03-09-2009, 03:38 PM
#21
2004 25' Classic
West Chazy
, New York
We have not seen any "as delivered" Airstream trailers, with any lead weights on any wheels. They simply do not do it.
Andy,
When I purchased my Airstream (new), there were stick-on weights on the inside of the Alcoa wheels. I could be mistaken, but the dealer that I bought it from would never have taken it upon themselves to do balancing before delivery.
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
03-09-2009, 04:09 PM
#22
You can check the balance of your drums at home, if you're clever.
The next time you repack your bearings (we do that once a year, right?) just put some light oil in the clean bearings, reassemble (loosely) and give it a few spins.
If the drum always stops in the same position, you have a problem. Tape a few washers to the light side until it comes to rest at a random location.
The number and size of the washers will give you an estimate of how much the drum is out of balance. Then you decide if it's worthwhile to have it fixed or replace it.
Don't forget to regrease the bearings with your regular wheel grease before you put it back on the road.
03-09-2009, 04:10 PM
#23
Corona
Originally Posted by romap
Andy,
Who knows, that was 5 years ago.
03-09-2009, 06:03 PM
#24
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Originally Posted by Torii
Thanks for the info on the Centramatics, Do you happen to know the limits as to what they can balance out in terms of weight? I assume they take the place of any weights that would normally be used to balance the tire/wheel assembly. If the brake drum is off balance by a few pounds as suggested by Andy, I wonder if the Centramatics are sufficient to counteract it.
Probably...we run them on 75,000# gravel trucks
Aaron
WBCCI #XXXX AIR #2495
03-09-2009, 07:10 PM
#25
Corona
Aaron
Well, now, if they work on 75,000 pound trucks, they certainly should work very well on a trailer that weighs 10 percent of that, even if it's an Airstream.
Thanks for the endorsement Aaron.
03-09-2009, 07:27 PM
#26
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Centramatics were originally developed for the OTR trucks, a well balanced tire runs cooler, lasts longer and give better mileage. Then they branched out into the smaller sized units. I run them on my F350 duallys and quite often get 65,000 miles out of a set of 50,000 mile steering axle tires.
Aaron
03-09-2009, 07:54 PM
#27
1964 17' Bambi II
Schererville
, Indiana
I ordered my Centramatics last Friday & am anxiously awaiting the UPS man. I'm glad Aaron has first-hand reports! I've asked a number of tire shops out here if they do the balancing of the wheels & hubs and they all looked at me (and Andy's pictorial guide) like I was crazy. Before I ordered them, I did a search on the forums & there are a number of members who use them, so that's encouraging. They seem to be easy to install. They have a video of how they work on their website--- Centramatics.com
Becky
1964 Bambi II
1988 Avion 32S
03-09-2009, 08:22 PM
#28
2004 28' Classic
huntsville
, Alabama
hi
if you can change a tire you can install the centramatic balancers. i installed a set on my 28 classic last week. and next month im going to get a set for the chevrolet 2500.. also i had to replace another tire good year marathon treed seperation. that makes four since i bought the tt. and i had a good year dealer tell me that marathons are made in gadsden alabama ,wrong has made in china on the side wall. i switched to coopers. made in the usa.
i had a set on my classic 310 , they will effectively put 12 ounces of weight on your tire if needed. and that is a lot of weight. if a tire needs more than 12 ounces i dont want it on any of my vehicles. i endorse centramatic balancers if you got a new airstream you can affor a set. $214.00 and that includes shipping.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
03-09-2009, 11:04 PM
#29
2004 28' Classic
huntsville
, Alabama
received a request the part number for the centramatics for airstream tt # is 300-556. these can be ordered on the phone or on line (centramatic.com) . i got mine in three days. ups is one of the better shipping companys here.
thnx al
AL
allison 6 speed
03-10-2009, 02:03 PM
#30
1991 25' Excella
2005 16' International CCD
2012 27' FB International
Salt Lake City
, Utah
Great information everyone!! Centramatics sounds like a great idea, while I am not going to try that at this time, it is something I want to read up more on and possibly do in the future.
I like the "Road Force" balance idea, thanks Robert. I just talked with a tire dealer, actually, the same tire dealer I bought my tires from and had an interesting conversation. First I asked if they had the road force balancing equipment (which I checked on-line first, there is a dealer look up tool to see who has this equipment here is the link: Hunter GSP9700 Wheel Vibration Control System ). When the guy found out that I had a travel trailer, he said that he doesn't even have his tires and wheels balanced for his TT... I told him that was fine but that I wanted to have mine done and "road force" balanced so that is what I am going to have them do tomorrow. It's only $20 per tire and I figure I am going to be much better off doing this than not having done it and then just hope and pray that the drums are okay as I could not find anyone who could or would blance those.
03-10-2009, 05:12 PM
#31
2016 23' International
Centennial
Thanks Andy!
Maybe you SHOULD become a Centramatics dealer....looks like there is a need for sure!
Steve "Centennial Man"
03-10-2009, 05:26 PM
#32
Corona
Originally Posted by centennialman
Thanks Andy!
I plan on it as soon as I get back from my trip.
We should have them right at the end of March, and, at a real good price, too, along with "no shipping charges."
03-10-2009, 08:17 PM
#33
1977 31' Excella 500
Berkeley Springs
, West Virginia
Drum Balancing
My take on this is that I would buy new drums and take them to a machine shop with a crankshaft balancer. I'd have them balance all four to zero. In other words, the hubs themselves would be perfectly balanced.
Then I'd get my wheel & tire combinations spun balanced.
Balanced wheels&tires + balanced drums = SMOOOOOOTH!
With that, you should be good to go.
I actually have an old static balancer that I got from an old gas station that went under. I could set a hub and wheel/tire assembly on there and balance it. But to date, I've not balanced the hubs. I have had my wheels & tires spun balanced and my rig tows very smoothly. I have pictures on the walls hanging on residential style hooks and they don't bounce off. Also did the "Wife Test" where I put her in the back with a cell phone and went down the road and she said it rode just fine.
But, I'm running an Avion and it has a different suspension setup than Airstream. I'm using swing arm type suspension and maybe that's more forgiving than the rubber torsion type? I really doubt that it is. All I know is...it is utterly foolish to think that you need to balance the gear on your truck but not on your trailer. When I bought my six new tires, the tire place looked at me like I was nuts, but I insisted on spin balancing them. As a result, she runs smooth. If a tire on any vehicle isn't balanced, it will vibrate, and that is bad.
ALWAYS BALANCE!
see ya on the road smoothly,
- Jim
03-10-2009, 08:46 PM
#34
1966 24' Tradewind
1975 29' Ambassador
Greenfield
, Massachusetts
I actually have an old static balancer that I got from an old gas station that went under. I could set a hub and wheel/tire assembly on there and balance it. But to date, I've not balanced the hubs. I have had my wheels & tires spun balanced and my rig tows very smoothly. I have pictures on the walls hanging on residential style hooks and they don't bounce off. Also did the "Wife Test" where I put her in the back with a cell phone and went down the road and she said it rode just fine.,
I think your static balancer idea is good except. Make sure you mark which wheel goes with which drum and also which stud goes through which hole on the tire rim. They have to be matched up the same way as they were when you balanced them. This could possible make the whole set-up even more out of balance.
I think your machine shop idea would work much better. Balancing each seperately.. that way it wouldn't matter which tire goes with which drum and the drum-tire rim matchup.
03-11-2009, 06:56 AM
#35
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Ok...... I'm convinced!!
03-11-2009, 08:07 AM
#36
1991 25' Excella
Salt Lake City
, Utah
Question - if I got centramatics and installed those, would I also need the balance weights on the tires/wheels or need to remove those?
03-11-2009, 08:29 AM
#37
Fort Walton Beach
"I plan on it as soon as I get back from my trip."
Andy,
Would you mind posting, as soon as they are available. I think you're going to get orders quickly.....before some of us start our Summer travels.
Chief
03-11-2009, 08:47 AM
#38
2006 30' Classic S/O
Mohrsville
, Pennsylvania
Matt,
From what I read on their web site I do not think you need to remove any existing balance weights. If your tires/wheels are already spin balanced I think the centramatics would just fine tune the balance.
But then again I could be totally wrong.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
03-11-2009, 10:00 AM
#39
7751
1975 25' Tradewind
Huntington Beach
Originally Posted by DEITZ645
Matt,
I can verify this to be true as I called them and asked this very question. The Centramatics will work equally well with or without the weights.
-T
03-11-2009, 07:45 PM
#40
Master of Universe
2008 25' Safari FB SE
Grand Junction
My understanding is as the tires wear, they go out of balance, so the Centramatics help there.
Sounds like getting running gear balanced is much more an issue with older trailers with two or three part brake drums. At least that makes me feel better.
I can see how Centramatics are a good idea, though not sure whether it would be necessary to balance the tires or not if using them. Now I know why I find paint marks on the wheels—probably the running gear was balanced and it was marked and now I know to make sure the wheel is put on in the same place if removed.
Gene
