Old 06-03-2015, 10:23 PM   #1
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
First time choosing tires for my Airstream
I need your help. I have a 1969 31 foot Sovereign International. It needs new tires. I have heard of using LT tires instead of ST tires on airstreams. I have 15 inch rims. What tires will work best for my TT. Any opinions are greatly appreciated. P.S. I'm scared of having a blowout because of picking the wrong tires.
bellastream is offline   Reply With Quote
Old 06-04-2015, 05:28 AM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Go to 16" Michelin LTX tires and Centramatics. See http://www.airforums.com/forums/f438...in-128145.html
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 06-04-2015, 05:46 AM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Your trailer came from the factory with "Truck Type" 6 ply 7.00x15 tires when it was new. You can still find 7.00x15 bias ply tires, but they are old technology. A good radial LT235/75/15 Load Range C tire would suit your trailer just fine. There are many brands of that size and load rating to choose from.
I use Michelin LTX M/S2 P235/75/15 XL 108T Extra Load on my '72 Ambassador. Many people are using that same tire with very good results.
Lance
Top is offline   Reply With Quote
Old 06-04-2015, 05:52 AM   #4
1969 31' Sovereign
Auburn , Washington
This was the tire I was leaning toward. How heavy is your Ambassador
Old 06-04-2015, 05:55 AM   #5
1969 31' Sovereign
Auburn , Washington
Never mind I looked it up we are about the same weight
Old 06-04-2015, 05:59 AM   #6
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Fully loaded for camping, she weighs 6,650lbs.
This summer will be the fourth season on the Michelins.
You may also want to look into a TPMS for additional precaution.
Lance
Old 06-04-2015, 07:14 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I also run the Michelin tires mentioned above. Look for the gross axle rating on the trailer name plate. The tires have to be rated to carry at least that much weight. The Michelin tires listed above are rated to carry 1985 lbs each for trailer use (DOT 10% reduction applied). So if your axle ratings are 3900 lbs or less each you can run these tires and they do work well. Some of the 6650 loaded weight is tongue wt so you are putting about 6000 lbs on the tires.
My 25' has a gross weight of 6800 and axle ratings of 3200 lbs each. It weights 6300 loaded for camping and puts 5600 lbs on the axles when hitched.
The only downside I have had with the Michelin LTX is that the first set developed a lot of surface cracking after 4 years and had to be replaced. I am 2 years into the second set now and all is well. But perhaps you should expect to replace them after 4 or 5 years. Probably a good idea anyway.
Old 06-04-2015, 11:15 AM   #8
1967 26' Overlander
Spartanburg , South Carolina
A load range D tire gives a margin of safety. In general radial tires give a slight bit better ride than bias ply. I have run Goodyear Marathon ST 225/75R15's load range D on my 67 for the last 16 years with no problems. The tires I have been running were made in Canada. The set I just put on was made in China. Time will tell if there is a difference in Quality and longevity. ST tires are made to have stronger sidewalls than LT's which is to take the extra stress of tight turns. I have never measured my tire temperatures, but I feel both tires and hubs at every stop to ensure nothing has changed since my last stop. My temps have never been high enough to feel uncomfortable. You are doing the right thing to research info on tires and get experienced opinions. Also, I seldom exceed 60 mph and mostly keep to double nickels
when towing.
Jacob D is offline   Reply With Quote
Old 06-04-2015, 11:37 AM   #9
Can-o-worms
1970 23' Safari
Howey in the Hills , Florida
Tire clearance
When I first bought my 71 Safari I put ST 225/75R15's because that is what was on it when I bought it. I did not watch them install these new tires but when I tried to remove them they were to fat to remove and real hard to reinstall. I had to pull out on the side of the wheel well more than I wanted to to remove them. It wasn't easy. I called the tire store and told them about my problem and they replaced with 7.00x15 bias ply tires. Can anyone give advice on this clearance issue?
Bob Riffle is offline   Reply With Quote
Old 06-04-2015, 11:54 AM   #10
1969 31' Sovereign
Auburn , Washington
Does anyone know the gross axle rating on a 1969 31' sovereign?
Old 06-04-2015, 12:32 PM   #11
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
We are running the LTX Michelins on our 05 Safari as well , performing flawlessly .
dannydimitt is offline   Reply With Quote
Old 06-04-2015, 12:37 PM   #12
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
The trailer was designed and built for the tall narrow 700/15 6 or 8 ply tires .
the shorter , fatter 225/75r15's are too wide to fit between the hub and wheel well without pulling the side of the wheel well outward during removal and instillation.
Old 06-04-2015, 12:59 PM   #13
1996 25' Excella
Tillsonburg , Ontario
They do not make Goodyear Marathon ST 225/75R15's in Canada anymore. and the Chinese are now making knock-offs from the technology they were given to make them for Goodyear. I have a set on my 96 25' Excella...came with them; look just like the Marathons ..I'll be keeping a close eye on them!
As in other posts on this subject, don't opt for an LT with too stiff a sidewall, and make sure they are well balanced.
JCW
JCWDCW is offline   Reply With Quote
Old 06-04-2015, 01:24 PM   #14
DR M
2011 34' Classic
Eastlake , Colorado
Other than the Goodyear Marathon tires is there any others that are really good. I have had Michelins in the past and had problems with them. The first one blew out when I have 60% tread life left and the second blew out when I had 50% tread life left. I'll never own another set of Michelins do the poor quality in my opinion.
DR M is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
First time living in Airstream full time. MyNancy1977 1977 Excella 500 0 02-23-2015 08:09 AM
Long Time RVer, first time Airstream(er) Lucas S Member Introductions 4 03-19-2014 03:39 PM
Asking for Advice on Choosing Tires streaminlife Tires 38 03-10-2014 08:33 AM
Need Help Choosing tires for 04 Suburban Davis Tow Vehicles 9 09-06-2007 06:03 PM
