Old 11-16-2007, 04:21 PM   #1
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Filling tires/nitrogen Gas
I filled my AS tires a year ago with n gas. (10.00 per tire!) I have not had to add air as of yet. The claim is that the gas molecule is larger than air molecules. (I think air is 30% Nitrogen) The tires are supposed to run cooler also.
I have bought a tank, regulator and hose so I can fill and refill my own. This will help with my daughters cars, bikes, motorcycles scooters etc. I am thinking it will pay for its self by wife, daughters and I being lazy about not checking tires frequently enough and riding on low pressure.
The tank set up was about 325.00. It is a tank about 3' tall I think they said it was a 55 cubic ft tank. Our local welding supplier set it up for me. Refills are 15.00. They said I should be able to fill several vehicles depending on tire size and pressure.
I ordered tires today from costco for my work truck and they said they would fill them with nitrogen for no extra charge.
Phil Gobie is offline   Reply With Quote
Old 11-16-2007, 04:26 PM   #2
Images: 59
Hydrogen is the lightest gas. Have you weighed your tires with and without the hydroogen?
I'll bet they're at least 50 lbs lighter!
Old 11-16-2007, 04:26 PM   #3
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
Ummmm...I think that's nitrogen - if it was hydrogen it would redefine the term "blowout".
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 11-16-2007, 04:31 PM   #4
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-16-2007, 04:32 PM   #5
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
oops! anyone have a match?
Old 11-16-2007, 04:41 PM   #6
Jim Clark's Avatar
What is really funny is that about 15 minutes ago my son told his cousin that they were going to do a lab at school to generate helium and ignite it. I had to correct him they will generate hydrogen.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 11-16-2007, 05:23 PM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Actually, run-of-the-mill, everyday breathing air is 78% nitrogen. I've had nitrogen in tires when they put it in for free, but I don't think it's worth paying for.
Old 11-16-2007, 05:43 PM   #8
_
hi phil!
the principle advantage to nitrogen fills phil...
is that the compressed nitrogen is very very very dry.
http://www.airforums.com/forums/380834-post11.html
while a regular air compressor compresses whatever moisture is in the air, along with the air.
so this might be an issue in especially humid climates....
moist air inside tires, contributes to more expansion/contraction with temp changes...
nitrogen/oxygen size has nothing to do with it really...
and i have yet to see a tire 'degrade' from the inside because of oxygen or water...
now jet-aro-planes have completely different reasons for nitrogen fills.
have you put it in the motor bikes too?
it might help reduce rust/corrosion to rims perhaps...
but if you use 'sealants' in the bike tires, pure nitrogen will just dry the sealants out sooner.
also nitrogen fills are a free service at many costco and sam's now...
cheers
2air'
http://www.airforums.com/forums/f438...gen-18625.html
http://www.airforums.com/forums/f438...res-32063.html
RV.Net Open Roads Forum: Tech Issues: Nitrogen in your tires
we even have a poll on this topic...
with very funny posts...wine, cheese, hats, and hot air!
http://www.airforums.com/forums/f438...ires-4975.html
Old 11-16-2007, 06:31 PM   #9
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
$10/tire. wow thats a money maker!
Air is 78% Nitorgen N2 molecular weight 28. 20% or so Oxygen O2 Molecular weight 32.
Nitrogen is non reactive. Compressed nitrogen is only available in high pressure cylinders. No moisture
Oxygen is reactive. Compressed Oxygen is only available in high pressure cylinders. No moisture
N2/O2 compressed is available anywhere someone has a compressor. How much moisture is in the compressed mix depends on how well the air is dryed after compression or in the line. This is a huge variable!
One reason to go with N2 but really the only one.
Michelle TAC MT-0
Sarah, Snowball
Old 11-17-2007, 08:54 AM   #10
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Since our humidity levels can be as low as 3%, I don't need no stinken nitrogen.
Ahab is offline   Reply With Quote
Old 11-17-2007, 09:09 AM   #11
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I also do not use nitrogen, but I am still amazed at the amount of water that my compressor collects. The water separator and the tank need to be drained regularly.
Richard
Old 11-17-2007, 09:24 AM   #12
DFord79's Avatar
Yakima , Washington
OK>>>FOLKS...where have you been?????
It is standard practice for ALL tires to be filled with Nitrogen for the last few years. When I go to ANY local tire dealer in my area...they always fill the tires with nitrogen. ONE of the biggest benifits from nitrogen is the pressure in your tires does not change from hot to cold weather like plain ol air does. I don't know about where you live...but nitrogen is the used at every tire shop here. Maybe its because WE go from 109 degrees in summer to 20 below zero in winter...but its used here EVERYWHERE. AT NO EXTRA COST BY THE WAY.
DFord79 is offline   Reply With Quote
Old 11-17-2007, 09:28 AM   #13
Very american 4 a french
brunoffrance's Avatar
1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
Hi Phil;
I've started this kind of thread ( see the link above) in '03 and I've made laughted a lot of people, in the better way;
I use nitrogen in tires for my A/S and my F150 and the benefit is that keep tires cooler than if not; Sure they become warm but you can put your hand on them after a long road to check. really there is a great difference . The problem is to refill when necessary and you 've to pay .
In Europe, lot of drivers refill tires with nitrogen and you currently see the green cap on tires.
Bruno.
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 11-17-2007, 09:38 AM   #14
Keymar , Maryland
I have to disagree
I have to disagree. Air is 80% plus or minus nitrogen. It is the lack of moisture that is the biggest factor.
If your tires are changing in pressure from hot to cold then you have a tire pressure fairy who is checking and adjusting them for you or your guage is broken.
Check the tires cold then drive a 100 miles or so. check them again. They will have gone up in pressure.
When I used to to work as a Aircraft line mechanic we had a tire pressure "guage" that was temperature compensated. A hot tire could be 10-20 PSI higher than a cold one. If the tire pressure was adjusted without the temp compensation when it cooled off it would be below an acceptable pressure and would have to be removed from service. Delays and money lost.
Per FAA regulation we used Nitrogen. Two reasons: dry no moisture, non-reactive. If a fire broke out it would help put it out and not support further combustion.
Michelle TAC MT-0
Sarah, Snowball
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 09:05 PM
Help with Filling Water Tank james814 Fresh Water Systems 1 07-16-2006 09:13 AM
Water Tank filling up thecatsandi 2006 - 2010 Classic (all lengths) 11 05-13-2006 07:14 PM
Fuel Filling Problem Chaplain Kent Mechanics Corner - Engines, Transmission & More... 7 07-15-2005 12:21 PM
Problem Filling Fresh Water Tank DaveJ Fresh Water Systems 8 10-14-2003 05:36 PM
