06-15-2016, 03:03 PM
2023 19' Caravel
Queensbury
, New York
Goodyear Marathon, + 10psi to run 66-75 MPH?
I just found that GY says if you want to tow your trailer at speeds above 65
Just add 10psi to your max cold air pressure.
Anyone doing this ??
mike
06-15-2016, 03:07 PM
2014 30' Flying Cloud
Tampa
That does not sound wise. Goodyear says, eh? Will they put that in writing?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
06-15-2016, 03:45 PM
2012 28' International
Olympia
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
06-15-2016, 03:56 PM
You may do that, however the increase is above the reocmmended inflation pressure for your load. not above the max pressure on the sidewall.
So if your recommended inflation is 55 psi for your load, then you can go up 10 psi to 65 psi, but you cannot go above 65 psi maximun cold inflation pressure.
06-15-2016, 03:57 PM
Tampa
Originally Posted by daveswenson
So when my tire blows, do I sue Goodyear or Tire Rack?
06-15-2016, 04:09 PM
Biloxi
, Mississippi
The OP made me cringe.
MICHAEL
06-15-2016, 05:34 PM
2023 19' Caravel
Queensbury
, New York
No it is 10 + above max load psi
06-15-2016, 05:35 PM
2016 30' Classic
The Beautiful Mountains Of Southwest
, Virginia
mike
I am positive that you can add 10% to the sidewall max pressure on a LT tire. I am not sure about a ST tire? I don't run them so I don't have to be sure!
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
06-15-2016, 06:50 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Not going to try to look it up again but I have seen the Goodyear information that said to pump them up to 75 psi for speeds above 65 mph. It is pretty old information.
No, I am not doing it. I would not do it. Neither pump them up to 75 or run faster than 65 with them.
But what do I know. I have a fairly light weight Airstream. (6400 lbs axle rating) I run P-XL tires on my Airstream at 50 psi and they are rated to a lot faster than I want to go.
06-15-2016, 07:03 PM
1991 25' Excella
Stanfield
, Oregon
Thats some old info, most good (not to be confused with goodyears) st rated tires have a speed rating on them. Mine have an M speed rating which is 81 mph but some go up to N which is 87 mph.
06-15-2016, 08:07 PM
Overland Adventurer
2009 34' Panamerica
Telluride
The gym already comes equipped with an auto explode feature why help accellerste that function by puffing it up more and then making it spin faster?
06-15-2016, 08:38 PM
2015 30' Flying Cloud
Berrien Springs
, Michigan
Eeeek! Who needs laxatives? No-one.
06-15-2016, 09:07 PM
2016 25' Flying Cloud
Venice
First of all GMT are junk tires, just about everyone on this forum agrees, now over inflating them is plain stupid, they blow out at 65psi @ higher pressure it will just be louder & quicker. Change them out to Maxxis E rated or Michelin LT tires.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
06-15-2016, 10:07 PM
Sneedville
, Tennessee
Nobody is recommending inflation over 65 psi. Just 10 lbs over the recommended inflation for the weight of the trailer.
06-15-2016, 10:20 PM
Venice
The AS sticker says inflate to 65psi on GMT, not depending on you weight.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
06-16-2016, 07:15 AM
Sneedville
, Tennessee
AS didn't make these tires. Goodyear did. I would think GY knows more about it than AS.
06-16-2016, 08:58 AM
2002 30' Classic S/O
Fleming Island
It is my belief that the inflation pressure in the tables is the minimum pressure to support the stated load, not the maximum, and one can inflate up to the maximum pressure on the sidewall without negative effect on the tire. But like others have stated, I don't have to worry about this because I put on the 16" Michelins.
Al
06-16-2016, 09:01 AM
Fleming Island
Goodyear doesn't know what load is placed on the tire, or what additional stresses (tandem axles, etc.) are imposed. Airstream does. Per FMVSS the vehicle manufacturer, not the tire manufacturer, is responsible for posting the required inflation for a specific tire on a specific vehicle.
IMHO, YMMV, etc.
Al
06-16-2016, 09:30 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
mike
Only if you want to trash your investment in the Airstream sooner and at a higher speed than the recommended 60 MPH towing speed.
Bob Martel
WBCCI# 5766
