Old 03-21-2019, 03:24 PM   #71
1998 31' Excella 1000
Simpsonville , South Carolina
Originally Posted by wulfraat View Post
I run my endurance at 65 on my 30’ ... it weighs in at about 7,000 lbs across both axles hitched and ready for camping.
Here is the load chart for the endurance....
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
Technically @1,750lbs load per tire (hitched) 40lbs is acceptable assuming the front axle has 10% more load due to the trailers overall weight distribution. These tires are speed rated to 87mph.
I may drop down to 50-55;this season to improve ride quality whilst still being far north of minimum inflation requirement.
I run 65 psi on my 1998. 31ft Classic. Trailer weighs 8,800 lbs consistently. LRE rated 2540 per × 4 = 10,160. Might drop to 60 psi @ 2380×4= 9520 and monitor it closely. Would give softer ride. I do not exceed 65 mph towing, my sweet spot for fuel economy is 62 mph and 16 mpg towing. 2015 Ram 1500 Ecodiesel .
sctinman44 is offline   Reply With Quote
Old 03-21-2019, 03:58 PM   #72
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
This gets really difficult to follow when I see a statement like this. You have not said which brand tires nor size. Nor, what the Mfg. of the tire's recommends for your weight. But, Your not the only one in these threads that omits the brand tire and tire chart information for given weight. Likely you have 16" tires on that Classic? Just guessing...but which brand?? Michelins are different than GY Endurance as an example...
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 03-22-2019, 01:12 AM   #73
INFO from my MAXXIS spec chart: ST225/75R15 LRE. PSI---65psi--2540x4=10,160 lbs. Psi- 60psi-2380×4=9,520. Max speed 65 mph. 1998 Classic 31ft trailer 8,800 lbs consistently. I think/assume the DOT specs are pretty much the same, per, size tire with respect to psi and weight carried. Only difference I see is "MOST" all ST tire spec 65 mph speed where as the new GYE specs 87 mph. Who on earth would tow a trailer 87 mph. That's insane. 😂😂😂
Old 03-22-2019, 01:18 AM   #74
BTW I upgraded from 20 year old 4000 lb axles to 5000 lb axles so the DW can carry many more shoes and buy more antiques, etc to haul from the west coast back to SC. My loaded gvw went from 8300 to 10300. So trailer and tire are not over loaded.
Old 03-22-2019, 06:26 AM   #75
CapriRacer
CapriRacer's Avatar
I'm in the , US
I want to clear up a bit of confusion.
It doesn't matter what brand of tire, the load tables are the same (or very close) and any differences have to do with which tire standardizing organization the particular tire is built to - and that is not consistent within a brand.
It's very easy to see when comparing ST tires because there is only one tire standardizing organization - TRA (Tire and Rim Association, based in the US) Compare Maxxis to Goodyear. (Taiwanese vs US)
Further, ALL load tables are MINIMUM's - not recommendations. (or maximum's if you approach from the other direction.) You need to use MORE pressure than what the tables says. I recommend 15% more load carrying capacity (which is what car and SUV manufacturers do.)
Every trailer ought to have a sticker (commonly called the vehicle tire placard) that lists the original tire size and the specified pressure for that size. If I remember correctly, since 2008 it is supposed to be towards the front of the trailer. It is supposed to be a yellow sticker just like your car, SUV or truck - and those are supposed to be on the driver's doorframe.
Prior to 2008, the location of the placard wasn't specified and on cars, SUV's, and trucks, it could be found on the driver's door frame, or some other door frame, in the glove box, on the fuel filler door, on the underside of the trunk lid - and in the case of travel trailers, on the entry door. It was white, not yellow, and it's format varied a bit.
CapriRacer
Please visit my website: https://barrystiretech.com/
CapriRacer is offline   Reply With Quote
Old 03-22-2019, 09:28 AM   #76
gypsydad's Avatar
INFO from my MAXXIS spec chart: ST225/75R15 LRE. PSI---65psi--2540x4=10,160 lbs. Psi- 60psi-2380×4=9,520. Max speed 65 mph. 1998 Classic 31ft trailer 8,800 lbs consistently. I think/assume the DOT specs are pretty much the same, per, size tire with respect to psi and weight carried. Only difference I see is "MOST" all ST tire spec 65 mph speed where as the new GYE specs 87 mph. Who on earth would tow a trailer 87 mph. That's insane. ������
Thanks for the clarification; I had poor luck on my Casita with Maxxis several years ago..1 blow out and the other bubble which I caught while on a trip. That was 18 years ago, however.
To answer your question about towing speed, only people driving 87 with an AS are those wanting to pass someone who can only go 65 with their Maxxis! (just kidding of course!)
Old 03-22-2019, 09:40 AM   #77
gypsydad's Avatar
Capri Racer- I think you should talk with the Goodyear factory experts about your assertion of not following their charts for a particular tire, like the Endurance model. Not meaning to be disrespectful but why would you recommend we should be using more pressure than the "Maximum Pressure" recommendations by the manufacturer? Goodyear said the composition used in today's tires differs from Mfg. to Mfg. and tire type; said the "stickers" are there to help folks who don't know their vehicle weight as a safety guide. Maximum performance of given tire to weight is listed in their charts. Sounds like the best advise is to follow their charts??
Old 03-22-2019, 10:01 AM   #78
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I’m not Capri - he is a tire engineer...
I went back and read your #42 here - no where in your discussion w/GY does it seem like they said to interpret the load charts as the MAX pressure to carry that specific load. I think you may be interpreting the chart that way and if so, I think you may be mistaken.
What I understand Capri to be saying (and how I’ve understood the charts) is that the PSI number is the MINIMUM pressure required to carry that load. All the tire engineers who participate in these forums talk about individual weight differences in (for a 2 axle trailer) 4 tires which you wouldn’t see from a CAT scale and right out of the gate they recommend usually a 15% cushion to be safe (meaning - if your trailer saw 4000# on your two axles - you’d have an average of 1000# per tire and would add a 15% Safety margin for a total of 1150#/tire to then select a PSI from the load chart).
Whatever PSI is shown in the load table for 1000# is the MINIMUM amount of PSI required to carry that load, not the MAXIMUM.
Glad to be corrected if I have any of this incorrect - including my inference of how you’re reading the load chart.
Old 03-22-2019, 10:55 AM   #79
gypsydad's Avatar
Thanks for that. No disrespect intended for Capri. My interpretation from my discussions with GY was the PSI numbers posted for given load were minimum; not maximum. Sorry if I confused anyone. Not sure where the "+15%" advice is listed anywhere by the Mfg I could find? But, likely not a big deal.
My point is, each tire Mfg. has a "recommended" chart for their tires; why not use that if you know your trailer weight for best performance?? My experience was Discount Tire who installed my replacment GYE's last summer, put in 70PSI; might be ok if my AS weighed in at 10,488lbs! But it was to much air for my 28', which weighs 7,580lbs. When the tires were too stiff, it caused popped rivets, hinge issues, and other issues inside- like cloths closet above foot of my twin bed with TV coming loose, closet door coming off in hall, and also shower door coming loose and hanging down; all this after I put on the new tires...in just a few trips!
I adjusted tire pressure down to between 45-50PSI per the chart after discussions with GY and also discussions on the Forum last year and have had no issues since after towing from MT to TX and several trips since.
As always, your mileage may vary, as may your opinion.
Old 03-22-2019, 11:15 AM   #80
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
🥴My chart interpretation...
80psi-15%+2psi=70psi. 🤔
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-22-2019, 12:34 PM   #81
W , New England
Got it. I saw no disrespect to anyone in your note at all FWIW....
Thanks for helping me understand how you’re seeing the load chart. You see the cells in the table as minimums. We’re on the same page.
The 15% doesn’t appear to be the manufacturer’s recommendation - just something we see in the forums by the handful of tire engineers who participate here; recommended for the reasons I stated earlier. That answers the question of why not use the manufacturer’s recommendations - especially if you don’t have individual weights for each tire or account for adding more pots and pans (or rocks, like Lucille Ball....).
Old 03-23-2019, 06:27 AM   #82
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Suwanee , Georgia
This shouldn't be rocket science. At 80 psi we had popped rivets and broken cabinet latches.
Now I use the following formula calculated with my tongue in my cheek:
Start with that 80 psi, multiply by driver's age converted to %, then multiply by a safety factor of 120%.
For my trailer that comes to about 65 psi. I start with that, it goes up about 7 psi as the tires warm up. So far so good. May have to rethink this if I'm still towing into my 80's.
Erik & Carol
Suwanee, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 03-23-2019, 06:40 AM   #83
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I run mine between 65 and 70 and it seems to run fine
urnmor is offline   Reply With Quote
Old 03-23-2019, 06:48 AM   #84
W , New England
Originally Posted by Baby Zeppelin View Post
...snip...
Perfect!
2018 Wheel and Endurance Tire take offs Leander Airstream Classifieds 0 11-20-2018 06:35 PM
Goodyear Endurance Tire / Pressure dlkershaw Tires 34 06-18-2018 05:54 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
