Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
d rated marathons are rated to 2540 lbs...
at 80% load (2030 lbs) 45 psi is the recommended inflation,
so one would inflate to 55 psi and still be under max inflation...
IF wanting to travel at 65-75 mph
the goodyear care guideline... "based on industry standards, if tires with the ST designation are used at speeds between 66 mph and 75 mph,
it is necessary to increase cold inflation pressures by 10 psi above the rocommended pressure for the load.
-do not exceed the maximum pressure for the wheel
-if the maximum pressure for the wheel prohibits the increase of air -pressure, then the maximum speed must be restricted to 65 mph
-the cold inflation pressure must not exceed 10 psi beyond the inflation specified for the maximum load of the tire."
my unit 3 axle 11,500 lbs gwr....6 tires d rated to 15,000 lbs
properly loaded to the max of 11,500 lbs the tires are at 75% capacity,
so from the inflation tables 40-45 psi is recommended.....at 65mph and 55psi at 75 mph.
and as i often carry/travel at 10,500 lbs...
the tires are at less than 70% max capacity...1700 lbs each.
so the recommended pressures go down to 35 psi!!! and at higher speeds add 10psi to 45...
still very soft.
a doube axle 30/31 is an entirely differnt critter....gwr 10,300 lbs. on tires rated to 2540x4=10,160 lbs.....nearly maxed out! so recommended pressures are 65 psi which is also maximum inflation pressure...
could it be that the heavier dual axle trailers max out and stress out the marathons moreso than other models? and that some of these tires are underinflated, over load....and exceeding 65mph?
on what size/load rated trailers are tire failures reports?
does anyone understand this post?
cheerrs
2ari'
__________________ all of the true things that i am about to tell you are shameless lies. l.b.johnson
My opinion is that you should run them at 65 PSI no matter what load you are carrying. That is what I run mine at. I think that running them below max tire pressure causes the failures. But that is just my opinion. I run all my trailer tires, (I have 4 trailers) at their max pressure and have only had one flat in the last 20 years. It was on a Marathon and I had run over a 1/4-20 bolt in the driveway.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
Hi 2air; I believe that you have nailed it down to the source of the problem. If you are late for very important corporate meeting, leave your As parked.
With the TV rating capacity and running gear maxed out, why would one want to travel at 85 mph? You're vacationing aren't you? Don't you want to enjoy the scenery instead of developing white knuckles?
I am glad that you have brought to attention the tire inflation logic.
Most, will inflate the tires to max pressure, needed or not. Often we see 3500 lbs boat traiers with dual axle and D tires inflated to 65 PSI. Result, sheared bolts, loose windshields and stressed out trailer frames from vibration. Heavy sidewall tires such as D and E rated tires having more rubber retain heat more so than lower rated tires. As you have pointed out it is very important to adjust the inflation rate to the weight they need to carry. Over inflating the tire, stresses the integrity of cordage especially when exposed to high heat factor. Towing a 42' Fountain weighing 11000 lbs on a tri axle with ST225/75D15 radials for past two years, each 2450 lbs capacity tire carries 1833 lbs at 50 lbs with no ill effects. It should be said here as well, that winding roads do have a considerable affect on tri axles in build up of heat.
It is very possible that the failures are tied exactly to what you have pointed out. Good post 2air. Thanks "Boatdoc"
I've followed the rule Pick is talking about for the past 4 Airstreaming years. I check them before I go, while in transit and same on the return trip. Clearly my loaded Safari at 6300lbs GVWR won't even come close to the max rating, yet I guess I too like Pick am old school figuring that less pressure equals a bit more friction, causing a bit more heat. I think we all have the same tires from the factory no matter what size trailer, even up to the 34' units...those just get another axle, but two more of the same tires.....
It is however good information to know about the speed, PSI info.
To answer a question from Dave in Elgin,
Walker Tire was not the dealer. The Goodyear dealer was one called Goodyear Auto Service Center. I'd rather not say which one.
Dave, you sure have a good looking Airstream. If you have any interest in joining our local group of Airstream owners, we are called the Texas Highland Lakes Unit of WBCCI. Our webb site is: www.wbregion9.org/txhlunit.html
You know, the more and more I think about this, the more puzzling I find it. In one hand, you have what I would consider a fair number of people having issues. Statistically small given the number of tires out there, but concerning nonetheless. OTOH, there are folks like me that may just be lucky. I check the pressures all the time, load carefully and my Safari is nowhere near the max weight rating of the tires combined.
Then I read about speeds, weight distribution of load, etc and can't help but wonder if some folks that have had issues (not all) simply don't check the pressures and drive faster than 65, regadless of outside temps.
Well, after another dozen or so posts, Silvertwinkie, I agree with your thoughts. I'll go a step further. In 1999, I had a blowout on a 1996 30' Excella. I do meticulously maintain my tires. I do not drop the air pressure way down as I know the only drawbacks of keeping high pressures are slightly stiffer rides, and possibly accelerated wear in the center.
All I did was call the customer service 1-800 number, and very calmly and maturely told them what happened. I had the dates of the tires, the tread remaining, the trailer weight and GVWR, the size Marathons, and the specifications.
They didn't give me the third degree. They didn't hassle me or ask for proof of my checking pressures. They paid to have the blown tire shipped to them. They got back to me within 3 days. However, I must give Goodyear a lot of accolades. They GAVE me 4 new tires, and paid to fix the side of my trailer (ripped skirt in front of the tire) 15 minutes on the phone and a couple of hours at the Goodyear dealer, and I was very pleased-both with Goodyear and what they did.
Yes, I still run Marathons, have been many thousands of miles on them, and with that one exception, have never had any trouble with them. I think that 85% fact may be so very real. I change my tires every 5 years.
By the way, with so many members of this forum and so many tires amongst us, how many posters have had problems?
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
the goodyear care guideline... "based on industry standards, if tires with the ST designation are used at speeds between 66 mph and 75 mph, it is necessary to increase cold inflation pressures by 10 psi above the rocommended pressure for the load. -do not exceed the maximum pressure for the wheel -if the maximum pressure for the wheel prohibits the increase of air -pressure, then the maximum speed must be restricted to 65 mph -the cold inflation pressure must not exceed 10 psi beyond the inflation specified for the maximum load of the tire."
cheerrs
2ari'[/quote]
2air ,
If I am reading this last sentence correctly , Goodyear is saying that IF the wheel is strong enough and IF you want to drive at speeds from 66-75 mph , that on a D rated ST tire you can inflate the tire an additinal 10psi beyond the 65psi stated on the sidewall for max load .
2air , If I am reading this last sentence correctly , Goodyear is saying that IF the wheel is strong enough and IF you want to drive at speeds from 66-75 mph , that on a D rated ST tire you can inflate the tire an additinal 10psi beyond the 65psi stated on the sidewall for max load .
hi tickl2...
yea that is confusing...
close but what it says is 10psi above the 'recommended' inflation for the load...and not over the wheel rating, and not more than 10 psi above the recommended pressure for the load....
in another place it notes not over the max cold inflation printed on the side walll (50 or 65)
visit the pdf guideline for the complete goodyear info...
i can't cut/paste from the pdf for some reason....
cheers
2air'
How that some people can NEVER, EVER, read a single word from tire guidelines, then check their tires once or twice a year, run the tires at 75-80 (yes, that is real too) for 7-8 years and never have a problem. That just goes to prove that the more that you know can go wrong, the more that will!
We all need to quit educating ourselves.
steelbird312
1989 29' Excella
I understand that the key to proper inflation is getting the actual trailer weight.
after getting that following the guidelines for inflation at that weight see chart
TIRE LOAD LIMITS (LBS) AT VARIOUS COLD INFLATION PRESSURES (PSI) HIGHWAY STEER AND ALL POSITION TREAD
DESIGNS USED IN NORMAL HIGHWAY SERVICE*
LOAD/INFLATION INFORMATION FOR RV ST METRIC TIRES
Max Speed Tire Rating Inflation Pressure - PSI
So if you wanted to carry 8000 lbs over 4 tires 45psi would do it (in red)
now if you want to go over 65mph inflate to 55psi.
I think that's what this all means????
Another interesting thing I see in that pdf is the LT tires don't carry as much load as the ST's
'77 Sovereign Intl 31' CB '07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI 11411 | Metro NY | AIR 15915
WBCCI Time's a-changing Say no to Lawrence Welk attitudes
exactly right lipets....and not that complicated either!
cheers
2air'
denellen was just joking in his post...he drives old mgs which run on solid rubber tires or wagon wheels...
he and i will sort this out over a big bottle of vino, in florida...you are invited to join us.
