Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 05-18-2017, 09:19 PM   #21
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Perusing the net this evening and noticed that Good Year has 10% off the Endurance tire if you order from their website till the end of May.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-21-2017, 09:20 PM   #22
Ravenna , Ohio
Don't forget to read THIS post for speed adjustments
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
Tireman9 is offline   Reply With Quote
Old 05-22-2017, 06:19 AM   #23
centennialman's Avatar
2016 23' International
Centennial , Colorado
Following with interest.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 05-22-2017, 06:36 AM   #24
Sag Harbor , New York
Good morning Steve, FYI this other GYE thread has some interesting points also:
http://www.airforums.com/forums/f438...sa-157249.html
Cheers,
Peter
Old 08-04-2017, 04:24 PM   #25
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
I just bought a 2018 27' Flying Cloud with GY Endurance tires. They are rated to maximums of 80# inflation and 2830# load. Now, the wierd part- although the trailer has a maximum gross weight of 7600# (1900# per tire), the tire placard says to inflate to 80#?! Given the fact that the maximum load the tires will experience with this trailer is 930# less than their maximum, I would have expected a lower pressure recommendation on the placard? I can't find pressure / load tables for the Endurance anywhere . . .
Mike G is offline   Reply With Quote
Old 08-04-2017, 05:02 PM   #26
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
That's odd to me - but admittedly I'm not a tire expert. My 27 also with 7600 GVWR (and about 6000# at the scales with WD on) called for load range D ST tires at 65 psi (2540#/tire). That 80 is an E range and more than you likely need. I'd be tempt d to go to 65 psi but you may want to call the factory or your dealer to get better advice.
Old 08-04-2017, 08:42 PM   #27
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
There are two tire engineers who post here at Airforums, named capriracer and tireman9. They can explain it better than I, but I will summarize what I think the main reason is. On a trailer with two or more axles, the tires fight each other as the trailer goes around corners. The phenomenon is called interply shear. This is hard on the tires and can shorten their life. Running the tires at higher pressure reduces the shear force.
If you google "rv tire safety" you will find a blog from tireman9 with more tire info than you ever dreamed of. Or just go to http://www.rvtiresafety.net/2013/11/...no-babble.html
SSquared is offline   Reply With Quote
Old 11-06-2017, 12:24 AM   #28
Projet2907's Avatar
2017 19' International
Rosemere , Quebec
Originally Posted by Rpatrick16 View Post
Thanks for your report on the GYE tires. Couple of questions:
1. Do you use a TPMS?
If so:
a. what min and max tire pressures have you set it up for?
b what maximum temperature ?
Your input would be very helpful as for reasons beyond me I can't find any info on my present GYM....even when I go to a dealer. I'm beginning to believe that people just don't understand these things or for some reason....no body is willing to share their settings.
Thanks.....enjoy your travels.
Pat
I would like to know too, have you found some info ?
Projet2907 is offline   Reply With Quote
Old 11-06-2017, 03:00 PM   #29
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
That question was asked in May 2017 and not answered. This thread is about GYE tires and not about TPMS.
I would suggest if you want TPMS data to post on a new thread on the Tire Forum as you may get greater exposure than to post on an old thread about a different topic.
Just a suggestion.
>>>>>>>>>>>>>Action
Old 01-19-2018, 10:20 PM   #30
2017 30' International
Lincolnwood , Illinois
Originally Posted by WaLee View Post
Has goodyear published inflation tables for these tires yet?
yes
Milo1952 is offline   Reply With Quote
Old 01-20-2018, 03:03 PM   #31
1970 27' Overlander
Liberty , North Carolina
Originally Posted by Milo1952 View Post
yes
Yes they have.
I have the 225 75r 15s on my 1970 Overlander and can tell you the 80lb maximum is way too high. Every divit makes it leave the ground !
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
B Wilson is offline   Reply With Quote
Old 01-23-2018, 06:52 AM   #32
South Burlington , Vermont
Originally Posted by VT Wanderer View Post
We just finished our first trip with the new Good Year Endurance tires. 3200 miles round trip from VT to FL and back. They ran great, starting with snow/ice and then temps in the 90s. But then again, I only had one issue in 10 years with the old GYM. I do like the idea that GYE are Load Range: E* - Max Load 2,830 lbs - Speed Rating 87 mph - Max Inflation 80 psi.
Thanks VT Wanderer. We are in Burlington, VT. Newbies with a 2012 22' Sport. It has the original tires on it and the previous owner recommended we put new ones on before our spring travels. Have you done much research and what led you to the Endurance?
TomPiper is offline   Reply With Quote
Old 01-24-2018, 06:46 AM   #33
2014 27' Flying Cloud
Stowe , Vermont
I checked online for reviews and articles. EVERY tire on the market had both positive and negative reviews. I was interested in Michelin LT tires at first because of so many positive comments from AS owners. I contacted the manufacturer and was informed that the LT is not designed trailer use. In 10 previous years I had GYM with no issues until a tire with 5 years and 50,000+ miles blew out as I was going faster than I should have been (70+) on a long downhill bend on an interstate. I knew that I should have changed them out before it actually happen. I believe that our VT weather - especially sitting idle all winter - cuts tire life. Most articles that I read advise changing tires every 5 years, as they can look good on the exterior, but most issues start on the interior. What attracted me to the GY Endurance was Load Range: E* - Max Load 2,830 lbs - Speed Rating 87 mph - Max Inflation 80 psi. This was the highest rating of ST (trailer) tire that I had found.
Good luck and safe journeys.
VT Wanderer is offline   Reply With Quote
Old 01-24-2018, 08:28 AM   #34
Mollysdad's Avatar
So far my GYE have been a success.
They don't leak down, haven't failed (knock on wood), and ride well.
I've been using 65 PSI.
Old 01-24-2018, 08:35 AM   #35
dznf0g's Avatar
Oswego , Illinois
I switched to 16" Michelin years ago. New ones about a year ago. However, am watching the GYE experiences here for next replacement consideration. I'll feel better with several years and people's actual historical experience.
-Rich-
Old 01-24-2018, 10:42 AM   #36
FCStreamer's Avatar
2014 30' Flying Cloud
I'll be putting GYEs on my 2014 FC when its time to replace. I may also be moving up to 16s if possible. So I'll need new wheels. Sigh....
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 01-25-2018, 11:54 AM   #37
Mike from Canmore
Mike G's Avatar
Calgary , Alberta
My Endurance tires have been good so far. Although with my 27' Flying Cloud, the recommended inflation pressure is 80#, which is also the tire's maximum recommended pressure. I run them at 75#, just because I don't like being right on the edge . . . plus, I like the higher speed rating- that's an addition cushion as well.
Old 01-25-2018, 03:02 PM   #38
Mollysdad's Avatar
Thinking out loud. If your gross weight is 7600 - 1000 tongue weight, or 6600# divided by 4 gives you a tire load of 1650#. Yes/No?
Goodyear's tire chart for the Endurance is the same as the Marathon. Not helpful.
I spent a good deal of time trying to find the magic number and concluded it doesn't exist. I use 65#. I could be wrong.
Old 01-26-2018, 05:40 AM   #39
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
This makes sense to me. I'm in the process of switching from 14" GYM to 15" GYE. I'll have a large amount of overcapacity with the tire ratings. I would think they'd ride better at 65# than 80. Doubt it would effect gas mileage very much.
Thx
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
GettinAway is online now   Reply With Quote
Old 01-26-2018, 06:46 AM   #40
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
I'm also in VT (South Hero). I have a 2018 30' FC and it came with Endurance tires. My previous trailer was a 2004 25' Safari SS and the last 3 years I had 15" General LT tires on that.
We just got back this week from a 3200 mile trip south. We had crazy (cold) weather. Lows one morning at 8 degrees and only highs in the 60's for a couple of days. I kept and eye on the pressures and ran at 75 psi cold. Some roads were horribly potholed and I know that I hit a few. Especially Rte. 95 in South Carolina and Rte. 81 between Harrisburg and Scranton.
The tires survived fine. But, lots of loose stones so my new trailer got a divot in the alum. and a cracked front window guard. UGH!
sb55 is offline   Reply With Quote
Goodyear Endurance ST Tires Made in USA subfan1 Tires 245 05-06-2019 05:26 AM
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
