Originally Posted by PeterH-Airstreamer
LTX, rated at 2680 at 80psi. GVWR of my 97 Excella is 8300 pounds, so 4x2680=10720 less 10% derated for the trailer use of the LTX= 9648 pounds. Still lots of margin for running them at slighty lower psi, is so desired
SInce your tires are LR-E they are LT which means you do not have to de-rate them.
Your GVWR might be 8300# but your actual weight could be 7500 to 9500# unless you have calibrated eyes.
At least run across a truck scale and get the total for your trailer axles. Best if you can get individual axle numbers as I have seen 800# difference F to Rear.
