Old 04-10-2019, 01:09 PM   #155
Berkel-Enschot , Noord-Brabant
https://www.rv.net/forum/index.cfm/f...d/27477930.cfm
To late to edit so this link must work
jadatis is offline   Reply With Quote
Old 04-13-2019, 10:16 AM   #156
Ravenna , Ohio
Originally Posted by AlanMcD View Post
The label on my Airstream says 80 PSI, I have it set to 75. Just had it to the factory and the Service Tech set the pressure.
Why would the factory service tech change the inflation from the Factory recommended setting?
What are the actual scale readings for each axle?
You might want to Google Interply Shear RV tires when thinking about tire inflation.
Retired tire engineer (40 years). Write a blog on RV Tire Safety. Give seminars for FMCA In Perry GA & Minot ND.
Tireman9 is offline   Reply With Quote
2018 Wheel and Endurance Tire take offs Leander Airstream Classifieds 0 11-20-2018 06:35 PM
Goodyear Endurance Tire / Pressure dlkershaw Tires 34 06-18-2018 05:54 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
