Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 05-15-2008, 03:03 PM   #323
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Airstream Registry
Originally Posted by bhayden
Go back and look at the comparision to the Yokohama 700x15LT. The truck tire is four pounds, about 14% heavier. Extra material means extra cost in manufacture. The ST tires, all of them, are pared down to the bare minimum.
All of which begs the question, if we consider that the statement regarding all ST's being "pared" down to be accurate, then it's not illogical that those folks whose trailers currently are equipped with D rated tires, should seriously consider moving to an E rated ST tire. Will the ST E rated tire carry that cushion of safety that the D's are not providing today?
I'll be honest with you all that was one of the deciding factors as to why I went from D to E's when I replaced my Marathon's.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 05-15-2008, 03:20 PM   #324
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 12
Michelin and many other tire manufactures have stopped makeing trailer tires altogeather. Those that are still being made are now made in China.
I have been tring to get a D rated tires for my daughters trailer and there are none made. Even tried to get LTs but none are made in the size we need. The wheel well is too small to accept whats out there.
As for my Airstream I replaced all the wheels with 16 in and am now using E rated Michelin LTs.
http://defendwally.org/
WBCCI 12156
AIR 3144 WDCU
TAC NJ6
2004 Excursion 4x4
1991 34 ft. Excella +150,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
My Kayak mysite.verizon.net/vze54tx9/kayak/
HowieE is online now   Reply With Quote
Old 05-15-2008, 08:39 PM   #325
Profile:  Exeter , Rhode Island
I've always used GoodYear tires on my trailers for the past 31 years. I've never had the problems that I read about on the rv forums. These tires are rated for a towing speed of 65 MPH. I just read a thread about a tire blowout on a trailer that was being towed at 75 MPH.
My neighbor was getting ready to leave on a trip with his travel trailer. The tires were the GoodYear Marathons. I noticed one was low on air pressure. He said he had checked the pressure the day before. The valve stem was leaking air. The wrong valve stems were being used. These were the original tires from the rv factory.
If he had been traveling on the road when the tire pressure dropped and the tire blew out I'm sure he would have found fault with the tires.
Rob30044 is offline   Reply With Quote
Old 05-15-2008, 11:34 PM   #326
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
Originally Posted by jcanavera
... it's not illogical that those folks whose trailers currently are equipped with D rated tires, should seriously consider moving to an E rated ST tire. Will the ST E rated tire carry that cushion of safety that the D's are not providing today?
Jack
It sure seems logical to me that not running a tire at the upper limit of it's load rating and inflation would give you an added margin of safety. Tire manufacturers do provide tables of load vs inflation. A "rock hard" tire does not necessarily equate to low rolling resistance or less heat build up. A properly inflated tire is what work best. In the case of my '78 Argosy the owners manual says to inflate the tires to only 40psi. To do that and still meet the load spec wouldn't I have to start with a load range E tire.
bhayden is offline   Reply With Quote
Old 05-15-2008, 11:40 PM   #327
bhayden's Avatar
What was the original size? I've found that tire dealers don't always give you the whole spectrum of choices. Most are only interested in spending a minute or two looking through the catalog of their primary supplier(s). Even worse is the guy that "looks it up on the computer". I think they're used to 99% of their customers just buying whatever they tell them is right. And for 99% of the applications it's pretty straight forward.
Old 05-15-2008, 11:50 PM   #328
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Airstream Registry
Jack
Hi, I'm still doing good with my original Marathons. Load range D, on a 6,300 lbs GVWR Safari, but I would be very concerned having the same four tires holding up under your larger and much heavier trailer. Load range E tires probably should be on all two axle trailers over 7,300 lbs GVWR.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 05-16-2008, 01:08 AM   #329
Harry W's Avatar
Profile:  1978 31' Sovereign
Scottsdale , Arizona
I have had most if not all of the experiences with trailer tires listed in this thread (middle of a national forest, old tire sold as new, etc). One tossed a tread but continued to run on the steel belt for another 50 miles, still holding pressure. The slight bump I felt didn't alert me to the problem. The rest shredded, with accompanying damage. My Airstream is stored inside, most of the time without weight on the tires. I have had three failures in the last 3 years, four in the last five, and five in the last seven. Age (over 3 yrs) seems to be the common denominator. Curiously, I ran four tires on a car trailer bought in '94 for seven years before a failure, and that was after towing it 2200 miles in four days, loaded to the gunwales .
I have come to believe that today's trailer tires are generally of poor quality (junk) because no one is getting killed so no one is getting sued. I now watch all passing cars for the dreaded "pointing at the trailer" gesture.
I am considering switching to a truck tire, maybe even a bias construction. While tandem axle trailers do drag the tires in a tight turn, I cannot believe that it is more stressful than turning the steering wheel of a 3/4 ton pickup when sitting still.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Old 05-16-2008, 06:21 AM   #330
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
"I cannot believe that it is more stressful than turning the steering wheel of a 3/4 ton pickup when sitting still."
seeing is believing! try watching a tripple axle swing on a turn.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 05-16-2008, 08:33 AM   #331
HowieE's Avatar
Images: 12
The tires I am trying to replace are 205 75 R 15s Goodyear has them but only in C rating and that is just too close to the limits for confort.
Yes the average tire salesman could not tell you if a tire is blown up or stuffed. I have never found one that has any idea that there are inflation charts based on load. If they miss that fundemental point size would realy through them.
WBCCI 12156
AIR 3144 WDCU
TAC NJ6
2004 Excursion 4x4
Old 05-16-2008, 08:45 AM   #332
jcanavera's Avatar
Fenton , Missouri
Images: 143
Airstream Registry
Good observation. Especially since we all now know that there are E rated ST tires out there. Is anyone aware of any other ST E rated tires out there other than Maxxis?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-16-2008, 10:30 AM   #333
2airishuman's Avatar
Profile:
how much rubber is enough?
LT tires and 'over rated' tires may cause issues too...
side wall stiffness and the related thickness of the sidewalls is critical for passenger tires.
slip angles and maintaining the contact patch and concepts that go with the 'friction circle' are all impacted
BUT most trailer tires just need to ROLL and carry load, except for backing/parking and pot holes and curb jumping and other abuses that no claims every happens to their tires!
this means adequate air, these are pneumatic tires so they function best inflated and with a HIGHER aspect ratio (again few will admit to ever towing underinflated...
the gym has a thin sidewall and this ads to the suspension characteristics of the tire...
i'm not defending the design or built parameters that gy or other ST tire makers use, but soft/flexible is good for the stream...
going to bias ply or e rating or LT tires WILL stiffen the ride.
and u can be sure that any loose rivets, frame/shell separation or insides that shake loose...
WILL be blamed on using 'non spec'd tires'...
while i agree jacks 30slide is a beast, the WHEELS are only rated to 2200lbs each and adding tire capacity doesn't change that.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 05-16-2008, 12:03 PM   #334
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Why tires fail
There are many other factors that also contribute to tire failure that I haven't seen mentioned here. Consider all the factors that cause tires to fail:
underinflation
overloading
overinflation
improper rotational balance
"leveling block stress"
scrubbing the sidewalls on curbs
jumping curbs
potholes, bumps, etc
debris (nails, screws, bungee cords etc)
sharp turns
hot conditions (ambient temperature, dragging brakes)
out-of-alignment axles
age (oxidation)
ultraviolet light (sunshine)
chemicals
Can anyone who has had repeated tire failures (of any brand) confidently say they've eliminated all these factors as a contributing cause?
I've made no secret of the fact that we've had three tread separations in the past six months. Each happened to a different brand: Towmax, Goodyear, Trailer King. The cause in our case seems to have been mis-aligned axles, which were corrected in September but had already caused internal damage to the tires.
For good professional info, try these articles:
SUBARU.COM : TOOLS : TRAILER-TIRE SAFETY
Tire Tread Separation Anxiety - Discount Tire Co.
WBCCI #9990 | Former full-timer | AIRSTREAM LIFE magazine | Tour of America | Man In The Maze
rluhr is offline   Reply With Quote
Old 05-16-2008, 02:50 PM   #335
jcanavera's Avatar
Fenton , Missouri
Images: 143
Airstream Registry
cheers
2air'
To that end I definitely did not go to E rated tires to allow me to carry more load capacity. My trailer isn't rated for more than 9,100 lbs. So technically 4 D rated Marathons are rated higher than what my trailer is designed to carry.
My intentions were to add some additional strength and margin between my normal towing load and the tire's top end. That I'm hoping will translate to better tire life and resistance to road hazards. Only time will tell.
I'm leery of going to E rated truck tires also and I'm hoping that the E rated ST's will not add that much stiffness to the ride. I'm carrying about 10 psi more pressure in my E rated ST's (75 psi), which is 5 psi below max inflation. So far in my initial tow from STL to Fl. last fall, nothing visually showed up to indicate that the trailer was experiencing a rougher ride.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-16-2008, 04:08 PM   #336
Profile:
...So far in my initial tow from STL to Fl. last fall, nothing visually showed up to indicate that the trailer was experiencing a rougher ride.
Jack
i suspect they will do nicely, but you will need 20+ years of towing to equal the gym record right?
one nice thing is the tires could be inflated to 75-80 psi during storage and winter...
that should help and there's no down side, when not moving.
cheers
2air'
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
