Old 04-24-2015, 05:32 PM   #99
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
And a lot more "disposable" products....
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-24-2015, 06:05 PM   #100
K.C. , Missouri
True that. But I suspect you'd agree that, as an example, the modern high strength steel alloys ( materials science ) used in production are better than ever, and the ability to CAD model the stresses ( more efficient engineering ) have made for a better more evolved product in many cases ( notice I say "many cases", not "all cases" ).
Now then....when we go to a third world country and bring peasants in from the fields to mass produce a given product line....well....we may not end up with what we hope for.
gmw photos is offline   Reply With Quote
Old 06-26-2015, 06:09 AM   #101
2016 27' Eddie Bauer
Plantersville , Texas
Update goodyear now at 100% failure rate and they don't care
The last original Goodyear tire on the trailer has now failed. The same defect as the other three. Goodyear is now 4 for 4 on my trailer after 17 months of use. This is on top of the $8,000.00 in damages to the trailer when the third tire blew out. The Goodyear store gave the same song and dance as the other three tires. No more Goodyear products for me. The pictures below show the tire failure on the 4th tire, the same thing happened on the other three.
ID:	241634   Click image for larger version
bladesmith2 is offline   Reply With Quote
Old 06-26-2015, 06:24 AM   #102
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Are these LTs or ST tires?
Silverflames is offline   Reply With Quote
Old 06-26-2015, 06:26 AM   #103
Gainesville , Florida
Marathons are original equipment ST tires.
Old 06-26-2015, 06:56 AM   #104
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Maybe it is just me or the lighting or something but what are we looking at with theses pictures? What are your inflation pressures and driving speed?
MICHAEL
Old 06-26-2015, 08:36 AM   #105
K.C. , Missouri
So the question is, what size are they ( 14" ? 15" ? ) and what are you going to replace them with ?
Not pointing any fingers, but often what we hear is folks taking one junky tire off, and simply replacing with a different brand of junky tire. One has to wonder how much of an improvement that may be ?
Old 06-27-2015, 03:21 PM   #106
Ravenna , Ohio
The pictures seem to indicate a tread and/or belt separation. Have you recorded the full DOT serial and filed a complaint for each tire with NHTSA?
I have a post on my blog Dec 24 2012 with a similar example along with the results of an autopsy. The post includes two links of actions taken by the owner.
Complaints on RV forums might make some feel better but they will not help improve the quality of the tires the RV industry buys or forces TT to use.
NHTSA needs facts and full DOT serial in quantity before they can consider taking action.
Retired tire engineer (40 years). Write a blog on RV tires.
Tireman9 is offline   Reply With Quote
Old 06-27-2015, 10:35 PM   #107
Goodyear Marathon tires 100% falure rate
The tires were on a 2014 Classic Limited, they were 15" Goodyear Marathon trailer tires. I check the pressure each morning before I pull out, I also look the tires over closely at the beginning of each day on the road. That is how I caught 3 of the failed Goodyear tires before they caused damage to the Airstream. The one that actually Blew-out looked fine that morning, air pressure was fine at 65psi. Looked fine three hours later when I stopped for Fuel, felt of all 4 tires temperature felt ok no obvious problems were visible. 60 or so more miles on down the road the tire blew-out while crossing a narrow bridge in Louisiana. I was driving 70MPH. It sounded like a shotgun going off then I saw the tread fly up in the air after it caused $8,000 in damages to the trailer. I have my tire gauge marked at 65psi so it is easy to check the pressure. Yes I drive fast I have pulled my trailer at up to 85MPH it pulls great. Airstream customer service told me they do not have a speed limit on the trailer. Yes it does burn more fuel at that speed 9.8 MPG. Yes the speed limit on some roads in Texas is 85mph. I think Goodyear should not make or sell any tires they are not going to stand behind. I now have Carlisle load range E trailer tires (also made in China), just drove from Kerrville Tx to ElPaso Tx at 80 to 85 mph both ways with no problems. I felt of the tires several times they were fine. I just purchased 16" wheels and going to change over to Michelin LT225/75R16/E tires as soon as I get the trailer out of the shop. I am concerned when it comes to the 15" trailer tires, at this point I do not trust any of them. I told the last Goodyear person I will never buy another Goodyear product and will work on others to do likewise. The Goodyear person did not care about the 4th tire I showed him, he said it was made in USA but was surprised when I pointed out the made in China label. Next he told me that the factory in China makes excellent tires. This tire is the same one that I posted a picture of previously. In my opinion that is a defective tire, it is coming apart just like the other three did. 100% failure rate in less than 2 years. My Airstream is in the shop at this time getting the damage repaired that was caused by the defective Goodyear tire.
Old 06-28-2015, 05:19 AM   #108
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Isn't a Classic very heavy? The GYMs I had on my Flying Cloud were in theory capable of 10,000# capacity on a 6000# trailer so tons of headroom. I'm not one of the tire experts here but i would think if your trailer pushes at the weight capacity boundaries, driving over Goodyear's stated 65 mph limit compounds the likelihood of a failure. The 16" Michelins you're looking at should have enough weight capacity and a higher speed limit to accommodate your style of driving. But I'd also recommend staying under 65 even with the new sneakers 😃
Good luck!
Old 06-28-2015, 05:26 AM   #109
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Goodyear Marathon Tires
Any ST tire built today has a 65 mpg speed rating. That rating is based on the tires ability to dissipate heat while rolling. So while you can keep pressures up to properly carry your trailer's load, speeds over may cause excessive heat which can will ultimately lead to failure. Keep in mind the heat build up is naturally caused by the flexing of a tire while it rolls plus air and road surface temperatures. The faster the tire rolls the more heat is generated. If you notice Airstream notes that you can tow with a tandem axle trailer on three wheels if you lose a tire, but keeping the speed down to 45 mph. One of the reasons is because a that speed rating has another component which is the load factor. According to a tire safety class that I attended, a slower turning tire can actually carry a load that is higher than its max capacity, if the speed is reduced. Less flexing means less heat. Towing with a missing tire means that the single tire is most likely carrying more that it's max capacity. If one would plot a tires capacity on a graph, you would see a downward slope as tire speeds increase. That's why if you drive fast, the LT tire is a better choice. Heat is your major issue. You generate it by speed based on flexing of the tire. You also affect the amount of flex based on inflation pressure.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-28-2015, 06:24 AM   #110
CapriRacer
CapriRacer's Avatar
I'm in the , US
OK, so now we have an explanation for the failures - too fast.
2 thoughts: It appears there are lots of folks you are not getting the word about the speed limitation on ST tires. It ought to come from a) the trailer manufacturer (unless they have done something to make it a moot point, like over-size the tires), and from b) the tire manufacturer, who ought to put the info in large letters on the sidewall - and perhaps a sticker that should be handed to the purchaser.
Also, we are talking about a fatigue type failure. These types of failures occur as a result of many miles worth of travel, followed by a sequence of events that leads to a catastrophic failure - ergo, you can years of good service, then what appears to be a sudden failure.
CapriRacer is offline   Reply With Quote
Old 06-28-2015, 07:13 AM   #111
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
"My Airstream is in the shop at this time getting the damage repaired that was caused by the defective Goodyear tire."
I would agree with CR that speed was a important factor.
Un-related defects not withstanding.
"Airstream customer service told me they do not have a speed limit on the trailer."
The speed of the trailer is limited by the rating of the tire, a constant, and common sense....a variable.
...GYM, 12 yrs, 2 sets, one nail.
Old 06-28-2015, 07:40 AM   #112
AWCHIEF's Avatar
Images: 33
Observation
Some seem proud of driving to fast for the GYMs and can not understand why they fail. Instead of blaming the product or the country of origin how about taking personal responsibility.
MICHAEL
Bad Marathon, Bad Marathon ROBERTSUNRUS Tires 45 11-01-2015 03:46 PM
GoodYear Marathon ST Tires and NHTSA 762x51 Tires 31 07-31-2013 06:59 AM
Goodyear Marathon Tires Ins. Man Tires 48 11-13-2011 06:57 AM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
