Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 12-28-2006, 08:13 PM
  #85
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood, California
Status: Online
Trailer Tire Failures
Hi, I like to look from a different angle sometimes; Actually a lot. It would not be too far fetched to say you could very easily pick up a nail in one of your perfectly maintained tires. As you are driveing down the highway, enjoying life, your tire is slowly loseing pressure and at the same time increasing in temperature. Then at some point starts comeing apart. As your tire is self destructing, you don't hear or feel a thing, until someone flags you down or someone at a rest stop says "Hey do you know you lost a trailer tire?"
One reason I suggest this is because on my last time out with my trailer I was at a rest stop when an old couple [probably my age] pulled into the rest stop near the dog walk where I was. I noticed that they had totally destroyed the right rear tire on their SOB trailer. I asked the lady who was the first person to get out of their truck, "Do you know you have a flat tire?" Or should I refrase that, "you vertually don't have any tire left." The couple thanked me for telling them the bad news, she said, "we had no idea that we lost a tire, we were just stopping here for lunch."
I'm sure if you were loseing a tire on your tow vehicle, you would notice it real quick; But on your trailer, I'm not too sure you will notice it before it totally destroys it's self.
Old 12-28-2006, 08:58 PM
  #86
Beginner
Profile:  1984 31' Excella
Norfolk, Virginia
Tire Failure
Tire Failures are not all of a sudden. They are a progression of events that lead to the tire coming apart. Gun Powder, Black Powder, dynamite, TNT and Nitro Glycerin and all “explosives” do not explode, they burn very fast. To verify this just as a Battle Ship Ordinance Man or reloader.
This sequence I was allowed to witness through the use of a Tire Pressure Monitoring System (TPMS).
One of the major problems of steel belted tires was getting the rubber to stick to the steel wire that the belts are made of. Heat greatly aggravates this problem.
The progression towards tire failures that we are experiencing is as follows:
1. Tire overheats: This is caused by driving the tire at a speed faster than its Speed Rating, out of balance tire, out of balance brake drum (running gear) both of which will cause the tire to “bounce” down the road causing the sidewalls at the heavy spot to flex much more than the rest of the sidewall area causing heat to build up at that spot much faster than the rest of the tire, and running the tire under inflated.
2. The rubber reaches its failure temperature: At this point the rubber starts to release the steel belt from its grip allowing it to slip.
3. The belt slips: As the belt slips at some point it tears inner bladder and causes a leak. This leak causes a decrease in the air pressure in the tire. This causes the sidewalls to start to flex more severely causing heat to build up faster.
4. At some point the temperature of the tire gets high enough to cause the rubber to release completely and the tire starts to come apart.
What can we do?
Slow down to 55 MPH or buy better tires.
We do not need tires that will carry a thousand pounds more than what we have, that only beats up our trailers, we need tires that will stand the heat of our driving habits.
According to the National Highway Transportation Safety Administration engineer that I talked to the Speed Rating is a very good gauging rating to use. The higher the Speed Rating the better.
I emailed the RV Safety & Education Foundation about a recommendation in one of their safety booklets recommendations that we run along with traffic. I pointed out that the tires that were being recommended were only speed rated for 65 MPH but on the Interstate System the posted speed limit often exceeds that.The person that answered me acknowledged the discrepancy and took it as an item to address. He also said “Just as a side note his is one of the reasons we see many towable manufacturers going to LT rated tires.”Some of us have taken the time to search out suitable durable replacements for the ST tires and have stopped having troubles. Some have emailed me stating that they have only used LT tires on the Airstreams and have never had problems. http://www.airforums.com/forums/f40/carlisle-tire-failures-28806-2.html
Post #17 states that he changed his Commercial T/As only after figuring out that they were 18 years old, and they were P metric.
The answer is simple folks,
Slow down to 55 or buy better tires.
Beginner
Old 12-28-2006, 09:58 PM
  #87
68 Overlander
Commercial Vendor
Profile:  Boise, Idaho
I have questions that I can't answer still. My recommendation is to listen to these testimonials and go with your gut, not a vendor that sells tire or recommends a brand, including myself. Unless one claims to be a rubber expert and has hard data to back it, it becomes consensus. I'm leaning toward LT for my own use but that has no merit other than my gut feeling. Is that fair?
Get rid of these ads... register today, it's FREE
Old 12-29-2006, 12:22 AM
  #88
ROBERTSUNRUS
Status: Online
Only Three Choices
Hi, this tire discussion reminds me of the 60's. People had three choices:
1. Dig a big hole in your back yard and install a bomb shelter.
Some place to hide if and when the bombs hit.
2. Dig a big hole in your back yard and install a swimming pool.
Have a lot of fun, hope no one drowns.
3. Dig a small hole in your back yard and plant a fruit or shade tree.
Save that money for later, maybe an Airstream for retirement.
Every time some one pops a tire this forum lights up like Las Vegas. I think they will find a cure for cancer before they make indesructable trailer tires.
Old 12-29-2006, 06:43 AM
  #89
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula, Montana
Bad dealer. I have never had anything but good luck with Goodyears. I have had the one several cars and now my Classic.
I am not sure how workers on strike has any affect on the quality of a tire. they are made by machines.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 01-14-2007, 12:16 PM
  #90
FL Excella
Profile:  1979 31' Excella 500
Gainesville, Florida
Our 79 Excella needs new tires. What is the opinion of the readers of this forum for the best tires to purchase for this trailer. Is it best to have an Airstream Dealer do this or can any good tire shop do it. I'm not sure about the Torque issue.
Old 01-14-2007, 02:45 PM
  #91
68 Overlander
Commercial Vendor
Hi FL,
You can read through this thread and a few others and form your gut feeling opinion on Goodyear versus something else and ST versus LT but I would not drive too far to have an Airstream dealer mount them whatever you decide. If fact, they don't specialize in tires so I might even steer toward a reputable tire shop instead. I forget the torque, 100 maybe but do re-torqure after a 100 miles or so.
Old 01-16-2007, 04:01 PM
  #92
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton, Missouri
Status: Online
If I were having a tire dealer do it, I'd stay with the trailer and supervise the jacking up of the trailer and the torquing of the wheel nuts. Technically the Airstream dealer is going to take the wheels off the trailer and most likely run them over to the local Goodyear outlet.
The other thought is to do it yourself and use the ramp method to raise two wheels, remove them yourself and take them to a local Goodyear outlet. That way you remount the wheels on the trailer and can do the torque yourself and won't damage the trailer by raising it incorrectly.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
2008 Moraine View Rally
June 13-15, 2008
Make your reservations now!
Old 03-09-2007, 02:22 PM
  #93
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County), Texas
Sidewall blowout
I had my first Marathon failure last week; however, I had made a turnaround through some rough surfaces a few miles earlier and I may well have damaged the sidewall then. I had just checked the tires with my IR thermometer 10 miles before the blowout and all were running cool and consistent.
I heard the blowout and stopped immediately. The tire was undamaged except at the spot it blew out. There were some gouges in the rubber that indicated to me that it was probably damaged when I turned around.
Along with many of my friends here, I replaced the blown tire with an E-rated Maxxis light truck tire inflated to 65# to match the Marathons. As I need tires in the future, I intend to migrate to the Maxxis. A lot of folks have made the change to Maxxis due to Marathon sidewall failures (there were about 10 Marathon failures among those who went to Salem last year). Since making the change to Maxxis, no one here has experienced a tire failure. My trailer is stored under roof and I don't need the extra UV resistance that the ST tires offer.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 03-09-2007, 02:41 PM
  #94
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal, Alabama
That's NOT the way it has ALWAYS been done.
Originally Posted by Pahaska
... As I need tires in the future, I intend to migrate to the Maxxis. ...
Moving away from Marathons? Doncha know that Marathons & Airstreams are like peanut butter & jelly? Oreos & milk?!?
I say more power to you. Everything I have read indicates Maxxis makes a good tire. And Maxxis is certainly interested in being associated with Airstream:
Tom
Old 03-09-2007, 02:42 PM
  #95
Blu_Hwy_Lady
Blu_Hwy_Lady's Avatar
Profile:  1972 23' Safari
Placitas, New Mexico
Pahaska. Thanks for the update. As somebody who experienced a much more damaging blow-out, I'm most definitely interested in hearing what others have to say. I was really amazed by your statement that 10 other people experienced failures at just that one rally. This really indicates to me that there is a big problem with this tire. What I'm wondering is what it takes to get some deeper investigation into the matter--a la the Firestone recall of 2000. It's much too dangerous an issue to just let go. In my case the tire shreded and took out a big chunk of the wheel wheel and burned the plywood subfloor filling the trailer with smoke so thick you couldn't even see into the trailer. Fortunately, with a tandem axel there was no danger of loss of control, but what about the single axel owners? That's my concern. It seems like people have to start dying before somebody takes notice. It would be wonderful to have somebody take notice and there be a recall of the Marathons before somebody dies or is seriously injured.
Airylle (Susan's 1972 Safari) featured for 5 nanoseconds in the movie Wild Hogs
pulled by Jak the Blue Mule (Bill's 2001 Dodge Cummins)
and
Jupiter (the Golden Retriever puppy)
Athena (the road kitty)
Old 03-09-2007, 02:44 PM
  #96
Pahaska
Pahaska's Avatar
Actually, a total of about 10 tires failed. Several people had multiple failures. One rig had 3 failures during the entire summer of travel.
John W. Irwin
Old 03-09-2007, 02:55 PM
  #97
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs, Illinois
Ok, I went to the Maxxis site and found a ton of tires. Which specific one should I be looking for? I'm going into my 4th season and am considering doing this now, rather than later.
Old 03-09-2007, 03:02 PM
  #98
Pahaska
Pahaska's Avatar
My trailer is at storage and I can't check the model on the tire, but Maxxis makes a LT 225/75R15 E-rated tire that is a perfect match for the Marathon, but with a lot stronger carcass. Discount Tire stocks them here in Austin. They had 10 in stock when I bought mine and that was a day after a friend bought 4 of them at the same place.
BTW, my friend, after blowing 2 less than a year old Marathons, now is switching to 4 Maxxis.
If inflated to 65# like the Marathons, the Maxxis will mix and match just fine.
John W. Irwin
vB code is On
Pingbacks are On
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
