Old 05-05-2018, 09:39 AM   #121
Ravenna , Ohio
Originally Posted by PeterH-Airstreamer View Post
Just completed a 3000 mile trip with my new 15" E rated Endurance to Arkansas, Florida and back to Austin
1987 29' Sovereign GVWR 6600#, cold inflation 68 pounds, at towing speeds between 60-70 mph, the psi was ~74, which was in the 10 percent range of cold inflation. Cold tire pressure after 3000 miles 68, 68, 67.5, 68.
I am running 16" Michelin LTX on my 96 30' Excella and was curious to compare them with the new Goodyear Endurance line. Very happy with the performance and handling of the Endurance!
Are your Michelin LTX P type or LT type. There is a serious difference that needs to be taken into consideration what with P type needing to be de rated if used on SUV, truck or trailer.
Retired tire engineer (40 years). Write a blog on RV Tire Safety. Give seminars for FMCA across the US. Tuscon AZ and Lincoln NE iin 2020.
Tireman9 is offline   Reply With Quote
Old 05-05-2018, 11:40 AM   #122
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
LTX, rated at 2680 at 80psi. GVWR of my 97 Excella is 8300 pounds, so 4x2680=10720 less 10% derated for the trailer use of the LTX= 9648 pounds. Still lots of margin for running them at slighty lower psi, is so desired
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 05-05-2018, 02:00 PM   #123
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by sb55 View Post
Sorry to hear about that. I-81 is awful!
We hit a pothole in the same place in January.
Not a blowout, but we had a bulge in the sidewall.
.......a short lived tire....
Old 05-05-2018, 08:27 PM   #124
Ravenna , Ohio
SInce your tires are LR-E they are LT which means you do not have to de-rate them.
Your GVWR might be 8300# but your actual weight could be 7500 to 9500# unless you have calibrated eyes.
At least run across a truck scale and get the total for your trailer axles. Best if you can get individual axle numbers as I have seen 800# difference F to Rear.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Goodyear Endurance ST Tires Made in USA subfan1 Tires 245 05-06-2019 06:26 AM
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 04:19 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 12:16 PM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 06:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 09:29 AM
