Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 03-09-2007, 03:07 PM
  #99
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs, Illinois
Thanks John. There is a Discount Tire down the street from me a piece, I'll get in touch with them.
Get rid of these ads... register today, it's FREE
Old 03-09-2007, 03:20 PM
  #100
Al - K4GLU
Profile:  2007 20' Safari SE
Madison, South Dakota
Status: Online
Maxxis makes a "E" load range trailer tire so why in the world would you use LT? I have a 2007 20' Safari and have already removed my Marathons and replaced them with Maxxis ST225 75R15 10 ply E load range trailer tires. I had a Marathon failure on another make of trailer and friends of mine in NC had 2 Marathon failures. In all instances these were new or fairly new tires and had been pampered - pressure and tires themselves checked frequently. I still use the Marathons as spares - and I carry 2 spare tires for the trailer just in case.
Old 03-09-2007, 03:21 PM
  #101
Silvertwinkie
Aluminut
I thought using 10ply was a bad idea....not saying I know for sure, but thought I read that here.....FWIW....
Also, my Discount Tire place doesn't carry Maxxis!
Old 03-09-2007, 03:29 PM
  #102
Al - K4GLU
Status: Online
Before I put the 10 ply E load range tires on I called Airstream. The reason for my call was to find out if the aluminum rims could take the additional pressure since you can run the E up to 80 pounds - I run 70 in mine. I told the person I talked to what I was planning and he did not say it was a bad idea - but again I didn't specifically ask that question. The aluminum wheels by the way are good for up to 90 pounds pressure.
Old 03-09-2007, 03:36 PM
  #103
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County), Texas
I have 65# in my Maxxis and I do not plan to exceed that pressure. Given the weight of my trailer, I would not even need to have as much as 65#, but I was told by Discount Tire's Regional Rep that I should always run the Marathons at max pressure, especially in the Texas heat.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 03-09-2007, 08:12 PM
  #104
ljmiii
ljmiii's Avatar
Profile:  2006 16' International CCD
New York, New York
Andy (aka Inland RV) has advised against using 10ply - but I'm not sure if he is against them in general or against getting them and then inflating them up to 80 PSI (thus cracking your D rated wheels).
See post #4 in:
http://www.airforums.com/forum...tml#post258089
and also post #8 in:
http://www.airforums.com/forum...tml#post325688
enjoy,
leo
Old 03-10-2007, 05:02 AM
  #105
hiker
hiker's Avatar
Profile:  2007 25' International CCD FB
Needham, Massachusetts
I can understand why putting 80# of pressure in a rim that was designed to handle only 70# may cause problems, especially with the valve stem. But don't understand why going from an 8ply to a 10ply tire would. Anyone know why?
Mike & Joan
WBCCI #1521 New England Unit
06 Chevy Duramax/Allison
Old 03-10-2007, 05:33 AM
  #106
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal, Alabama
Status: Online
Mike,
If you are the only one that fills your tires, I do not think there would be a problem because YOU know the rim & valve stem are not rated for the tire's potential pressure. The problem would be for people that go to the tire store and ask for 10 ply tires and don't check the pressure after installation.
Since the tire store would probably inflate the tires to the pressure listed on the tire wall, there would be a problem.
Tom
Old 03-10-2007, 05:41 AM
  #107
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL, Hood River, OR
Status: Online
IIRC, the debate on the 10 ply tires centered around stiffer sidewalls producing a harsher ride and transmitting an excessive amount of shock and vibration into the trailer.......possibly shaking the daylights out of the beast.
I've been investigating 16" rims for my 19CCD with LT225/75R16 Michelins , as I am not comfortable with the Marathons and their 65mph speed rating. I tow 8-10,000 miles a year, mostly out West and need a higher rated tire, especially with a single axel!!
I am now leaning toward the 10 ply Maxxis in 15" to preserve the integrity of the free space in the wheel well. I'll report back when I make the transition.
Thanks for the great info on this thread!!!
Lew Farber - contact
Certified Master RV Tech
ON THE ROAD mid-May !!!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-10-2007, 06:08 AM
  #108
Pahaska
Pahaska's Avatar
When inflated to 65#, I believe that the increased 10ply sidewall stiffness is way down in the noise when supporting about 2000# of trailer.
By putting my weight on an unmounted tire at the dealer, I couldn't detect a great enough difference in stiffness over my 8ply Marathons to affect a loaded trailer. The same argument could be used for those upgrading from 6ply to 8ply.
No one of my friends has detected excessive vibration after changing to 10ply tires.
John W. Irwin
Old 03-10-2007, 06:35 AM
  #109
TomW
TomW's Avatar
Normal, Alabama
Status: Online
That's an old motorcyclist's trick
Originally Posted by Pahaska
... By putting my weight on an unmounted tire at the dealer, ...
Hmm, I wonder how many plies this fella has?
Tom
Old 03-10-2007, 10:56 AM
  #110
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
Status: Online
What is the speed rating on the Maxxis E's
Old 03-10-2007, 11:26 AM
  #111
Al - K4GLU
Status: Online
Per the Maxxis website the speed rating for all of their trailer tires is 65. This suits me fine as my personal towing max speed is 65 - have no desire to go any faster. I just want the tread to stay on the tires and for the air to stay in them!
Old 03-10-2007, 02:27 PM
  #112
hiker
hiker's Avatar
Originally Posted by TomW
Mike,
Tom
Isn't it safe practice to check cold tire pressure before every trip? If so, over inflation by a tire store wouldn't be a problem.
Mike & Joan
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
vB code is On
Pingbacks are On
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
