Old 04-30-2006, 08:50 PM   #1
sigv's Avatar
1963 24' Tradewind
Pittsford , New York
Do trailer tires need to be balanced?
Just bought new tires and rims from TrailerTiresAndRims.com. The tech there said trailer tires do not need balancing?
Is this true?
-Sig
sigv is offline   Reply With Quote
Old 04-30-2006, 08:57 PM   #2
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
Well, dad has owned an independant Goodyear dealership for 32 years. We balanced mine.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 04-30-2006, 09:55 PM   #3
Is this true?
-Sig
If it can wobble, balance it.
Anon is offline   Reply With Quote
Old 04-30-2006, 10:11 PM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
The truth is, yes they should be balanced..The trouble is, not very many places are set-up to do the job properly. In case you do find a place, treat it as gold~ Remember, always share your good luck~!!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-01-2006, 12:49 AM   #5
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Your tire and rim supplier got your business and doesn't care about you or your trailer. Your tires are probably somewhere between 27-29 inches outside diameter. The tread is the heaviest component in the tire and located at the outside of the diameter. At 60mph, the tire is rotating approx 720 times per minute. If there is any variation in the tread weight distribution around the tire or variation in the carcass or in the wheel, or in the hub, then you can have enough centrifugal force to vibrate your trailer. Getting the tire & wheel dynamic balanced goes a long way to eliminating problems. The hub can still be an issue but, not as likely as the tire and wheel. A tire dealer with a Hunter machine can do the job. If they tell you a tire is really bad, I hope your .com will take the tire back. I always buy from a dealer and watch them do the job. I also select a dealer who isn't afraid to send a tire back.
wingfoot321 is offline   Reply With Quote
Old 05-01-2006, 04:31 AM   #6
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Read this thread where we are discussing some findings some members have had.
http://www.airforums.com/forum...ear-22389.html
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-01-2006, 06:56 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes, they do need to be balanced.
The last time we got tires, I asked the dealer to balance them. He stated they didn't need to be balanced, but would be happy to do so for me, as I was the customer, and the customer is always right. (especially when they pay for the balancing)
Most trailers don't need the tires balanced, because most trailers are not on the road long enough to show the effects of out-of-balance tires, they fall apart long before it is evident.
Old 05-01-2006, 02:11 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Not all trailers are the same
If you had a utillity trailer you may not want to balance the tires. A good example would be a landscaper that hauls only clippings and yard equipement around at speeds that never exceed 40MPH. Why bother?
Your travel trailer, ahhhhh that is a another story. You are going to actually live in there. And all of your possessions are in there. Not to mention the trailer is a bit more spendy that the utillity trailer.
>>>>>>>>>>>>>>>>>Action
Old 05-01-2006, 08:55 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Balance them as everyone has suggested. If not, you will find screws backing out; evidence of rivets popping and needing replacement. If this isn't enough, consider the fact that all aluminum sheetmetal is buck riveted together and caulking where the sheets overlap. Do you really want these panels subjected to vibration with the resulting leaks that might develop? Also, the plastic domed headliners at each end of the interior might start cracking. It just isn't worth not balancing.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-02-2006, 12:08 AM   #10
1992 34' Limited
Falls Church , Virginia
Is it worth it?
If a 'tech' suggests that something 'isn't worth it', be sure to check that 'suggestion' out to the n'th degree, cause it ain't worth that dude's 'degree' thumb-tacked to the wall....
Get 'em balanced. Every time. Period.
Pay the bucks, do it right! Your AS and YOU deserve all the best.
Peace
Axel
SilverToy is offline   Reply With Quote
Old 05-02-2006, 06:29 AM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Is this true?
-Sig
No, they should be balanced. Airstream balances their tires.
Old 05-02-2006, 06:38 AM   #12
1984 29' Sovereign
Savannah , Missouri
Thumbs down That's not true~
I wished..Airstream doesn't balance the tires~!!
If you go in for service, they will (if you request it) send the tires out to be balanced but..They are NOT set up at the factory to balance tires on the trailer~
In all the time I've been there at the Center, not once have I seen such an equip set-up..
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 05-02-2006, 06:38 AM   #13
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
There are wheel balancers on the market that automatically balance your wheels as you roll along. One of the popular brands is manufactured by Centramatics in Alvarado, Texas just south of Fort Worth. You may wish to study these products further by using your search engine and type in "Wheel Balancers" or just go to www.centramatics.com. You'll find Centramatics and other products on Google. These, plate shaped units merely fit over your axle hub prior to bolting on your wheels. Sweet!
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 05-02-2006, 08:22 AM   #14
Images: 59
Is it possible that Airstream buys the wheels and tires already mounted and balanced?
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Trailer wiring & new trucks 3Ms75Argosy On The Road... 6 11-09-2002 09:45 PM
New trailer, old club rally Pahaska Other Rallies & Events 7 07-24-2002 01:26 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
