Old 03-23-2018, 07:31 PM   #1
dlkershaw's Avatar
2016 22' Sport
Swedesboro , New Jersey
Goodyear Endurance Tire / Pressure
Good evening to all: Just purchased and had installed 15 inch/ Goodyear Endurance E rating tires on a Bambi 22FB. I noticed an improvement in ride immediately...
Question: The tire states a max pressure of 80 pounds. the dealer set the pressure at 65 as with my original factory specs. I know it is always recommended to keep your pressure at the required number ? which is required in this case. The trailer spec calls for 65 pounds ? Thanks to all in advance. Always appreciate the input / Dave
dlkershaw is offline   Reply With Quote
Old 03-23-2018, 07:34 PM   #2
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
I'm running them at 75 psi on a 25 ft
dmbecke is offline   Reply With Quote
Old 03-23-2018, 07:39 PM   #3
2018 19' Flying Cloud
Coeur d Alene , Idaho
My dealer told me to run our FV19 at 80 lbs.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 03-23-2018, 07:54 PM   #4
2018 27' Globetrotter
Mooresville , North Carolina
I always run at least w/n 5 lbs of the max or max. Under inflation is one of the main factors in tire failure.
GOUSC is offline   Reply With Quote
Old 03-23-2018, 08:01 PM   #5
Long Island , New York
FYI there are a number of threads on the GYE tire, including this one:
http://www.airforums.com/forums/f438...sa-157249.html
. . . where a fairly extensive discussion about tire pressure took place last year.
[click on orange arrow to go to that thread and the following post and later ones]
Originally Posted by silverback View Post
Excellent discussion. I was wondering what pressure to set the Goodyears to, and now I'm clear. The plate on the 28' Safari says 65 PSI all around for 7300 GWR, and that is what I'll use. I set the previous tires (Maxis) to a little under that, and I may go a little bit over 65 PSI with the load range Es. On a related note, when we left the dealer's yesterday I asked (should have checked) and they said they were 65 PSI. I thought something felt a bit 'squirrelly' on the ride home, and when I checked, they were over 75 PSI. Not right for our Safari.
Old 03-24-2018, 11:45 AM   #6
2014 27' Flying Cloud
Stowe , Vermont
70 to 75 on my 27ft. FC
VT Wanderer is offline   Reply With Quote
Old 03-24-2018, 12:27 PM   #7
2018 27' International
LINCOLN , Nebraska
Goodyear Endurance
I just installed the Goodyear Endurance on my 2006 Airstream Safari SS last month at Discount Tire in McAllen, TX. They are a 10 ply tire, unlike the Marathons which are 8 ply. I run them at 75 lb. per recommendation of DT manager with Max pressure of 80 lb. They are the ST225-75R15. They are D rated I believe; 2833 is the load index and speed rated at max 87mph. Price for four installed and balanced $497 before tax.
MissingLink5 is offline   Reply With Quote
Old 03-24-2018, 12:39 PM   #8
2013 28' Flying Cloud
Penn Yan , New York
Air pressure
I installed the Goodyear Endurance tires and have traveled from NY to South Florida with no issues. So far I think they r great.
I inflated them to the tire pressure recommended for my trailer. The 28’ tire pressure recommended 65 psi.
The tire monitor temperatures stayed in the ball park as the original tires so all is good.
I highly recommend a tire monitor.
delrossa is offline   Reply With Quote
Old 03-24-2018, 01:01 PM   #9
Bentley
pfcardwell's Avatar
2017 23' Flying Cloud
St. Louis , Missouri
My 2017 23FB Flying Cloud came with endurance15 and this sticker
PF Cardwell
23FB Flying Cloud
2017 F150 4X4 Super Crew
3.5 V6 Ecoboost 10-speed
pfcardwell is offline   Reply With Quote
Old 03-24-2018, 02:24 PM   #10
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
If you notice the placard says to check your manual for more information. My manual says: “Proper Tire Inflation
The level of air in your tires affects your vehicle’s overall performance. A maximum inflation pressure specifcation is found on the trailer’s exterior on a metal tag riveted to the lower front, roadside of the trailer, as well as on the original equipment tires.”
You don’t have to inflate to maximum.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 03-24-2018, 06:33 PM   #11
Bentley
pfcardwell's Avatar
This is the placard on 2017 lower right hand side.
PF Cardwell
23FB Flying Cloud
Old 03-25-2018, 10:35 AM   #12
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Well, if Goodyear has a tire load versus air pressure chart for their new GYE tires, one could select the pressure predicted upon some arbritary safety margin. However, one needs to know how much weight is supported by each tire when the unit is fully loaded for camping to be sure the tire with the greatest load has the desired safety margin.
We wanted about a 20 to 25% load margin on the 2014 31' Classic Michelin LT225/75R16/E LTX M/S2 tires. Our weights are:
……1200……——1200
2034……2042—4076
1921…….2062—3983
Total weight——9259
Michelin LT225/75R16/E LTX M/S2 tire load table
80psi 2,680 (E)
75psi 2,560
70psi 2,440
65psi 2,335 (D)
60psi 2,190
55psi 2,060
50psi 1,940 (C)
45psi 1,790
So we aim for 72/73 psi for a 2,500 pound load rating. (2,062 X 1.2 = 2,474.4 pounds for a 20% load reserve) The Dill 1506-453 TPMS shows that is a good setting based upon temperature rise in the tires. Sometimes it is just easier to hit 75 psi and know are are good to go.
The 15" Michelin LTX (P) 235/75R15 XL tires (I used on the 2013 25FB International Serenity and now another set on the 2015 23D International Serenity) derated capacity of 1,985 pounds would be exceeded by three of the four wheel locations on our Classic. The minor load increase for the new Michelin 15" Defender series to a sidewall rating of 2,271 pounds gives a derated load capacity of 2,264 pounds. That slightly higher load capacity would still not over come the heaviest tire load with any safety margin.
Old 03-25-2018, 10:41 AM   #13
Something Shiny
2017 27' International
Mosinee , Wisconsin
[QUOTE=pfcardwell;2080395]This is the placard on 2017 lower right hand side.[/QUOTE
I assume that Airstream calls out tire pressure on each Airstream model's placard for the same reason the auto manufactures specify tire pressure on the placard inside of each vehicle driver's door. Tire manufacturers can only specify a maximum air pressure; they've no knowledge of requirements for which a tire may be used on differing vehicles. There may be justification for adjusting tire pressure in some circumstances, e.g., changing from an ST to a P or LT rated tire. That said, I've kept tire pressure on my Endurance tires to that specified on the placard Airstream riveted to my rig.
Mark & Gina
2017 International Serenity
160W Solar roof mount + 160W Zamp portable
ProPride hitch, 1400#
2018 Ford F250 Platinum 6.7L Diesel
Pongo is offline   Reply With Quote
Old 03-25-2018, 10:55 AM   #14
2016 28' International
Sioux Falls , SD
I just read in the AS manual that ANY tire run with 20% pressure reduction or more of Max MUST be taken off the wheels and inspection done by a tire professional.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Goodyear Endurance ST Tires Made in USA subfan1 Tires 242 09-30-2018 11:37 AM
Goodyear Endurance VT Wanderer Tires 123 05-05-2018 08:27 PM
Goodyear Endurance tires goneupnorth Airstream Classifieds 2 12-07-2017 01:15 PM
Considering Goodyear Endurance Sdt Tires 21 10-03-2017 10:21 AM
Gye - Goodyear endurance Mollysdad Tires 105 07-28-2017 04:42 PM
