10-30-2017, 02:21 AM
#41
Sag Harbor
, New York
Originally Posted by delrossa
. . . A two inch piece of a steel belt was sticking out of the inside tread side wall. I am so glad I pulled the wheels to balance them.
How many miles approx. were on these tires, and do you remember any hard impacts from pot holes, curb strikes, etc.?
Thanks for the report.
Peter
10-30-2017, 12:23 PM
#42
Ravenna
, Ohio
It is true that the internet makes a nice vehicle to spread the good, bad and ugly. After being a loyal fan of the Forum I installed a TPMS after buying a used 2013 28 FC. I believe the piece of mind is priceless.
I have had no trouble with the Marathons but with the tires approaching 5 year mark I had already decided to put the Goodyear Endurance tires on when I change the tires.
I was readying to put the Airstream away and was doing some maintenance items. One item was to rebalance the tires. I balanced the first one fine. When I pulled the second wheel off I got a surprise. A two inch piece of a steel belt was sticking out of the inside tread side wall. I am so glad I pulled the wheels to balance them.
Glad you lucked out. A belt separation (what I suspect is what you have) does not happen overnight. In many cases it takes many hundreds or even thousand miles to "break-out"
Have you reviewed THIS post?
You migh also check my blog post on How to Properly Inspect trailer tires with a "Free Spin" inspection (video included)
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
10-30-2017, 06:09 PM
#43
2013 28' Flying Cloud
Penn Yan
, New York
Marathons
I bought the Airstream in April. The previous owner thought it had approximately 5k miles on it. The tires looked like they had that many miles.
I think the tires now have about 10k miles. I had the wheels off in May to change the valve stems to heavy duty for installation of my TPMS.
The tires were fine then. I don’t recall hitting any pot holes. There will always be rough roads but don’t remember anything significant.
No curbs were hit.
10-30-2017, 06:31 PM
#44
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
catching up with GYM thread...
We have 9K miles on our 2017, 28' FC, over the last 5 months. I check the stock GYM's religiously for air pressure, damage, and wear. I notice the tread wear now starting to show this trip to Alumalina...not liking the excessive wear after only 9K miles. I am moving to Michelin's when I get back to Austin. 4 AS's in 11 years; never had an issue with Michelins. I am now starting to worry with these original equipment, GYM's! Not worth the stress...
10-31-2017, 01:52 AM
#45
2013 31' Classic
billings
, Montana
What do you expect of a tire that costs $125 VS one that costs $185.....you always get what you pay for, there are no bargains out there...the michelins will end up costing less at the end of 5 years especially if a Chinese tire damages your as,which it usually does..
11-01-2017, 03:47 PM
#46
Ravenna
, Ohio
To my knowledge, Michelin does not make ST type tires so I assume the Micheline tires will be LT type. Depending on size LT tires are rated for 10% to 20% lower load capacity than the same size ST type tires. If you are making the switch be sure you know the actual load on each tire (loads are seldom evenly split) and be sure your LT tires are rated appropriately.
