Old 03-15-2019, 01:11 PM   #15
2017 27' Flying Cloud
Brookfield , New Hampshire
We were popping rivets at 80 Lbs. Dropped to 65 Lbs and the rivet problem seems to have gone away.
devilsbox is offline   Reply With Quote
Old 03-15-2019, 01:43 PM   #16
demijac
2014 27' FB Classic
Livingston , Texas
Send a message via Skype™ to demijac
Still Experimenting
This topic has been on this Forum a couple of times already and it has been helpful. Seems like it comes down to using what the tire charts recommend based on weight vs. ride quality preference. Also, doesn’t seem like anybody is happy with the rough ride at 80 PSI.
We started with 80 PSI which is what Discount Tire recommended. It was clear that wouldn’t work for our 27FB Classic based on the mess inside of our trailer after only an hour’s drive down the road. We’ve been running at 75 PSI for the last year and that has been only marginally better. Based on the experiences of others on this Forum, it sounds like 70 PSI might be worth a try to improve ride quality and overall wear and tear on the trailer. Hopefully, doing so doesn’t compromise safety. I’m thinking that since we limit ourselves to a 60 mph maximum speed, there will be much less risk in experimenting with 70 PSI in an effort to duplicate the smooth ride we used to have with the Goodyear Marathons at 65 PSI.
demijac is offline   Reply With Quote
Old 03-15-2019, 02:10 PM   #17
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
As mentioned, this topic has been covered in several previous posts on the Endurance. We also had 70PSI from Discount Tire; popped rivets and hinge issues on cabinets. Adjusted to 45-50lbs per our AS weight and Goodyear tire chart. Important to get your AS weighed. We took combined AS weight off scale ticket and divided by 4; then adjusted tire pressure per the Goodyear chart attached. For me, that is 45PSI. I run between 45-50 per the chart.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 03-15-2019, 02:17 PM   #18
CruizinDux's Avatar
Tracktown USA , Oregon
One of many gye threads with great psi/tire load comments by tireman9 and capri racer.
http://www.airforums.com/forums/f438...-157249-9.html
CruizinDux is offline   Reply With Quote
Old 03-15-2019, 02:34 PM   #19
1999 30' Excella 1000
small town , Maryland
Sams Club has a $80.00 rebate on Goodyear Endurance tires till December 31. Sams sells the tire $1.00 less than Tire rack before rebate. For those of us that need tires.
streaminwild is offline   Reply With Quote
Old 03-15-2019, 02:36 PM   #20
2017 27' International
Box Elder , South Dakota
Does anyone ever rotate the tires on their Airstream?
alphamale49 is offline   Reply With Quote
Old 03-15-2019, 05:38 PM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes...every Spring.
It's a habit I acquired as a result of tire removal for Winter storage. It helps the tires and the underrated AS axles.👍
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-15-2019, 09:44 PM   #22
2018 28' Flying Cloud
Fairfield , California
We have GYE`s on our 28`. Ran 1st season at 80 psi because dealer swore it had to be. Brutal for trailer and us. Based on forum input and Goodyear chart, I picked a happy medium of 55psi cold. Pulled 625 miles in last two days, much better and may go a little lower yet.
StuartsDad is offline   Reply With Quote
Old 03-16-2019, 03:33 AM   #23
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Yes.
Rotate front-to-back only, to minimize the possibility of belt separation from reversing rotation.
Old 03-16-2019, 08:34 AM   #24
2013 28' Flying Cloud
Penn Yan , New York
Tire pressure
I installed the Goodyear Endurance tires a few thousand miles ago. We have a 28’ Flying Cloud and the prior Marathons were run at 65 psi. I run the Endurance’s at the same 65 psi. I have tire monitors and the temps and pressure increases are the same as the Marathons. The tire wear is even on all 4.
I didn’t increase the tire pressures as I was concerned with the ride harshness.
delrossa is offline   Reply With Quote
Old 03-16-2019, 10:12 AM   #25
I seem to recall an expert admonition..."lowering IPS to improve ride is not always the best option"🤔
Amanamus
"Tahawus"
Old 03-16-2019, 12:12 PM   #26
gypsydad's Avatar
Suggest you weigh your AS and adjust tires to recommended GY Endurance chart mentioned here...my 28' weight according to the GY Endurance chart says 45psi... I run between 45 and 50 and monitor with the TPMS. No more issues with cabinet door hinges or popped rivets...which I experienced when the tires were installed new last summer and dealer had them filled at 70PSI...the chart PSI for the given weight for these tires seems to be the best reference.; I would guess your 28 is no different after you get to the scales....45-50 PSI should be right.
Old 03-17-2019, 02:09 AM   #27
Berkel-Enschot , Noord-Brabant
I extpected for Airstreams the tires also been yust enaugh for the GVWR .
But remarks about bumping here, made me think they have a comfortable reserve.
So I searched back pictures I made ,when camping in Austria in Petneu, from a tandem-axle Airstream, and calculated pressure with my made extra safe calculator.
GVWR 7300 lbs, and even overrated axles of 3800lbs GAWR
Tires ST225/75R15 prescribed 65 psi.
Maxload acording to given list here 2540lbs wich is loadindex 113.
Gave with GVWR and 10% on pin , 46 psi .
Lowered the loadindex by 6 to give max pressure without bumping and gave 55 psi.
So the Airstreams are exeption to the rule in TT world, and are given tires with a comfortable reserve. The 65 psi advice then must give bumping, if not overloaded.
ID:	335851   Click image for larger version
jadatis is offline   Reply With Quote
Old 03-17-2019, 07:17 AM   #28
I'm happy for you, AS has improved payload and axle ratings over the years...it has not always been so.👎
My food and adult beverages can consume half of my CCC, and I refuse to leave the Wife & Dog behind.
I will run my psi accordingly.
ID:	335859   Click image for larger version
Amanamus
"Tahawus"
2018 Wheel and Endurance Tire take offs Leander Airstream Classifieds 0 11-20-2018 06:35 PM
Goodyear Endurance Tire / Pressure dlkershaw Tires 34 06-18-2018 05:54 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
