Old 05-05-2006, 11:17 AM   #29
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
The size of the lead weights will depend on the level of balance of the combination of tire and wheel. Wheels can not be balanced without the tire, and must be rebalanced when the tire is replaced.
Someone doing a good job of balancing wheels/tires will try hard to put all of the weights on the back of the rim so that they can't be seen. It is not always possible to balance a wheel/tire only putting weights on the back of the rim.
Balancing a tire and wheel is obviously only for that point in time. As we drive down the road the tire is slowly worn and balance is impacted.
If you rotate tires on your TV you should check the balance to see that the tires are still in balance. I say this being able to do this for my self for free, and not paying for the balance. So you should do your own price/risk analysis to decide if you want to pay for this service. I would guess I change the size and location of weights on the rim when rebalancing around 50% of the time. Note: That is not a scientifically calculated estimate.
I would be very surprized to encounter a tire business that doesn't offer wheel/tire balancing. I'm sure it happens. I can't imagine running a tire businesses without one. Dad has balanced tires for the 31 years he has owned this businesses and did it for the 5 years he worked for Goodyear before that. Since I have Dad's business, I've not had to consider this before...would I shop at a tire business without a tire balancer....good question.
In my mind, a recommendation not to balance tires on a trailer is due to someone's personal opinion that a trailer isn't worth enough to worry about balancing, along with the fact that trailer tire life isn't based on the same tire features as a normal tire application (car, truck, SUV) as trailers in general don't cover enough miles. Trailer tires tend to die from age rather than use. For all I know, the guy making the recommendation had no idea an Airstream has the kind of value (monetary and emotional - both) that justifies the added expense.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 05-05-2006, 12:23 PM   #30
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by frozen chosen
Not sure; but I'd guess around July 2003
Originally Posted by jcanavera
My build was September or October of '03. You do have to look carefully for those weights. They aren't the typical big lead ones that you see on auto's or trucks. I know I missed them the first time I looked.
So, if FC has no weights and Jack does as of 10/03, to me that would mean one of 3 possible things:
1) That sometime between July '03 and October '03 the factory started putting balance weights on the RVs (be it themselves or from an outside vendor).
2) FC's wheels were perfect and needed none.
3) The factory forgot to balance these or they came to the factory that way unbalanced (in error).
I'm leaning toward #1. Though with some of the QC issues I've seen #3 isn't all that impossible.
Old 05-05-2006, 12:50 PM   #31
frozen chosen's Avatar
I gotta go with door no. 3 here. I pulled the tires and definately no weights, front or back. Given AS's abysmal record at QC, this seems typical. While J might have gotten some info from AS to the effect they balance tire/wheels, isn't it suprising others, including some major AS dealers who post on this site can't get a straight answer from the company; about balancing, or jacking procedures, or standing on the roof, or protective covering, or product manuals, or about a dozen other things I can think of. While I have never "taken the tour", and can't think of a lousier way to spend my time, it appears the Jackson center operates with the skilled efficiency of a Bulgarian shoe plant. No 2 trailers are alike, ever. The appologistas will say this is quaint and indicative of the fact these are hand made. Sorry, I'm starting to blog; anyway, I'm getting the damn tires balanced today, and wish I'd done it before my bearings blew up and broke the wheel assembly in half last year.
frozen chosen is offline   Reply With Quote
Old 05-05-2006, 03:49 PM   #32
Aluminut
2004 25' Safari
. , Illinois
Not to sound like Sly Stalone in Judge Dredd, but "I knew you'd say that!"
Old 05-05-2006, 08:27 PM   #33
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Many larger tire retailers will offer a lifetime wheel balance, so you can purchase a wheel balance once, pay a bit more, and have them checked for free whenever you get the tires rotated. Many retailers also will offer free tire rotation on tires that you purchased from them. You may be able to get the lifetime balance on your trailer tires, also, but check with your tire dealer to make sure he will honor that program on trailer tires before you purchase this.
Old 05-07-2006, 05:25 AM   #34
Dusty601's Avatar
Originally Posted by sigv
Just bought new tires and rims from TrailerTiresAndRims.com. The tech there said trailer tires do not need balancing?
Is this true?
-Sig
Check out centramatic self balancers for your trailer. I have a set and they seem to work just fine. Allows you to rotate without need to balance and eliminates need to pay someone to balance.
Dusty601 is offline   Reply With Quote
Old 05-07-2006, 10:40 AM   #35
They sound like the ticket allright. I checked and they do not make these for 14" rims, but may in the future. If they do, I suspect it may not fit b/c the bolts on my wheels do not stick out very far - the centramatic plate would add too much thickness. I guess I would have to add longer bolts.
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Trailer wiring & new trucks 3Ms75Argosy On The Road... 6 11-09-2002 09:45 PM
New trailer, old club rally Pahaska Other Rallies & Events 7 07-24-2002 01:26 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
