Old 05-01-2009, 05:52 AM   #575
SteveH's Avatar
Common Sense , Texas
Terry,
But do the Marathons have the extra nylon belt in the tread area?
That is what seems to reduce the amount of tread seperations in tires, which is cause for about 90% of trailer tire failures as I have observed.
Old 05-01-2009, 07:14 AM   #576
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by SteveH View Post
Terry,
I have asked Goodyear to forward to me any changes they have made to the Marathons, if it is only cosmetic changes, or if there are any internal improvements. I'll let you know what they say, if anything.
Old 05-04-2009, 07:33 AM   #577
1984 31' Excella
Norfolk , Virginia
Images: 11
ST tires
Until the speed rating of the ST tires goes up to around 99 MPH (indicating a change to better rubber coumpounds) the problem will not go away.
The only thing that may help is a constant water spray on the tires while going down the road to cool them.
Beginner
Beginner is offline   Reply With Quote
Old 05-04-2009, 09:58 AM   #578
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Beginner
I'd love to see an increase in the speed rating of the Marathon tires...any tire for trailers for that matter. But I think it's not necessary to go to extremes for tire cooling.
I have the original Marathons that came on my 2006 Airstream and keep an eye on them. I plan to get one more season out of them. I tow my Airstream at Interstate speeds when, and only when BTW, I'm on the interstate and keep the air pressure at the max 65 PSI. I check the sidewall and tread temperatures approximately every 3 hours (works out to pottie break and meal break stop schedules) and they are almost always within 20 degrees of ambient temperatures on the shady side and 30 degrees on the sunny side. This goes for summer months as well as other months. I use an infrared thermometer to check them. I also check the hub temps using the laser target finder through the wheel spokes. I also check the temps of my tow vehicle's tires and the rear tires generally are about 10 degrees warmer than the Airstream's. So I don't think you need a water spray or any other extreme measure to keep the tires cool. I make checking the tire's air pressure as much, as important, a pre-trip step as checking the torque on the lug nuts.
Family of Disney Fanatics
WBCCI# 4821
Old 05-17-2009, 01:14 PM   #579
Ben4762's Avatar
1989 32' Excella
Lawrenceville , Georgia
A defective valve stem can cause any tire to fail.
Ben4762 is offline   Reply With Quote
Old 05-17-2009, 02:10 PM   #580
silverbacksurfer's Avatar
2005 25' International CCD
Glendale , California
I just bought 4 maxxis tires not made in china .Had a blowout on my Sob trailer before i got my airstream .
silverbacksurfer is offline   Reply With Quote
Old 05-17-2009, 02:20 PM   #581
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Ruidoso , New Mexico
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Was the blowout on the Maxxis tires that were on the sob trailer or did you just get Maxxis tires for your new Airstream because of a previous blowout?
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 05-17-2009, 04:45 PM   #582
The blowout on my old SOB were marathons . After reading alot on the ASforum I decided on Maxxis .When I can I try to avoid chinese products . A lot of the times there is no other way .Here is the link for maxxis 8008 st radial. The tires I got were made in Thailand.
M8008 ST Radial
Old 05-17-2009, 06:26 PM   #583
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
We're now riding on 4 new Maxxis M8008s. Replaced the original Marathons on our 2006 last Friday. We never had any problems with the Marathons. I checked inflation religiously and never tow over 63 MPH (well maybe a short burst now and then if necessary). Two people I talked to that had blowouts with the Marathons, both stated that the tires that blew had been lower than the others when they checked inflation before towing. I never saw that.
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 05-17-2009, 06:36 PM   #584
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
Goodyear I Like Them
Just as an FYI, I have had Marathons on all my trailers for the past 12 years, they do great! Just put a set on my 88.
I pull at 65 to 75 MPH regardless of the temp and have never had a failure.
Buy American!
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Ed Emerick is offline   Reply With Quote
Old 05-17-2009, 07:06 PM   #585
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Our Marathons say "Made in China", though there was a post saying Goodyear was not going to get Chinese made ones anymore. Nonetheless Goodyear is an American company selling tires made elsewhere. Doesn't sound very American made.
Gene
Old 05-17-2009, 07:09 PM   #586
2004 30' Classic Slideout
Albuqueruqe , New Mexico
In 2005 I bought a new 28’ SOB with Goodyear marathons on it…. In the 3 years I owned in I had 5 blow outs including 2 with the Goodyear’s and 3 with a set of new greenballs. Last year I bought a never used old stock 2005 Classic with a slide out, my dream stream. After putting a couple thousand gun shy miles on some date coded 04’ factory installed marathons I tossed them and installed a new set of maxis 235/75 LT light truck tires with a load range D. My tire guy talked me into this, he convinced me this is the way to go and that every 15’’ trailer tire was crap! I have put about 500 miles on this new set of truck tires and I cannot tell any difference in towing, I guess I’ll find out if these are any good when this New Mexico pavement heats up to egg frying temperatures this summer. I still can’t figure out why in the hell Airstream did not put a 16’’ tire on the larger units, it seems to me that this would have helped this problem…
nmgt350h is offline   Reply With Quote
Old 05-18-2009, 08:35 AM   #587
HowieE's Avatar
Princeton , New Jersey
Images: 12
-Ken
Under inflation is the FASTEST way in the world to blow a tire other than a nail. That is why most people grossly over inflate their tires.
You can't blame Goodyear for a blow out when under inflated.
2004 Excursion 4x4
Old 05-18-2009, 08:38 AM   #588
Master of Universe
Gene's Avatar
How much overinflation is too much? As temps have gone up on our trip—about 40˚—so has tire pressure. We had to stop and let air out yesterday when the TPMS warned up a tire was up to 81 lbs. and the others were close.
Gene
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
