05-16-2009, 10:38 PM
#21
moderator
2016 27' International
Wilton
All the DOT tire plant codes...
Oh goody. Here's my tires birthplace... CARLISLE TIRE & RUBBER CO., LTD --> BU JI TOWN --> SHENZHEN --> CHINA
06-12-2009, 08:04 PM
#22
2009 19' International
LA
Originally Posted by RDM16CCD
A question I've researched but can't find an answer to. Looking at Maxxis trailer tires, they offer three options (ST225/75R 15)
6 ply Load Range C 2150 pounds @ 50 PSI
8 ply Load Range D 2150 pounds @ 50 PSI 2540 pounds @ 65 PSI
10 ply Load Range E 2150 pounds @ 50 PSI 2540 pounds @ 65 PSI 2830 pounds @ 80 PSI
For my trailer I would need the 2150 @ 50 PSI - would buying the tires with more plies give me more protection against the 'blow out' problems that are the subject of so many other threads? Or is blow out not related to the number of plies and max load rating? My present wheels will 'take' 65 PSI, so I could go with the Load Range D or E tires & the higher PSI, if that helped the problem. My inclination is to go with the D tires and run them at 50 PSI - is this the right way to go? The two extra plies over the C tires would give me some safety margin against a blow out?
Thanks in advance for your opinions & info?
Yeah! If you are going with 2150 then your problem with be solved. I am not sure but I think.
06-13-2009, 05:52 PM
#23
1972 Travelux Princess 25
Cobourg
, Ontario
Originally Posted by Bob Thompson
It's funny how we can exalt 454 cubic inches of self indulgence and belittle 47 mpg of frugal. That's curb appeal without character in some books.
What I can't get over is the goofs who buy 6000 pound 454 cu in vehicles and complain about the mileage. Duh, what did they think?
Amazing some people. I feel like asking if they are stupid.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
06-16-2009, 09:36 AM
#24
2022 25' International
Savage
Originally Posted by vlamica
Carlisle radial trails ST225/75 R15 Load E 2830LB's @ 80psi.
Thanks Vinnie
I just ordered the exact same tires (2) for my single axle '64 Safari. I will plan to run them at 65 or 70 psi. I will certainly report how they perform. At Discount Tire the Maxxis version was $30 more per tire.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
06-16-2009, 10:37 AM
#25
Corona
If you have steel wheels that have been in service for an extended period of time, you must replace them when you increase the tire load range.
If not, they will split around the inner circumference, as per wheel manufacturers warnings.
That can happen going from "C's" to "D's" as well as going from "D's" to "E's".
06-16-2009, 12:06 PM
#26
Savage
Good to know, and I should have stated that I also ordered new Aluminum Wheels, also rated for 2800# each.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
06-16-2009, 12:30 PM
#27
Corona
Good, now that worry is over, but "E's" are not recommended by Airstream.
Also, you should probably install the wheel balancers, since next to no one can balance the tire, wheel hub and drum, as an assembly.
06-16-2009, 02:39 PM
#28
moderator
Wilton
I am very happy with these tires so far. We are staying in Grand Canyon right now and have traveled some rough road at high temperatures. I set the cold tire pressure to 65lbs. On the hottest part of the trip when i pulled over at a rest stop i checked the pressures and they were 71psi. So when they heated up they increased by 6 psi. I purposly put a few things on the counters while traveling and to my amazement they rode right where they sat. These trailers are amazing how they ride. There was a crazy section of I-40 that had rolling dips on the road. The sign warned of it but I had no idea it would be as bad as it was. I expected to find everything on the floor when we stopped but it was all intact and in good order. Even though the tires are load range E the trailer is heavy and I think they suit my application well. I hope they work well for you too.
Thanks Vinnie
