Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 10-23-2008, 06:31 AM   #41
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
You guys can say and think what you will but I have not had to add pressure for 20 months now. And when I send my girls off to school I know they are not likely to check there tires often so if it stays longer it may help.
As for adding on the road you can always add air.
It is working for me!
Phil Gobie is offline   Reply With Quote
Old 10-23-2008, 07:44 PM   #42
mustang's Avatar
1999 27' Safari
Kent , Ohio
I have nitrogen in my SuperDuty tires. I was told many things, better mpg, smoother ride, less pressure fluctuation, run cooler, better tire life ect. All I can say is I dont have to add air they seem to stay full, as for the rest, I see no difference. The green caps are a conversation peice though. Would I do it again??? I dont know. I will alsways use a air dryer when filling my tires up with air.
mustang is offline   Reply With Quote
Old 10-23-2008, 09:01 PM   #43
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by markdoane View Post
Don't try that!
When I did it, the trailer windmilled like crazy, and I couldn't keep it on the road. I think the tongue weight was too low. Also, with the tires off the trailer had no directional stability.
When I got to the campground, I had to park under a large tree to keep the trailer from floating away.
And my gas mileage didn't really improve that much. Overall, a less than optimal experience.
Under correct circumstances, it will help mitigate shot axles, though.
Vaughan
Old 04-26-2009, 12:13 PM   #44
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Just checked my tires again (6 months later) and they are still holding the same presser. All 4 tires are still the same! I am having similar results on my motorcycles, scooters, bikes and other cars. Quite the novelty! I am still sold
Old 04-26-2009, 02:31 PM   #45
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Phil,
I have had the same experience with my TV. I check them, just don't fill them. All I use is air.
>>>>>>>>>>>>>>>Action
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 09:05 PM
Help with Filling Water Tank james814 Fresh Water Systems 1 07-16-2006 09:13 AM
Water Tank filling up thecatsandi 2006 - 2010 Classic (all lengths) 11 05-13-2006 07:14 PM
Fuel Filling Problem Chaplain Kent Mechanics Corner - Engines, Transmission & More... 7 07-15-2005 12:21 PM
Problem Filling Fresh Water Tank DaveJ Fresh Water Systems 8 10-14-2003 05:36 PM
