Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 05-02-2006, 08:28 AM   #15
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by 53FlyingCloud
I wished..Airstream doesn't balance the tires~!!
If you go in for service, they will (if you request it) send the tires out to be balanced but..They are NOT set up at the factory to balance tires on the trailer~
In all the time I've been there at the Center, not once have I seen such an equip set-up..
53FC
Just to clarify, the newer trailers do come from the factory with balanced tires. I crawled under mine and saw the wheel weights on the inside of the wheel.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 05-02-2006, 08:50 AM   #16
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
My unit was built not long after Jack's unit was built. I assume my rims had weights too, but I never looked. I had my rims replaced under warranty when I was at the factory for service in late April of 2005. The factory took my old tires off the rims to be replaced and when the tires were mounted to the new rims, there were balance weights on the new rims. I don't think they had the balancer in the service area as I watched a forklift take my old rims/tires to the production area and shortly after saw 4 tires on rims brought from the production area to the service area.
My take is that they factory does in fact have a wheel balance machine and places the weights on the rims on site. This may or may not be a change from prior practice, but without question, the new rims had new weights on them with my old tires when I got the trailer back from the service folks. Since I don't think they can pre-balance rims without tires, I assume that they in fact did balance the rims after they placed my old tires back on.
Old 05-02-2006, 11:14 AM   #17
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Wink that's intersting..
Jack
That's interesting news~!
It was 2004 since my last trip there and, on that trip..they send out my tires and new wheels to be mounted.
So...
If I were to travel to the factory...You're saying then, they now do the wheel balance on the trailer while you wait at the factory??
Ithink that sigv has his ans now, that the tires should be balanced ..
53flyingcloud is offline   Reply With Quote
Old 05-02-2006, 04:18 PM   #18
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
So...
I think Eric's example was due to the factory replacing his wheels. My guess is that you probably can't ask for a wheel balance as a normal service request.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 05-02-2006, 05:07 PM   #19
2airishuman
2airishuman's Avatar
Profile:
hi wheel watchers.....
surest thing is to call or email factory....
get the straight dope.....
as i recall from last summer
the factory has a couple of vendors
supplying wheels/tire assembly
for new production and
these come to the factory balanced.
when a customer gets new tires....
in the service center,
i cannot remember if they balance in house
or send 'em out...
and if disc vs drum and
vintage vs new alloy wheels matters
someone here
recently visited
and had new tires
put on her vintage trailer....
now to find the thread.....
oh, it's easier just to email jc
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 05-03-2006, 12:16 AM   #20
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
The only correct answer as we all know is absolutly yes, The local tire shop here used to do on vehical wheel balancing .the machine had a drive drum that spun the wheel rotor /drum tire assy up to speed ,stopped ,weights installed , The company was BEAR Alignment , worked excellent ,usually if you had large ,off highway tires ,it did the best job .Most are long gone today .My other choice shophad one till it broke down and was too expensive to fix due to newer spin balancers we see today . balancing the whole assy does get a better balance ,job.In lieu of availability of that type ,having the tire and wheel assy balanced only is going to be fine . i have also noted unfortunately that even my local tire shop has improperly balanced my service truck tires on the front ,it shook at 45mph went back ,they redid the balance ,I watched ,they got it right ,took 2 times though. bummer! Dont forget the importance of good shocks as well ,they control the rebound effect of the tire and help smooth out the ride.
Scott
scottanlily is offline   Reply With Quote
Old 05-03-2006, 03:34 AM   #21
sigv
sigv's Avatar
Profile:  1963 24' Tradewind
Pittsford , New York
Getting them balanced
Thanks for all the good advice. I called the trailer place and asked them again to balance - said they never do that.
I am picking up the tires and wheels tommorrow from them, bringing them to shop and getting them balanced.
Thanks again,
-Sig
sigv is offline   Reply With Quote
Old 05-03-2006, 12:46 PM   #22
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Thanks again,
-Sig
I never understood that about shops. You are asking them to do a proceedure that they can do and is something they have the capability to do safely. You have money to give them for the services that you are requesting. And they don't want to do it!
Even if they thought your request was nutty I would think they still would want to do work and get paid!
>>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 05-03-2006, 01:04 PM   #23
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
>>>>>>>>>>>>>>>>>>>Action
maybe they don't have a tire balancer.
I was shopping for tires last year...there is a local "trailer" shop near me that services all kinds of trailers...not just campers. they could sell me rims and tires, but when I asked about balancing, they said the same thing: "trailer tires don't need to be balanced". They don't have a balancer.
maybe this is why sob's rattle themselves apart in a few years. their service folks think they're immune to the laws of physics?
doesn't make alot of sense, thats for sure.
but, as for the fact that they don't have a balancer...perhaps thats not so crazy, considering that perhaps most of their customers don't actually "need" balancing...or that they believe this to be true. for the cost of the machine, the space it takes up, etc, etc...perhaps its too small a profit margin to be bothered. just guessing, there. But these guys always look like they're quite busy enough, as it is.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-03-2006, 10:31 PM   #24
scottanlily
Hello chuck ,
Funny you should mention that about sob shaking apart. I do road service work on sobs in conjunction with my local RV shop.Many customers complain about that very problem ,also bouncing around going down the road and a big common problem,broken leaf springs ,why ,no tire balance and alot of sobs do not use shocks! Shocks control the rebound and movement of your tire and wheels. Its hard to believe ,but true.
Scott
Old 05-03-2006, 10:54 PM   #25
frozen chosen
frozen chosen's Avatar
Profile:
Jack
Sorry Jack, I crawled under my '04; no weights. I plan on getting them balanced this week.
frozen chosen is offline   Reply With Quote
Old 05-03-2006, 11:02 PM   #26
Silvertwinkie
Aluminut
FC, my Safari was built 12/03. I think Jack's was built between 30-90 days before mine. What is the build month/year of your coach. We might be able to narrow down when they started putting the weights on the rims......
Old 05-04-2006, 07:07 PM   #27
frozen chosen
Profile:
Not sure; but I'd guess around July 2003
Old 05-05-2006, 07:30 AM   #28
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
My build was September or October of '03. You do have to look carefully for those weights. They aren't the typical big lead ones that you see on auto's or trucks. I know I missed them the first time I looked.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Trailer wiring & new trucks 3Ms75Argosy On The Road... 6 11-09-2002 09:45 PM
LT versus ST tires on a trailer 76Argosy Tires 16 08-21-2002 06:15 AM
New trailer, old club rally Pahaska The Rally Zone 7 07-24-2002 01:26 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
