Old 11-17-2007, 11:02 AM   #15
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by Ahab
Since our humidity levels can be as low as 3%, I don't need no stinken nitrogen.
Our Humidity level is at 75.7 right now and that is low for New Orleans. I just throw a couple of the little bags of desacant I find in the cheap Tools I buy at Harbor Freight in each tire, works great.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-17-2007, 11:05 AM   #16
Jim Clark's Avatar
Originally Posted by DFord79
OK>>>FOLKS...where have you been?????
It is standard practice for ALL tires to be filled with Nitrogen for the last few years. When I go to ANY local tire dealer in my area...they always fill the tires with nitrogen. ONE of the biggest benifits from nitrogen is the pressure in your tires does not change from hot to cold weather like plain ol air does. I don't know about where you live...but nitrogen is the used at every tire shop here. Maybe its because WE go from 109 degrees in summer to 20 below zero in winter...but its used here EVERYWHERE. AT NO EXTRA COST BY THE WAY.
I live in New Orleans and it is not used here, heck your lucky to find a station with a working air compressor. I feel so behind the times now, I am scard to put my truck or trailer on the road. BTW I purchased a spare tire and wheel for my trailer and it came from Dallas mounted and "aired" up so I don't think it is standard practice in Dallas either.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 10-12-2008, 09:56 PM   #17
1972 Travelux Princess 25
Cobourg , Ontario
Race car mechanics have been using nitrogen for years, mostly as a matter of convenience. A big cylinder of nitrogen is cheap and a lot more convenient than a gas powered air compressor when you are way off at the races.
This idea of nitrogen being superior to air, I believe started as a cock and bull story fed to reporters hanging around the pits.
Nitrogen expands at the same rate as air. So do all gases, according to Boyle's Law. Anyone who finds out different, will get the credit for overturning a 200 year old law of physics.
Moisture inside the tire does nothing, compared to the moisture, or lack of same, combined with UV radiation (sunshine) on the outside.
Nitrogen is great for filling tires but not worth paying extra for. Don't let any tire shop or garage tell you different.
Ganaraska is offline   Reply With Quote
Old 10-13-2008, 08:13 AM   #18
1994 30' Excella
Mississauga , Ontario
Putting bags of dessicant inside your tires does not remove the moisture from inside the tire it just binds it with the dessicant. The bags will throw the balance of your tires off.
They will never sit in the same place twice. When the tire rotates the bag will be held in place where ever it happens to be by the centrifical forces.
Al
Old 10-13-2008, 08:24 AM   #19
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I disagree with part of what has been said. The biggest contributor to tire pressure change is the moisture contained in the compressed air. IF you can remove the moisture from the air, it will change pressure much more slowly. Something that I see tire stores touting is that the tire will not lose pressure over time, this is not true. A tire will lose 1-2 pounds of pressure per month, no matter what it is filled with.
What tire stores and others try to tell you is the oxygen will find its way out of microscopic cracks and gaps in the tires. This is true, but it also means the nitrogen will also find its way out of those same spots. If it didn't, tires would automatically fill with nitrogen just by the fill and loss process.
Old 10-14-2008, 06:45 AM   #20
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
The claim is that the nitrogen molecule is larger and does not escape as fast as air.
Phil Gobie is offline   Reply With Quote
Old 10-14-2008, 07:21 AM   #21
Images: 59
If the nitrogen molecule is larger, wouldn't nitrogen tend to collect nearest the earth's surface due to it's higher molecular weight?
Then people that live up on the mountain top would be breathing more oxygen than those down in the valley.
Old 10-14-2008, 07:24 AM   #22
CanoeStream's Avatar
St. Cloud , Minnesota
Terry, that makes sense.
Air is 78% nitrogen, 21% oxygen, .9% argon, .033% CO2 and other makeup really drops off after that. Oxygen is only slightly heavier than nitrogen; molecule size size is a much more complex issue but I'll bet on not much difference. Everybody sing now -- Nitrogen makes the cha-ching go around...
5 meter Langford Nahanni
Old 10-14-2008, 07:31 AM   #23
Four times around on a tandem trailer.
Old 10-14-2008, 01:03 PM   #24
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Airlines and nitrogen
On 31 Mar 1986 a Mexicana Airlines Boeing 727-200 crashed killing 166 passengers and crew.It was determined the aircraft crashed due to a blowout of one of the tires.The tire had ruptured fuel,hydraulic and electrical lines in the wheel well.
In Jun 1987 the FAA issued an Airworthiness Directive requiring large aircraft that had tires on wheels with brakes installed to be seviced with less than 5% oxygen by volume thus nitrogen-which will suppress any fire caused by overheated brakes that cause the tire pressure to increase untill the tire or wheel failes.
Since useing nitrogen the airlines found .
(1) More consistent tire pressures ( Tire pressures are checked daily)
(2) Reduced corrsion to allow wheels.
(3) Prevented iner liner rubber deterioration due to oxidation.
(4) Tires run cooler
(5) No moister to freeze at high altitude.
I do use nitrogen in ALL my tires.
I think it has become a green thing.(In europe I hear they use green valve caps on nitrogen filled tires)Some say with nitrogen tire inflation improvement can be noted in vehical handling with better steering,braking and reduced chance of blowouts,fuel savings and better tire life through better tire pressure retention and cooler running tires.Here in the HOT Southwest heat takes it tole on tires so cooler running tires are .
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 10-14-2008, 01:26 PM   #25
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
It is great that the FAA regulates air content of tires used in aircraft that have landing and take off speeds in excess of 100 miles per hour.
However my bullit only sees the north side of 65 mph on a good day. I consider the nitro green thing an added pain that I choose out of. Costco offers the service and does put the green caps on the valve stems. However, when I go to the great out doors I have discovered a spanish phrase from locals in the South West .......
"We don't need no stinkin' green caps!"
Couple that to the lack of moisture around here (usually less than 10% relative humidity) in the air I breathe which gives my sinuses a fit. However that is a story for another thread.
>>>>>>>>>>>>>>>>Action
Old 10-15-2008, 09:25 AM   #26
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Jimmini, I'd be willing to bet you have those magnet gizzies on your fuel line too!
Ahab is offline   Reply With Quote
Old 10-15-2008, 09:09 PM   #27
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
When I bought new tires from Costco they gave me green valve caps, no charge.
Pat
pmclemore is offline   Reply With Quote
Old 10-15-2008, 10:50 PM   #28
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Little cans.
Hi, I'm still waiting for the little cans of nitrogen [16 oz.] to top off my tires while on the road so I don't mix nitrogen with ordinary air. Everytime you check your tires with a pressure guage you will lose a little bit of air/pressure and will need to refill it somehow. My vender couldn't answer that question; What do we do while on the road? Why don't they make "Run Flat" ST tires?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 09:05 PM
Help with Filling Water Tank james814 Fresh Water Systems 1 07-16-2006 09:13 AM
Water Tank filling up thecatsandi 2006 - 2010 Classic (all lengths) 11 05-13-2006 07:14 PM
Fuel Filling Problem Chaplain Kent Mechanics Corner - Engines, Transmission & More... 7 07-15-2005 12:21 PM
Problem Filling Fresh Water Tank DaveJ Fresh Water Systems 8 10-14-2003 05:36 PM
