09-14-2008, 06:35 PM
#521
_
Originally Posted by SteveH
Discount Tire shows the Goodyear Marathon to have an "R" speed rating, which is up to 106 MPH....
Tirerack says the country of origin for the Marathons is China.
the speed rating linked is not correct,
someone at d/c tire is confused or mis-keyed this or assumes the R on the side wall indicates something other than Radial tire...
ST tires do NOT receive a passenger tire utog OR speed rating...
ST tires are LOAD RATED/ tested at 65 mph, that is NOT a speed rating,
which is a large part of the continual CONFUSION offered here, OVER and OVER and OVER.
by the same players.
How to Read Speed Rating, Load Index & Service Descriptions
UTQG Standards
Air Pressure/Load Adjustment for High Speed Driving
many/most gyms are now made in china, especially those destined 4 the usa.
but the factory origin code is specific and stamped on EVERY tire.
cheers
2air'
09-14-2008, 07:11 PM
#522
Common Sense
2air,
I'm not trying to be argumentative, but even the info from the pages you listed is confusing....from the OTQG Standards:
Every tire sold in the United States must be capable of earning a "C" rating which indicates the ability to withstand 85 mph speeds. While there are numerous detail differences, this laboratory test is similar in nature to those used to confirm a tire's speed ratings.
Now granted, they are mostly talking about passenger car tires on the page, but it specifically says "Every tire sold in the United States....", not every passenger car tire.
Regards,
Steve
09-14-2008, 07:14 PM
#523
Aluminut
2004 25' Safari
I dunno... so far liking my Maxxis "D" rated tires with the nylon caps.
Oh, and no pure nitrogen for me...most of what is in the atmosphere that we breathe is mostly made of nitrogen (somewhere about 8 out of 10 atoms). Filtering out the water is the key when putting regular air from the air hose to top off yer tires....
Most of what folks around here that "sell" tires filled with pure nitrogen or nitrogen filling services, are based on pure nitrogen's larger molecules than that mixed with 2 atoms of oxygen. Oxygen molecules from what I understand are smaller and, tires, being somewhat porous, allows these smaller molecules to escape over time far easier than the larger nitrogen molecules, but heck, what the hell do I know, I flunked math, algebra, and barley even passed biology and NEVER took chemistry, but those out there who have and know more than what I've read on the subject could easily say if I'm even remotely right or clearly wrong.
09-14-2008, 07:15 PM
#524
holland
, Michigan
I took off the canadian made marathons dated 04 and put on chinese made marathons and left friday for the west coast. They made it to colorado and for some reason the trailer seems to handle better?? Anyway, fingers crossed, I checked every stop and they were running very cool and no problems. Could it be these things are better? I notice they have a scuff guard on the side wall. Anyway, still paranoid.
09-14-2008, 07:34 PM
#525
_
twink'
the 'small molecules leak theory is a real thing turned, applied-myth regarding tires, but mrs. malaprop would be proud...
...I'm not trying to be argumentative, but even the info from the pages you listed is confusing....from the OTQG Standards...
steve...
not to worry, your posting isn't argumentative at all...
and there's nothing bad about a little online argument, so long as it's not made personal...
and u don't reach INTO the 'puter screen...
i agree the paragraph is confusing IF you apply it to every tire made,
(besides that "C" is actually a temperature rating (the temps that are typical at 85 mph) not a speed ratingl
but they are referencing UTOG rated tires only, and ST tires aren't utog rated...
NONE of the passenger car OR light truck tire standards apply to ST tires...
the speed ratings and UTOG ratings ONLY apply to passenger tires, even LT tires dance to a different tune.
trailer, utility, motor cycle, atv, wheelchair tires and so on aren't required to COMPLY with or USE those standards...
that alone may fuel much of the "st tires are inferior" thinking....
true or not.
perhaps the most import notation is this...
"Unfortunately for all of the money spent to test, brand and label the tires sold in the United States,
the Uniform Tire Quality Grade Standards have not fully met their original goal of clearly informing consumers
about the capabilities of their tires. Maybe it's because tires are so complex and their uses can be so varied,
that the grades don't always reflect their actual performance in real world use."
cheers
2air'
09-14-2008, 08:37 PM
#526
2004 30' Classic Slideout
Fenton
, Missouri
Originally Posted by 2airishuman
yes they do.
and the speed rating system for passenger car tires,
has NO relationship to how ST tires are labeled, tested or rated.
cheers
2air'
Understand...but take a passenger tire and exceed the speed rating for a length of time and you stand a higher chance of tire failure. Exceeding ratings for a tire, no matter on how the tire standard is set does preclude the tire to have a shortened life. That may manifest itself in premature wear out, or in worse case a failure of the tire to maintain its structural integrity.
Bottom line you run an ST tire in excess of the 65 mph that is stamped on the rating at the max inflation pressure, you lose load rating capacity...that's a fact. Dependent upon how much capacity is lost as you exceed 65 mph, and the actual load that the tire is carrying, the potential looms for an overload situation which we can all agree is a tire killer.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
09-14-2008, 08:38 PM
#527
Common Sense
Found this on the Discount Tire site about trailer tires
THE RIGHT TIRES
When purchasing or replacing trailer tires, look for the ST (Special Trailer) designation. Avoid using a passenger car (P) tire or light truck (LT) tires, as these do not have stiff, beefy sidewalls and other structural components to provide stability and handle the stress and dynamics imposed by a trailered load.
Modern ST tires feature materials and construction to meet the higher load requirements and unique demands of trailering.
"The major difference is reflected in the polyester cords used in ST tires," said Tim Fry, senior development engineer with Goodyear Tire & Rubber Co. in Akron, Ohio. "These cords are bigger than they would be for a comparable P or LT tire. Typically, the steel wire also has a larger diameter or a greater tensile strength to meet the additional load requirements.
"Because of the heavier construction for an equal volume of air space, an ST tire is designed to carry more load (than a P or LT)," says Fry.
What's more, the ratings on ST tires are standardized for axle ratings on trailers, according to Leo Garbarino, regional sales director for Carlisle Tire and Wheel Co. of Aiken, South Carolina. "If you have a 5000-pound axle, use an ST tire rated at 2540 pounds, so that two tires will meet the 5000 pound requirement in weight-carrying capacity," said Garbarino. "A P or LT tire is not rated the same way, so determining the load capacity can be difficult."
If the combined tire ratings do not meet the axle ratings, the tires will eventually fail-perhaps in a catastrophic blowout.
Bias ply trailer tires normally have two belts of steel in the tread area and extra sidewall cords to add stiffness. Most tires also include nylon belts to help resist separation caused by overloading, underinflation or excessive speed.
FAILURE ANALYSIS
Even properly rated tires can fail. The No. 1 cause is underinflation. This is particularly true of an ST tire, which relies on proper inflation to live up to its load rating. Without enough air pressure, an ST sidewall will not function as designed, and will eventually fail, usually in the form of a sidewall blowout. Tires lose approximately 1 psi per month as well as 1 psi for every 10-degree drop in temperature.
Overinflation is also hard on a tire, causing irregular wear and possibly a blowout. Yet, you can't always spot improper inflation with a visual inspection, so check your tires frequently with an accurate air-pressure gauge.
Long-term fatigue can also weaken a trailer tire. There are a number of factors that accelerate fatigue, but heat buildup from towing at high speeds is one of the main culprits, according to Fry.
"If you trailer nonstop from Phoenix, Arizona, to Las Vegas, in 100-degree temperatures at 65 mph, you use up much of the resources of that tire, and you don't realize it," said Fry.
Fry is not talking about wearing out the tread. It is the tire's construction that is breaking down. As heat builds up, the tire's structure starts to disintegrate and weaken. Over the course of several trips, this load-carrying capacity gradually decreases, according to Fry. Incidentally, all ST tires have a maximum speed rating of 65 mph.
One key to extending tire life on a tandem- or tri-axle trailer is to ensure that the trailer is riding level, thus distributing the load equally among all the tires. If the trailer tongue sits too high, the rear tires may bear the brunt of the load: with the trailer tongue too low, the front tires may be unduly stressed.
OLD MAN TIME
Time and the elements can also weaken a tire. The structural components and bonding agents slowly break down. This is due primarily to internal air pressure forcing oxidation of the tire materials. Ultraviolet rays also attack the rubber on a tire left exposed to the sun. As a result, a 15-year-old tire that was rarely used may look virtually new, but because of the ravages of time and elements, it does not have the same strength as when it was new, according to Fry.
"As an estimate, in about three years roughly one-third of a tire's strength is gone, just because of the normal process of aging," Fry claimed. "We believe three to five years is the projected life of normal trailer tires."
Regards,
Steve
09-14-2008, 10:12 PM
#528
Naples
Thanks Steve!
Nice find! But I have to disagree with what I've seen in the 'real world'. I have lots of clients that tow very large triple axel car carrying trailers behind their $Million motor homes. They often ask me to air up the rig and trailer before they leave FL in the Spring. I always look at the tires, and I have found most, if not all of these trailer tires to be LT rated!!!! So much for Mr. Goodyear! Also, ever seen an ST tire on a semi trailer???? Talk about weight, heat and speed......... I have nothing against ST rated tires when properly used within their design parameters....those parameters just don't work for me.
I changed my 15" ST Marathons on my single axel 19CCD to 16" 227/75-16 LT tires (the same tires that I have on my Sprinter) soon after I bought the trailer. I drive the Sprinter fully loaded all the time and don't tow my Airstream at 65MPH and regularly tow in the desert heat, so I feel that the choice of LTs was proper in my case. I'm currently on my 3rd set of LT tires in the Sprinter without a single issue (112,000 miles), and expect the same great service from the LTs on the Bambi (and my tandem axel work trailer that also has LTs on it).
YMMV......and probably will!!!!
lewster
09-14-2008, 11:23 PM
#529
_
Originally Posted by jcanavera
... take a passenger tire and exceed the speed rating for a length of time and you stand a higher chance of tire failure...
well as i understand it just 10-15 minutes time running at or above the speed ratings results in tire failure, they just come apart.
they are rated to 'just short' of the failure point.
since many of us run long hours and 1000s of miles above 65 mph on the gyms, it obvious the rating system is DIFFERENT.
...Bottom line you run an ST tire in excess of the 65 mph that is stamped on the rating at the max inflation pressure, you lose load rating capacity...that's a fact...
i see it repeat often HERE but without support from any official tire maker documents...
gotta link to this somewhere?
the goodyear info on towing between 65 and 75 mph covers inflation and load issues,
but makes NO mention of 'losing' capacity other than in loads vs underinflation situations.
and i agree with lew that LT tires can work and have been proven over time on MANY trailers...
check out the big 5th wheels, race car teams and so on...
almost ALL of them on rolling above LT tires, but for how many years will the trailer last?
on triple axles streams clearance is an issue (but still doable) however i've read the NEW panamerican toy hauler has 16/LT rubber.
cheers
2air'
09-15-2008, 05:41 AM
#530
Common Sense
Ratings....
I think the speed "Ratings" must be on the conservative side. Don't think the tire manufacturers want to keep ALL the lawyers busy.
I know for a fact on our trip of 11,000+ miles this summer to Alaska and back, a great deal of the trip where possible (read on American Interstates) was done at 70-75 MPH, and we had no tire problems on our 23' Airstream. And, one of those tires had been repaired with a plug!
It was one of those punctures too close to the side of the tread for a patch to hold.
Anyway, I know for a fact these trailer tires will not immediately self distruct if driven over 65 MPH.
Regards,
Steve
09-15-2008, 06:33 AM
#531
Aluminut
2004 25' Safari
Though I don't advocate driving 75+mph towing, the posted speed limits on some interstates can be around 75mph. Shouldn't tires be rated for at least the maximum posted speed limits the tires could see? I realize that we live in the global economy and that it's a fool's paradise out there, but it just seems to me that unless you are doing something a-typical, that tires should have enough of what is needed to do at least the posted speed limits around the country.
Me, I stick to about 62mph fairly regularly. Sure I've passed at 75 once in a while, but never for extended periods of time. But let's face it, we all know the sweet spots our rigs get the best MPG....few, if any have I ever heard get the best fuel econ at 75mph. Of course if money is no object, 9 mpg can be a small price to pay to get to your destination a bit earlier.
For me, I can get about 12 mpg if I stick to 62 mph....slower, near 55 mph, I can get upward of 13 to 14.
Now don't get me wrong, I love speed like the next guy and love to get where I'm going.... when I'm not towing and driving my 1996 modified Impala SS, I can assure you with my Z rated nylon capped steam roller type tires, I go significantly above the posted speed limit. Funny thing is that I just got a "safe driver" renewal certificate from the state saying I wouldn't have to come in to renew my license.
09-15-2008, 12:27 PM
#532
_
...It was one of those punctures too close to the side of the tread for a patch to hold.
which is exactly why i suggest the rating methods are different, and don't apply as they do with p tires.
on the patch/plug issue, my understanding is that punctures near the belt edges are not to be repaired using ANY method.
the 'no repair' zone is about 5/8-3/4 inches in from tread margins...
having experienced 3-4 nails/screws and foreign objects imbedded in tires this year,
i'll soon put up pics of each and how they were handled.
cheers
2air'
09-15-2008, 01:17 PM
#533
Fenton
, Missouri
cheers
2air'
No tire manufacturer has a link to this information. I'll scan the document that I got during the RV-SELF tire safety training. It was published by Michelin and shows the degradation in load capacity of a tire as speed increases.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
09-15-2008, 02:00 PM
#534
Common Sense
cheers
2air'
Yep, I understand the "rules" about repair of radial tires, but I think my 11,000+ mile trip with the plugged tire proved that "rule" is also not cast in concrete.
Regards,
Steve
09-15-2008, 02:11 PM
#535
_
no doubt a repaired tire might go a long long time or explode in the first 5 miles of use..
and i doubt it has much to do with WHERE the hole and plug/patch are located, within reasonable limits.
but getting a shop to MAKE the repair is an issue.
having had 2 punctures (2 different tires) that were with millimeters of the same location and tiny tiny holes...
the gy shop refused to repair one (too close to the belt 'margin') and agreed to repair the other, which is now in duty without issues.
i'm fine at diy on bicycle tires, but don't plan to fix gyms at home...
cheers
2air'
09-15-2008, 03:43 PM
#536
E Pluribus Aluminus
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Land Of Enchantment
, New Mexico
Ditto what you said...
I guess, when I think of barreling down the highway towing a 9K# Daisy with all the trimmings at 75mph, my first thought is "am I rated at this speed if something happens?"... Having been made back when Ike was a president, not a hurricane, I'm probably due for some sort of tune-up or re-treading as it is...
Just don't think that with a lot of the dimwatts on the highways these days, I'm rated fast enough to react at that speed.... ... And trust that 'ol Daisy will too...
Jaxon
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
11-11-2008, 03:06 PM
#537
E Pluribus Aluminus
1967 22' Safari
2005 30' Classic
Land Of Enchantment
, New Mexico
Was just browsing Cabela's, on-line and noticed that they have Goodyear Marathons ST225 75 R 15 on sale - $99/each, if anyone is lookin'.
Cabela's -- Goodyear Marathon Radial Trailer Tire
Jaxon
11-12-2008, 07:15 AM
#538
holland
, Michigan
Just an update. In sept I pulled 4 perfectly good marathons with 04 date codes and Canada mfg and replaced with 4 new marathons and china mfg. locations. I did it because of potential age issues only. The tires performed flawless in 2 trans cont runs. Since then towed to california and back to michigan. All went perfect, but due to this thread my wife thinks I have some sort of psychological problem. I inspect the tires every time I pee. She is really worried about me. HELP???
11-12-2008, 07:51 AM
#539
2011 34' Classic
Westchester Cty.NY
, / Miami FL
tell your wife not to worry as frequent urination is common as you age.
Ricky
11-12-2008, 07:57 AM
#540
1957 22' Flying Cloud
Lone Jack
, Missouri
Tires
Wait until you get my age and you really can do some tire inspectin'. Are you supposed to inspect them at 3:00 a.m., as well?
Maybe 4 years is a little early to worry about tire age but since you replaced the tires all you have to worry about now is your wife. You must be fairly new to wifedom because you need to learn to ignore them sometimes, especially near a jewelry store around Christmas time. Just keep walking and find a restroom.
I had Marathons for 7 years on a tandem axle car trailer. No problems. My younger son's new father-in-law is a tire dealer. He sold me some Towmaster tires (see previous threads for that discussion) for the car trailer and my '57 Flying Cloud.
Towmaster is sold by an outfit called Greenball and is/was/still is some sort of branch of Goodyear. Goodyears made over a million of these for Greenball. These tires were made in China but, apparently, meet all DOT specifications and regulations for sale and use in the US. I've had them two weeks and they still hold air--that's a good start!
I don't want to rekindle the US made vs. foreign made debate. They don't make many tires in Akron anymore and that is how it is. I do remember the American made Firestone 500 that had 7 million tires recalled in 1978. Then there was the BF Goodrich tire recall in 2004 but Goodrich was bought by Michelin in 1988 and that is not an American based company. No tire is perfect and no tire is junk, in my opinion.
Here is the secret to marital bliss and please don't tell anyone:
Every night when you get home, give her a good listening to!
Larry
"Turleen", the '57 Flying Cloud
Lone Jack, MO
Pop.528
"You better learn it fast; you better learn it young"-John Fogerty
