In the rear, you are spreading the weight over 4 wheels and only 2 in front. Your tires will support a different weight at a different P.S.I. (up to the maximum that is printed on the tire). The only accurate way to find the correct P.S.I. on your M/H is to find the weight that is on the two left rear, two right rear, front right, front left then call your tire company with these four specs. If you haven't done this you might be in for a big surprise. Keep us posted. Good luck
Nye
