Old 10-24-2007, 06:22 AM   #197
1976 25' Caravanner
Campton , New Hampshire
Originally Posted by ROBERTSUNRUS
Hi, aluminauts. That tire is wasted. At first, I would say don't be so wasteful, just replace the one bad tire. But my second thought was, are those your original 2003 model tires? If so replace all six. [or seven] As for changeing brands, I'm personally not convinced that they are any better. Time and mileage will tell.
Is there anyone on this forum that has, let's say, five years and fifty thousand miles on an Airstream trailer with tires other than Goodyear Marathons? We would like to hear from you. Or is it too soon for anyone to give us a first hand report on your experience with other brand trailer tires?
Not exactly the criterion but here's a start.
12 years old
10,000 miles
never covered
never jacked up
bf goodrich commercial TA
235/75/15 XL
2 tires developed slow leaks because of alum rim corrosion , other than that look to be in exellent condition ,tread and sidewall.
ticki2 is offline   Reply With Quote
Old 10-24-2007, 06:54 AM   #198
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Like tiki2, I have the BF Goodrich Commercial T/A'a. Mine now have about 35,000 miles on them and they are doing fantastic. There is still about 90% of tread depth remaining and the wear is very even. It looks like I should get at least 100,000 miles of use out of them. I have had issues with nails, having picked up 3 so far, but the holes were easily plugged. Great and reliable tires. I give them my full endorsement!
So Long!
Bob Thompson is offline   Reply With Quote
Old 10-24-2007, 07:58 AM   #199
HowieE's Avatar
Princeton , New Jersey
Images: 12
I had contacted Goodyear recentently for comments on our discussion
This is the lastest responce after I had offered him a chance to read this post.
Don't know if this will cause Goodyear to improve thier product but some may get relief.
I bought 4 Michelins the day after this came in.
I kind of got the drift of that.
If anyone you know has issues with tires or not being treated properly by a Goodyear dealer, please have them call our Consumer
Relations Call Center at 1-800-321-2136. They will make sure that the dealer administers the warranty properly or they will find one
that will.
Sorry for any problems you may have experienced. I hope that some day we will regain your confidence.
Rick Read
Goodyear OE Tire Sales
rick_read@goodyear.com
574-583-7000, fax -8010
2004 Excursion 4x4
Old 10-24-2007, 09:41 AM   #200
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
that will.
Rick Read
Well, unfortuately it's not a dealer problem or warranty issue. What we are looking for is a product that won't fly apart after a few years or less of use.
I'll get my Maxxis tires delivered on Monday.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-24-2007, 10:31 AM   #201
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I wonder about Load range C LT tires for my 63 Overlander. My axle weight on 4 tires is 4700lbs. Axle rating is 6000lbs between the two.
That's 1500lbs per axle, when and if loaded to the max.
That's 1175lbs per tire as it is, travel ready, with 1/2 tank of water.
Seems that XL rating is all that's available in the 225 size, unless I go to a 235/75/R15.
On another note, perhaps those that had tire failures should share here:
Goodyear Marathon Radial
Uwe
www.area63productions.com
Old 10-24-2007, 10:43 AM   #202
HowieE's Avatar
Images: 12
If you look at the inflation chart
http://www.goodyear.com/truck/pdf/LoadInflLTMetric.pdf
you will see the 235 75 15 will carry 1395 lbs. per tire at 35 pounds air pressure.
Please don't comment on the fact i used the Goodyear chart. That is only because Michelin has taken thier chart of the net, but it still printed in thier spec booklets. By Federal Reg tires of a given spec carry the same inflation requirements per load so it's OK to use the chart just don't use the tires.
2004 Excursion 4x4
Old 10-24-2007, 10:53 AM   #203
richinny's Avatar
2011 34' Classic
NEVER, NEVER, NEVER, plug a radial tire! the process cuts the metal cords and will cause a failure of the tire.
Ricky
Old 10-24-2007, 11:03 AM   #204
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
Huh. I have never heard that and have had quite a few radial tires plugged over the years. Never had any sort of other failure on any of them, and I wore them all down to the treadbars before replacing them. But these were on driving vehicles and flatbed trailers and not an RV trailer.
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 10-24-2007, 11:29 AM   #205
richinny's Avatar
2011 34' Classic
if you listen to the probe going into the tire you can hear the noise. i used to plug tires that way myself. after seeing all the dismounted tires with cord shift, and plugs in the tire, i stopped doing it and only patch tires. it may not be the whole equation but it is enough for me.
Ricky
Old 10-24-2007, 11:33 AM   #206
1976 25' Caravanner
[quote=HowieE]If you look at the inflation chart
[/quote
The specs for the BFG 235/75/15 XL is 1985# @ 41 psi
Old 10-24-2007, 11:36 AM   #207
1976 25' Caravanner
Susan
Many people do and have good luck , but it is not the right way . Tire should be removed from wheel and patched from the inside .
Old 10-24-2007, 12:48 PM   #208
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Ooops...I have been plugging tires for years. Nails, screws, even a spark plug once.
I even plugged a tire on my brand new Suburban the night I brought it home. All of the tires have merrily lasted through their normal life cycle. Just sayin'....
Uwe
Old 10-24-2007, 12:55 PM   #209
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
[quote=ticki2]
[/quote
I like running about 50lbs in my trailer tires. Was looking for LRC minimum. I figure I can get about 2000lbs capacity per tire that way? Maybe a little less, acording to your table. That should be plenty, as long as I have all 4 wheels on teh ground...
Uwe
Old 10-24-2007, 01:29 PM   #210
HowieE's Avatar
Images: 12
Looks like the I nformation I was given and thus posted here is wrong.
Looks like the ratings per a given size tire are not the same from manufacture to manufacture.
The Michelin chart shows 1530 lbs. at 35 psi, 1680 lbs. at 40 psi, 1825 lbs. at 45 lbs. and 1985 lbs at 50 lbs. for the LT235 75 15 for a the C rated tire.
2004 Excursion 4x4
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
