Old 06-15-2016, 03:03 PM   #1
MOS
2016 28' Flying Cloud
Queensbury , New York
Goodyear Marathon, + 10psi to run 66-75 MPH?
I just found that GY says if you want to tow your trailer at speeds above 65
Just add 10psi to your max cold air pressure.
Anyone doing this ??
mike
MOS is offline   Reply With Quote
Old 06-15-2016, 03:07 PM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
That does not sound wise. Goodyear says, eh? Will they put that in writing?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 06-15-2016, 03:45 PM   #3
daveswenson's Avatar
2012 28' International
Issaquah , Washington
https://www.tirerack.com/tires/tiret...jsp?techid=219
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 06-15-2016, 03:56 PM   #4
Images: 59
You may do that, however the increase is above the reocmmended inflation pressure for your load. not above the max pressure on the sidewall.
So if your recommended inflation is 55 psi for your load, then you can go up 10 psi to 65 psi, but you cannot go above 65 psi maximun cold inflation pressure.
Old 06-15-2016, 03:57 PM   #5
FCStreamer's Avatar
Originally Posted by daveswenson View Post
So when my tire blows, do I sue Goodyear or Tire Rack?
Old 06-15-2016, 04:09 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The OP made me cringe.
MICHAEL
Old 06-15-2016, 05:34 PM   #7
MOS
No it is 10 + above max load psi
Old 06-15-2016, 05:35 PM   #8
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
mike
I am positive that you can add 10% to the sidewall max pressure on a LT tire. I am not sure about a ST tire? I don't run them so I don't have to be sure!
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 06-15-2016, 06:50 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Not going to try to look it up again but I have seen the Goodyear information that said to pump them up to 75 psi for speeds above 65 mph. It is pretty old information.
No, I am not doing it. I would not do it. Neither pump them up to 75 or run faster than 65 with them.
But what do I know. I have a fairly light weight Airstream. (6400 lbs axle rating) I run P-XL tires on my Airstream at 50 psi and they are rated to a lot faster than I want to go.
Old 06-15-2016, 07:03 PM   #10
1991 25' Excella
Stanfield , Oregon
Thats some old info, most good (not to be confused with goodyears) st rated tires have a speed rating on them. Mine have an M speed rating which is 81 mph but some go up to N which is 87 mph.
SpletKay06 is offline   Reply With Quote
Old 06-15-2016, 08:07 PM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The gym already comes equipped with an auto explode feature why help accellerste that function by puffing it up more and then making it spin faster?
Old 06-15-2016, 08:32 PM   #12
Tincampers's Avatar
Sneedville , Tennessee
Here is the link to the letter from Goodyear. Nowhere does it say anything about inflating tires to 75 psi.
https://www.tirerack.com/images/tire...plications.pdf
Tincampers is offline   Reply With Quote
Old 06-15-2016, 08:38 PM   #13
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
Eeeek! Who needs laxatives? No-one.
DuncanK1 is offline   Reply With Quote
Old 06-15-2016, 09:07 PM   #14
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
First of all GMT are junk tires, just about everyone on this forum agrees, now over inflating them is plain stupid, they blow out at 65psi @ higher pressure it will just be louder & quicker. Change them out to Maxxis E rated or Michelin LT tires.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Bad Marathon, Bad Marathon ROBERTSUNRUS Tires 45 11-01-2015 03:46 PM
Goodyear Marathon Failures Surman1322 Tires 677 05-03-2011 01:48 AM
Goodyear Marathon Separation Steve Heywood Tires 5 09-19-2006 12:46 AM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
