View Poll Results: "Teletector" flat tire detector works?
Use it and it saved a blowout 0 0%
Use it and it did not prevent a blowout 1 6.67%
Use it and no incidents yet 1 6.67%
No experience with this product 13 86.67%
Voters: 15. You may not vote on this poll
Old 08-01-2002, 06:02 PM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Flat tire detector
I keep seeing ads for the "Teletector Flat Tire Detector" in the Blue Beret and on the WBCCI website. The price is quite a bit better than the similar detector that Camping World has. After blowout damage to my last two trailers, I am seriously contemplating putting in a detector.
Has anyone bought/used this detector? If so, does it appear to be a quality product?
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 08-06-2002, 12:49 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Tire pressure
I have not used the devise or ant simular.
However the government considers tire pressure a key item so as to require automobile manufactures to have these devises available on new vehicles soon. Whatch for the price of new cars go up again.
>>>>>>>>>>>>Action
Old 08-07-2002, 06:47 PM   #3
Re: Flat tire detector
Ira Iburg is offline   Reply With Quote
Old 08-07-2002, 06:56 PM   #4
I have had the TELECTOR for many years, while They never wre needed I feel they are great. I would frequently check them by pulling one wheel at a time up onto a 2 X 6 to see if the lights were working and ocassionly there would be need for adjustment. Also rolling down the highway a rough bridge will make the light blink and believe me there are many rough bridges, but it is a good check.
Old 08-08-2002, 12:16 PM   #5
Contributing Member
Pahaska's Avatar
Question for Ira
How does the Teletector work? The one from CW uses little transmitters inside the tires. From your description of how you test yours, I assume it works somewhat differently, perhaps from the angle off the axles..
John W. Irwin
WBCCI #9632
Old 08-08-2002, 05:57 PM   #6
there is a lamp on the dash-----TIRES------ should one be low the lamp will illuminate
There is a tube on each side mounted to the upper mount of the shock absorber
FROM THE OWNERS MANUAL< BRIEFULLY
THE TELETECTOR IS COMPRESSED AS THE FRONT TIRE LOOSES AIR AND EXPANDED AS THE REAR TIRE LOOSES AIR, THIS ILLUMINATES THE -----TIRES ----- LAMP. IF THE TELETECTOR LENGHT IS INCREASED OR DECREASED BY APPROXIMATELY 0.45" THE TIRES LAMP WILL ILLUMINATE
Old 08-08-2002, 06:38 PM   #7
Contributing Member
Pahaska's Avatar
Thanks Ira, but ...
The 2003 International does not have shock absorbers. AS decided they weren't needed on a dual-axle trailer of this size and weight.
I'll buy the CW system, then, at about $50 more. I need to have the wheels balanced anyway, and that is a very good time to insert the sensors. You buy sensors set for the pressure you carry and they go off at a certain percentage of that pressure.
I want to get them installed before an upcoming major trip.
John W. Irwin
WBCCI #9632
Low Tire Detector Pahaska Tires 31 12-19-2007 04:58 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
avoiding tire flat spots thedakotakid Tires 3 07-08-2003 04:48 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
