thread is about ST tires primarily.
there is no difference in tread depth for ST tires ranging from C 2 E ratings (they are all 9-10/32nds)
_________
...I assume you're running 65 PSI on your LRDs? Marathons, I seem to recall from some other post?
Have you observed and can you share your observations relative to "normal" temp rises in varying conditions? (ie: differing regional climates, sunny side differentials, mountains and long downhill runs, brake heating effect etc?
i did run 65 psi in the Dz, now using Ez they are cold inflated to 70 psi.
most so the info is here (~posts #90-110)
http://www.airforums.com/forums/f438...ons-27999.html
the temp data over a wide range of conditions has been posted in many threads...
basically (tire internal air temps/not rubber temps) ..
-sunny side runs 10-20 degrees higher, this includes while PARKED/cold or towing.
-middle axle tires run 2-3 degrees higher than 1st or 3rd axle
-with disc brakes there has been essentially NO difference in tire temps while rolling/braking...
the vented rotors dissipate heat better than drums.
-after PARKING tire temps climb ~5 degrees after prolonged braking.
-when air temps are 60-85 degrees the tires typically run at 75-95 degrees (~ambient +10-15)
-when air temps (and roadway temps) approach 95-100, the tires run 110-130 depending on shade.
all the trailer data is compared to the TRUCK tire data...
-the load range E, LT tires on the truck (inflated to 75psi) are typically 10-30 degrees HOTTER than the trailer tires...
(i am using the same brand pressure/temp sensors of both vehicles)
i have no idea what the critical temp is for any of these tires (air or rubber temps)
but the truck tires are almost always 20-30 degrees warmer than the trailer tires.
most of the temp observations are while towing at 65-75 mph.
i have stopped using the laser surface temp gizmo now.
cheers
2air'
Old 11-02-2010, 02:20 PM   #37
jcanavera's Avatar
Fenton , Missouri
Images: 143
I do run at 80 psi and I just wanted a larger threshold of margin. At full load I'm at 90% capacity with the D rated tires. With the E's I'm just over 80%. No real scientific theory at this point. I'm more of a believer attempting to give myself a 20% margin. Maybe its not defensible but there is a matter of peace of mind.....and when I get out on those trips where air temps are in the high 90's and I'm highly loaded, it gives me a confidence level that isn't there otherwise.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-02-2010, 02:24 PM   #38
dznf0g's Avatar
Oswego , Illinois
Thanks, 2Air, I'm going to print that info out and use it as comparison while "playing" with pressures and Ds vs. Es.
I have asked several tire industry "experts" what the critical tire temp is for danger of delamination, etc. No one seems to know, or will tell.
Old 11-02-2010, 02:44 PM   #39
dznf0g's Avatar
Oswego , Illinois
2air,
I read through the linked post. Couple of questions After all those miles:
1) Did you notice any issues with running Ds at 65 PSI (BTW what it your loaded axle weight)? Indications of rough ride?
2) Why did you decide on 70 PSI with Es, as opposed to 65, 75, or 80?
Old 11-02-2010, 03:16 PM   #40
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Jack
That's the same line of thought that is making me think I will feel more comfortable with E rated tired on my Classic 30 - just the same as I am happier towing well within the max tow rating of my truck, I will feel better with a greater capacity margin on my tires.
Don't know for sure that the logic holds water, but it feels right!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-02-2010, 05:33 PM   #41
_
no problems running at 65 psi.
the D rated tires were inflated to 70 psi if/when the trailer was placed in storage,
with the idea being to minimize flat spotting/cracking and account for any air loss while dry docked.
deciding on 70 psi for the Ez was initially arbitrary.
having weighed individual axles and contact points, each tire supports between 1600 and 2300 lbs.
typically 1800-1900 lbs per,
but there is always ONE heavy spot (fridge/closet or full holding tanks x3) in the 21-2300 lb range.
this varies by trip and cargo and with a total trailer weight ranging from 9,500 to 11,300 lbs.
so at 60 psi even the heaviest single tire/wheel load (2300) is covered (with D or E rated tires)
then at 10 psi for travel over 65 mph (per the gy guide) and that yields 70 psi.
then, using the "fiddle with them" approach i watched how inflation INCREASED while towing.
70 psi cold typically goes no higher than 72-75 when HOT/rolling.
67 psi cold typically goes no higher than 72-75 when HOT/rolling.
65 psi cold typically goes no higher than 72-75 when HOT rolling.
in other words the increased pressure observed was the the same at all 3 cold inflations,
which means the increase was the LEAST starting at 70 psi.
(haven't tried 72 or 75 or 80 as cold inflations)
i have not observed any trailer trauma from 70 psi.
again the choice was really arbitrary but the empirical data suggests it is a sensible cold inflation.
it's also a summertime starting pressure that will be fine with travel starting at sub freezing morning temps.
i don't like fiddling with inflation.
cheers
2air'
Old 11-02-2010, 06:21 PM   #42
dznf0g's Avatar
Oswego , Illinois
Logical, and at 70 PSI your within that 10% rise bogey even at the top of the range (75 PSI hot).
At 67 your OK on the low end, but not the hot end.
This is all starting to become better defined in my mind.
Goodyear Marathon Failures Surman1322 Tires 677 05-03-2011 01:48 AM
Goodyear marathon Born dates? Pappy Tires 11 05-16-2009 09:24 AM
'bumps' in sidewall - Goodyear Marathon ericwarren Tires 15 12-11-2008 09:12 PM
Goodyear Marathon Separation Steve Heywood Tires 5 09-19-2006 12:46 AM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
