Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 08-31-2009, 07:30 AM   #1
Profile:  1975 25' Tradewind
Reno , Nevada
Getting Tires Off/On My Tradewind
Hi Everyone,
So you pick out tires. How do you get them changed? Regular tire places aren't going to unhitch your trailer and put it up on the rack...Can I put some blocks under my leveling jacks and lift up the entire trailer to get my 4 tires off? Is this safe? Is there a better way? I'm thinking of simply taking the wheels down to Sears and having them throw some tires on for me. Also, can't I just use some regular car tires (a bit on the heavier duty side)? My 25' Tradewind isn't any heavier than many cars (I would think). Thanks in advance for any suggestions you may have.
onemanclan is offline   Reply With Quote
Old 08-31-2009, 08:17 AM   #2
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
Ask the tire shop
All the tire shops I use have, and use, floor jacks to raise the trailer. ...yours should too. Its a one side at a time deal....not a hoist like you see in the shops your talking about. Be absolutely sure they know where to jack from. A hole in the belly pan or a bent axle could occur if they do the wrong thing.
Don't use car tires.
Old 08-31-2009, 08:48 AM   #3
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Car tires, ones that the size starts with "P" will not have the load capacity to support the load and forces required of a travel trailer of any type. Side walls flex a lot more on a trailer than on a car. Most cars weigh less than 3000#'s now in an effort to increase fuel economy. Passenger car tire are just not designed to do the job on a trailer. My older Overlander weighs in at 5000#'s. The newer an Airstream the more it weighs as the company made them wider and added more features. An trailers of all types tend to gain weight as they age. Things get left in the trailer and it will weigh more.
Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action is online now   Reply With Quote
Old 08-31-2009, 10:01 AM   #4
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Originally Posted by onemanclan View Post
Hi Everyone,
ABSOLUTELY NOT!!!!
Use the marked jack points or the frame plates that the axles are bolted too....
Name:	2007 WINTERIZE 007.jpg
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
ROBERT CROSS is online now   Reply With Quote
Old 08-31-2009, 10:28 AM   #5
Profile:  1992 21' Sovereign
Albuquerque , New Mexico
Hi
I recently had new tires done by Discount Tire. They had a place in the back of the store where their big trucks come in and unload. I had to back the trailer up the ramp (had lots of helpers on that one). I had coordinated with the DT manager. He had two of his guys on it had the job done in about 20 minutes.
I posted pics here.
Jacked up Airstream for new tires
barbara4rb is offline   Reply With Quote
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 11:11 AM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 05:11 PM
Help on tires: 67 Tradewind 24' double axle pinkflamingoes Axles 21 05-13-2004 11:31 PM
62 tradewind - tires/wheels needed..... p.dow Tires 1 02-27-2004 09:24 PM
61 Tradewind tires lee_jachter Tires 11 10-04-2002 01:00 PM
