Old 12-29-2013, 08:57 AM   #1
2008 31' Classic
Lake Charles , Louisiana
Firestone Transforce vs. Michelin LTX
Has anyone considered going with the Firestone Transforce HT over the Michelin LTX M/S2 due to the cost? I am a firm believer in Michelin tires and run them on all of my family vehicles. But I always change them out due to tire wear and on my Classic 31 trailer they will more than likely be changed out on a time basis instead of mileage. For the past couple of years I have been running 15 inch Michelins following a GYM blowout which caused extensive damage to the side of the trailer. Now I plan to move up to 16 inch wheels and have been shopping for tires. I run a set of the Firestone Transforce tires on a 24ft. car hauler and have had no issues. The Michelin LTX M/S2 225/75R16's run around $235 each. I can purchase the Firestone tires for around $146 each. Anyone with Firestone Transforce experience on their Airstreams that can provide me some feedback would be helpful. Thanks......... steve
Steve & Mary is offline   Reply With Quote
Old 12-29-2013, 11:12 AM   #2
1974 Argosy 20
Kooskia , Idaho
Steve: No experience with the Firestone you mention but the Goodrich TA in 225/75 R 16 LT is a favorite of the GMC motorhome group. I put a pair on my Argosy when I changed to the 16" wheels. They are a good tire and I have several years on them with no issues.
I have Michelin's on the Airstream as Costco no longer can provide the specific size 16" Goodrich LT tires due to some stupid internal ruling which even the tire shop manager found to be nutsy. Unfortunately in my area other shops who sell Goodrich are not common.
Old 12-29-2013, 11:56 AM   #3
r carl's Avatar
Lin , Ne
The firestone is pretty much a bridgestone. Michelins will ride better!
Old 12-29-2013, 02:15 PM   #4
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I am running the TransForce on the tow vehicle with excellent results. Don't know why they would not work well on the trailer.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 12-29-2013, 02:20 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I am also running them on my Excursion which is a dedicated AS tow vehicle. I tow 2 different 34s. I have 75+k on this set and still have 30% left. I experience very uniform wear, as I keep my front end tight, and the tires inflated hard. I have often pondered using them in a 15" e load application, on my classic, a d 16' on my PanAmerica. Both are due for new rubber this coming year.
Old 12-29-2013, 04:29 PM   #6
1966 17' Caravel
Bethel Park near Pittsburgh , Pennsylvania
Send a message via Skype™ to aceflys
I run the Firestone's on my Sprinter van. I'm on my second set now. I got many miles from my on 1st set. They were on the van when I got it. Plus I run my Sprinter loaded to the max most of the time with no issues.
Ace in PA
aceflys is offline   Reply With Quote
Old 12-31-2013, 12:29 PM   #7
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
All of our 3/4 ton trucks at work use the Firestone Transforce tire. I think they are a good bang for the buck and would use them myself if going to the 16" upgrade. They are a common tire and cost a lot less!
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-31-2013, 12:49 PM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
What he said.
We use Firestone Trans-Force almost exclusively on our fleet of 300 trucks/50 trailers.
We have a Firestone-Bridgestone national account and get a discount.
We had 10 custom trailers built with the same wheel/tire combination as the tow vehicle to be able to use the same lug wrench/spare.
Most all tires in the fleet are LT245/75R16 or LT225/75R16.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-31-2013, 01:05 PM   #9
tintent's Avatar
1996 34' Limited
humboldt , Iowa
We use Firestone Trans-force HT on our Excursion and keep them inflated hard.
WBCCI - 6318 CAC - 6318
AIR - 23036
TAC - IA-1
tintent is offline   Reply With Quote
Old 12-31-2013, 02:30 PM   #10
m.hony's Avatar
2013 30' Classic
50 psi on the front. 80 psi on the back. Rotate every 10,000 miles.
I wonder if Firestone TransForce LT225/75R16 on steel wheels would work for the Airstream- we probably have enough steel wheels hanging around to git-r-dun- but, no, wait a minute- the Airstream wheels are 6 lug, aren't they? We could possibly have 4 6-hole 16" steel wheels hanging around-
TAC #MS-10
Airforums #70955
Old 12-31-2013, 03:14 PM   #11
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
I had Transforce HT on my Suburban for about 70k miles, then replaced with Michelin AT2. Never any problems, but I noticed much smoother, better ride with Michelins.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 12-31-2013, 03:42 PM   #12
m.hony's Avatar
2013 30' Classic
The Michelins do ride better, and I got a 130,000 miles from a set of Michelins on a Chevy Express van. I don't put enough miles on my trailer or tow vehicle to justify the expense of Michelins. I never get the tread life out of a tire. The sidewalls start cracking before I get anywhere close to the tread wear indicators. A less expensive good enough tire is all I need. I will never get more than 45-50k out of a set of tires before they dry rot anyway.
TAC #MS-10
Airforums #70955
Old 01-01-2014, 01:08 AM   #13
2008 31' Classic
Thanks for all of the good information. I decided to go with the BF Goodrich tires and give them a try. They were split about halfway in cost between the Firestone and Michelin tires. I've got the TransForce tires on a 24ft. enclosed trailer we haul the cars in and have had great service. I just thought I would give the BF's a try. Again... thanks
