Old 07-31-2016, 05:53 PM   #85
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Had a 10% drop in fuel economy for each 5 mph increment over 55 mph on my Gold Wing motorcycle due primarily to drag of the oversized. Went from high 30s to low to mid 20s.
Old 07-31-2016, 09:14 PM   #86
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
My very best fuel economy - 13 mpg - seems to be at 61-63 mph.
70 cuts it almost in half to 7-8 mpg.
50 (speed limit on the Natchez Trace Parkway) reduces it a little.
65 mph is about all I'm gonna do. I get 10-12 at 65 mph depending on headwind, crosswind, tailwind, or no wind.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-01-2016, 07:44 AM   #87
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Running slower the junk lasts longer including the tires,thus the cost per mile goes down...
Old 08-01-2016, 08:37 AM   #88
1967 26' Overlander
Spartanburg , South Carolina
Very true and the lower pucker factor is easier on the upholstsery.
Jacob D is offline   Reply With Quote
Old 08-01-2016, 09:04 AM   #89
Anna Maria , Florida
Not to beat a dead horse but you might find this informative:
My set up is 2012 EccoBoost, Heavy Duty Tow pkg. 36 gl. tank with the 3.73 rear axle pulling a 2013 30' International. The sweet spot for my set up is 72 MPH. I get that speed in 6th gear at 2000 rpm. On a reasonably level terrain it will not down shift to 5th over bridge crossings nor gradual inclines and I can easily average 11.5 MPG. At 65 mph my rig constantly down shifts and up shifts between 6th and 5th gears and my mpg drops to 10.5 and 11.0 mpg. I can get 12 mpg and no shifting at 60 MPH. So whenever conditions allow I set the cruise at 72 MPH and purr along like a kitten. When conditions change where I need to go slower I normally set it at 62 MPH and it will stay in 6th gear at 1600 rpm and at that speed I get over 12 mpg on the average.
franklyfrank is offline   Reply With Quote
Old 08-01-2016, 10:00 AM   #90
Gainesville , Florida
Try it at 65 in 5th gear., can you lock out od?.
Old 08-01-2016, 10:09 AM   #91
HowieE's Avatar
Princeton , New Jersey
Images: 12
That should work as long as the convertor will lock in 5th at 65. The locking of the convertor is a very important consideration to fuel milage.
2004 Excursion 4x4
Old 08-01-2016, 11:19 AM   #92
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We set our 5.7 Hemi 6-speed with 3.55 axles in 4th gear most of the time to prevent regular downshifting for hills, about 2100 rpm at 60-65 mph, for best towing economy.
Now with the Ecodiesel 8-speed with 3.92 axles the downshifting is much less frequent, and the 8-speed makes the gear selection on its own very smoothly so no need to manually select a lower gear for remarkable fuel economy.
Doug and Cheryl
Old 08-01-2016, 11:26 AM   #93
m.hony's Avatar
2013 30' Classic
I'm gonna say our rigs are so different.
I have a naturally aspirated V8 and you have a twin turbo V6.
I have 20" wheels. I don't know how big your wheels are.
My transmission may hunt for gears from time to time, but is barely perceptible- not like a 1985 Buick Lesabre which would downshift just because the wind began to blow-
Horsepower, torque, and transmission gearing are probably similar, but my truck has 4:30 rear end gears where your truck may have higher speed rear end gears?
I ain't goin' 72 mph anywhere if I can help it... We don't have a road in Mississippi with a legal speed limit more than 70 mph. I go the speed limit up to 65 mphbut never exceed 65 mph when towing. I won't exceed 70 not towing- not even in Texas where speed limits are 70 and 75 mph. If a car pulls out of a side road or driveway, or a kid runs out in the street, or a deer or a dog runs out...
TAC #MS-10
Airforums #70955
Old 08-01-2016, 06:01 PM   #94
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Pretty far off course from the OP's tire post lately.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-01-2016, 06:58 PM   #95
m.hony's Avatar
2013 30' Classic
Speed and heat help the Marathons separate sooner...
TAC #MS-10
Airforums #70955
Old 08-02-2016, 09:01 AM   #96
I will play with it, it gets boring out there somedays.
I do have the option to lock out gears.
Bad Marathon, Bad Marathon ROBERTSUNRUS Tires 45 11-01-2015 03:46 PM
3 Goodyear Marathons failed, found before disaster. GCinSC2 Tires 15 06-17-2010 12:59 AM
Goodyear Marathon Separation Steve Heywood Tires 5 09-19-2006 12:46 AM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
