01-20-2011, 01:41 PM
#641
2005 30' Classic
Burlington
, Ontario
Originally Posted by Phoenix
Brief update to our Marathon story. One of the two Maxxis 225/75x15 LR-E tires that we put on to replace the two Marathons that failed in 2008 (I think), has a slipped belt. Luckily it was discovered by Discount Tire when installing one of the Centramatics I got from Santa (and Andy). I am now revisiting the 16-inch wheel fix. I am done with ST tires, especially GYMs.
Also, it looks like we might make the homecoming trip to the mother ship this year to get the wheel well fixed that was damaged by the GYM blowout two years ago. Does anyone know how much this might cost? Luckily it is mostly cosmetic (dents in the belly pan and about 4 inches of torn trim at the trailing edge of the wheel well); not like above).
Sprocket, I feel your pain. We spent about 6 hours stuck in the sand about half-way between Tuba City and Four Corners about two 4th of July's ago, in 105 degree heat. Good test of the new Tundra's air conditioner...
Just curious, what are the symptoms of a slipped belt? is it something eaily seen?
Hope this doesn't mean that the Maxxis are now not a good tire to buy! I've always heard pretty good things about them.
We are traveling to Tucson next month, and when we get there, I was planning to go to a Discount Tire store and have them replace my 5 year old
Marathons with Maxxis E rated tires. (same ones you have)
I am not able to find them locally and am hoping Discount would be able to get them for me within a day or two, we will be in Tucson for a couple of weeks.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
01-20-2011, 01:48 PM
#642
2005 30' Classic
Burlington
, Ontario
Odds are that the running gear is not properly balanced.
You can add Centramatic balancers to your running gear, provided that the back side of the wheel has a minimum of a 10 inch flat surface.
But, to be on the safe side, you should also check the algnment, which you can do with a ruler and a straight edge.
Andy,
Is there info someplace here on the forum as to how to check the wheel alignment with a straight edge and ruler? is it toe-in or camber or both that you check, and what sort of specs should one find?
I have one tire that seems to be wearing on the inside edge and have been wondering about aligment - if there is a problem, does it automatically mean a new axle or can the existing axle somehow be re-aligned? We are not too far from an Airstream dealer here (CanAm in London)
Thanks .............. Brian
2005 Classic 30'
01-20-2011, 01:50 PM
#643
Master of Universe
2008 25' Safari FB SE
Grand Junction
Brian,
You can call Discount now and ask them to have the tires waiting for you when you get there. I recall some posts about similar problems with Maxxis, but not anywhere as many as with Goodyear. This may reflect the fact that there are a lot more Marathons than Maxxis tires on Airstreams. The alternative is a LT tire with 16" wheels. Those of us that have gone that route usually pick Michelin LTX or Rib tires—there are lots of threads about that. This is the most expensive way to do it, but we are very happy with the change.
Gene
01-20-2011, 01:59 PM
#644
Corona
Originally Posted by Wingeezer
Andy,
Torsion axles can be realigned.
The tow in is 1/16 inch, plus or minus 1/16 inch.
The camber is 3/4 degrees positive, plus or minus 3/4 degree. The top of the tire should be further out from the frame than the bottom of the tire.
The specs should match for each wheel, namely all being the same.
Lack of proper running gear balancing, can also cause some weird tire wear.
01-20-2011, 03:45 PM
#645
2005 30' Classic
Burlington
, Ontario
Excellent info, thanks Andy I will try to check measurements.
Presume that all you can do is try to use a straight edge and ruler to make measurements in from the edge of the wheel wells.
I bought the trailer used, and don't really know how long it has taken for this wear pattern to develop.
I did however buy and install a set of centramatics from you last year. I think the wear pattern was already in evidence when I installed them.
I'll be checking alignment and if I think there may be a problem, will call our nearby AS dealer to see if they could verify and possibly fix - hopefully without new axles, although I do have a still unresolved issue as to what size axles are in my trailer. It is a 2005 and I believe they changed the axle rating mid-production.
If it does turn out thatI have the lighter axles (as my manual indicates) I wouldn't mind having the 5000# ones installed. having a bent axle might give me the incentive I would need!
Brian.
2005 Classic 30'
01-20-2011, 03:51 PM
#646
2005 30' Classic
Burlington
, Ontario
Originally Posted by CrawfordGene
Brian,
Gene
Thanks Gene,
May well go the route of 16"LT at some point, A bit reluctant for the moment as I have just installed two brand new Alcoa 15" rims!
Also, and despite all the good reports on the LT's I must admit that I still find myself thinking that they must make ST tires for a reason! I guess that's a whole other debate!
I did consider ordering the tires from Discount ahead of time - but
incorrigible pessimist that I am, I worried about what to do if for some reason, health issues or other, that we never make it to Tucson this year, even though I have made reservations!
The Discount website says they should be available at a Tucson store within 24 hours, and so since we will be there two weeks, maybe a bit more, I figured I'd go to Discount and order them the day we arrive in Tucson.
Brian
2005 Classic 30'
01-20-2011, 11:50 PM
#647
2005 19' Safari
GLENDALE
, AZ
Wingeezer, a slipped belt looks like a lump in the tread or like a small section of tread squirmed a little and got stuck out of alignment with the rest of the tire. The radial belt should be securely bonded to the body plies. However, when it starts to separate from the carcass, the tread starts to creep and gets lumpy or squiggly. As the belt continues to separate, the tread slips and peels off the tire and ends up with the other alligators alongside the highway.
We hoped that the Maxxis tires were a permanent fix, but it appears that they too are no match to the southwest desert heat. Arizona's highways are littered with alligators in the summer months. Perhaps, the Maxxis tires will last longer in cooler country.
These tires were running smoothly, and there was no indication of problems. The tire shop had to deflate the tire to get it back in the wheel well, and it had a little lump in the tread when it was deflated. After they reinflated it, I asked them to spin it to see if the lump rounded out. (The trailer had been sitting for about a month, and I had only driven it a couple of miles to the tire shop, so I thought the tire might have had a flat spot in it that would normally have run out as it warmed up.) That's when the tech noticed the slipped belt.
I am now shopping for 16-inch wheels and various Michelin LT tires to fix this problem once and for all. Luckily this isn't too expensive, because we only need two wheels and tires, one of the few advantages of having a single axle.
If I didn't think we could switch to 16-inch wheels, I would probably buy Maxxis tires again. Even with this failure, it still seems to be the best tire available. I definitely wouldn't consider most of the other brands.
We got our Maxxis tires from Discount Tire. Discount ordered them one day, the tires were delivered the next afternoon, and the following day we had them installed. There must get them from a tire distributor in Phoenix or somewhere that can deliver them overnight.
01-21-2011, 07:25 AM
#648
2005 30' Classic
Burlington
, Ontario
Wingeezer, a slipped belt looks like a lump in the tread or like a small section of tread squirmed a little and got stuck out of alignment with the rest of the tire..
Many thanks for that info. I did have a set of marathons fail on our last trailer when we were near Fort Stockton in Texas.
I felt vibration from the trailer and sopped to look and found that about 15" of tread (full width) missing from one wheel - luckily, no significant damage to the wheel well, and the tire didnt appear to have lost air. We managed to limp into Fort Stockton on the ruined tire and find a little one man tire shop that had tires to fit!
I changed all four because when i looked closely at the remaining three tires, I found two of them showed signs of the tread just starting to lift away from the carcass in one small spot.
Although these were Marathons, I can't really blame the tires but rather my own foolishness.
At that time, I wasn't really aware of the importance of replacing tires every five years or so. I had always thought that as long as they had tread and the sidewalls were not cracked, you were fine. These tires were probably 12 years old at least.
Hopefully we will get good performance with the Maxxis tires. If desert heat is a culprit leading to early failure that shouldn't be a big factor for us. The only time we are in the SW is during the winter. We only use the trailer for a couple of short trips in summer and usually in Canada or the NE States.
Thanks again for the info.
Brian
2005 Classic 30'
01-21-2011, 07:38 AM
#649
Contributing Member
Austin (Hays County)
Maxxis
Over the last several years, I have had 3 Maxxis E-rated slip belts. The clue is that a slipped tire looks like a bicycle tire. Instead of being flat across the tread, the tire becomes round with a bulging tread center.
In one case, I had already had a fatal puncture on another tire when I noticed the slipped belt. I kept my speed down and ran for several hundred miles across west Texas to where I could replace the tires. I watched the pressure and the temperature of the slipped belt tire. It ran a little hotter than the other tires, but not critically so.
The current Maxxis seem to be better made and my latest ones have held up well.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
01-21-2011, 08:22 AM
#650
2017 23' International
Ridgefield
ST Tires
Take a peek at this article sponsored by Good Sam.....a disturbing survey....perhaps not enough numbers to make a significant statistical difference, but.............
RV tire survey stirs failure cause questions
01-21-2011, 09:21 AM
#651
Master of Universe
Grand Junction
Zig', good link, though the link in the link for the complete survey does not seem to exist any longer. I would have liked to have seen more detailed results.
On these threads about tires it has been said it appears that more tires fail than actually do because it's anecdotal, thus people with no problems, don't post. The survey shows a lot of RV tires are bad and trailer tires worst of all. It isn't some isolated people who post over and over again giving the impression of a problem—a survey of 17,000 is a fair sample. The link is worth reading.
Gene
01-21-2011, 10:16 AM
#652
_
while interesting and more worthy of reading than many of the posts IN this thread...
i have read the original UNclipped survey and have a copy of the piece somewhere.
as i recall "problems" was very vaguely defined...
flats (from all causes) was included as was low pressure, wear, balance and basically everything else that may happen 2 a tire...
given that, the "i had problems" response rate should be much much higher, like 90-100%.
picking up a nail, 2-5 psi loss in a tire not used for seasons, tread wear, alignment/balance and so on...
are normal things and should be EXPECTED at some frequency by rv users...
'early years' wasn't based on tire age, but rather when the rv was purchased...
in other words reports from folks buying a used rv,
having problems in the first year or 2 or 10,000 miles of use were included.
and no accounting was made for valve stems that may be the cause of many issues and still are...
again the nature of the survey and how it was distributed encouraged folks with "negatives" to reply.
the 'maintenance' questions also made it appear that daily monitoring was widely used...
and simply "looking" at the tires was part of this.
there were a dozen other 'gotchas' in the survey/results consistent with it's value IN the costco flyer.
_________
the fact that costco sells tires and the monthly mag (while often good stuff) promotes the products they sell also matters.
i vaguely remember the same issue had a special sale on tire monitoring systems that costco was hawking.
or maybe this is some OTHER costco survey, i've not seen.
________
this is an rv forum.
and there are folks here who've reported the same tire issue dozens (100s) of times...
just as there are folks reporting one good result multiple times.
IF you wanna read about LT or performance tire failures or P metric tire issues...
the enthusiast forums for trucks and cars are replete with threads and stories on passenger and truck tire failures.
this is no defense of st tires or any other tire style,
but it is useful to understand that cyber space is a quagmire.
cheers
2air'
01-21-2011, 10:49 AM
#653
2005 30' Classic
Burlington
, Ontario
2air'
Sometimes I wonder when I read all the negative reports about trailer tires is how often we are the cause of the problem rather than the tire manufacturer.
I'm sure that I read the results of one RV survey where many RV's were checked for tire pressure and a large proportion - I forget the figures, but it was substantial - were found to have tires that were running very much under-inflated.
Almost every tire company website I have perused has claimed under inflation as a major cause of overheating and subsequent failure.
There's no doubt that for many years of my own RV'ing experience I did not give tire pressures much of a thought. I suppoe that "Doesn't look flat, must be good" was my guideline!
Now, due mainly to all I have learned through forums such as this one,
I check pressures with a gauge before every trip, use a TPMS on the road, and as well, do a walk around every time we stop the trailer to examine every tire, as well as the trailer itself, hitch, and TV generally.
No guarantee I won't still have problems I'm sure, but I'm sure it helps. I will also replace trailer tires irrespective of wear every five years from here on.
Brian.
2005 Classic 30'
01-21-2011, 01:10 PM
#654
1963 24' Tradewind
Anderson / Sun City
, Indiana / Arizona
I read advice about switching to 16" LT tires for better tire safety and longevity. However, I have a 1963 Tradewind and I can barely get 15" ST radials in the wheel wells as it is. I have to let the air out of the tire and then install the wheel & tire on the hub before re-inflating. Once installed thereis plenty of clearance.
Could I even get a 16" LT wheel and tire to fit in the wheel well?
Mike Brumback
WBCCI #1200
01-21-2011, 07:37 PM
#655
Ottawa
, ON
That's a gorgeous TT, Mike. Have you tested your axle to make sure it's OK?
I'm no expert, especially with the '60s models, but either your model has more coverage of the wheel/tire assembly, or you need a new axle, from what I can see in your registry photos.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
01-21-2011, 08:09 PM
#656
2007 25' International CCD FB
San Antonio
Just felt I needed to add to this post.
During a recent rally this past summer, a friend pointed out that I had some tread separation on my 3 of my GYMs, and then after researching and reading all of the posts on this forum, I went to Discount Tire in San Antonio, and bought 4 new BF Goodrich Commercial 16" LTs with new wheels.
To date, I probably have 6000 miles on them, and my comfort level has increased exponentially. I have always checked tire inflation before and during trips, and was totally blown away when he pointed out that the condition of the tires were dangerous.
I can only assume that the RV companies put ST tires on because of liability issues. They can't put a Light Truck tire on a RV.
I run pressure and heat monitors on the tires, and they are performing great. Also, I have noticed that I do not have any more rivits popping or any other problems related to vibration.
Also, I should add that we are currently on a trip, and driving in New Mexico where the speed limit is 75 on the interstates. We have been cruising at that speed and sometimes above, and there are absolutely no worries.
ST tires are rated at only 65 mph.
To me this decision was a no brainer. Hope this helps.
Barry
01-21-2011, 08:36 PM
#657
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens
, Georgia
I only use bias ply tires. 10 ply. Never had any problems. I put them on all my airstreams. With all the Good year. When the double axle tires skid when turning the belts breakdown. Bias does not have belts to break!
Athens GA
01-21-2011, 10:39 PM
#658
1963 24' Tradewind
Anderson / Sun City
, Indiana / Arizona
Yes,my Tradewind has a brand new Henschen axle installed by Airstream in Jackson Center. This is the same height and wheel coverage as the day she rolled out of the factory brand new. It is the original 22 degree starting angle rather than the 35 degree angle most people have modified their Airstreams to.
It is a misconception that this era Airstream showed more tire sidewall when new. I have hundreds of pictures taken in the 1950's & 60's and this is the proper height for this vintage Airstream.
Mike Brumback
WBCCI #1200
01-22-2011, 12:31 AM
#659
1981 20' International
Shasta Lake City
I want 35 degrees....will replace soon
01-22-2011, 01:13 AM
#660
2005 19' Safari
GLENDALE
, AZ
Marathon tire failures are widespread. When searching through a boating forum that I also follow, I found that boaters also have problems with Marathons. In fact, you could just replace the words "Airstream" and "wheel well" with "trailer" and "fender", and you couldn't tell the difference in the rhetoric. (Evidently, blowouts rip the entire fender off of boat trailers.)
There was even one boater that had 5 out of 6 Marathons fail in one outing. One tire blew and took out the other two on that side, and the fender. A check of the other side showed that the belts had slipped on two of those. Sound familiar?
Also, it looks like that RV survey was done by Sam's Club, not Costco; though this is probably a moot point, since both advertise in this manner.
It's really hard to get Goodyear to admit there is a design problem, when there isn't enough of the tire left to analyze. Everyone always blames the driver for driving on underinflated tires. There are a lot of us in the southwest desert areas that know the dangers of underinflation and check our tires religiously. (Remember the Ford Exploder tire problems.) And, we still had Marathon failures.
I think the simple fact is that you get what you pay for. Marathons are around $100 and Michelin XPS Ribs (all-steel) are $275. Which do you think lasts longer, without blowouts? I am just upset that our Bambi didn't come with 16-inch wheels so that we had the option to spend a little more for better tires. I guess, of course, we can just buy whatever we want; but I feel that a travel trailer like an Airstream, for which we paid a premium, should have come with a better set-up on tires. We shouldn't have to constantly worry about blowouts and repairs to wheel wells and whatever gets torn off by alligators.
Uh, oh... sorry, got to ranting...
Anyway, I hope to have this era behind me soon with new 16-inch wheels and XPS Ribs. I weighed replacing two dry-rotted XPS Ribs that still have a lot of tread on them, versus sitting on the side of the road for six hours on the Indian Reservation in northern Arizona waiting for a tow truck to come from either Colorado or New Mexico to fix a blowout and pull us out of the Lake Powell-like sand on the shoulder. After thinking about the long wait and the $400+ towing bill, that couple of hundred dollars for 16-inch wheels and tires is a bargain, with peace of mind.
(Sorry, again, about the rant...)
