Old 05-05-2016, 08:20 AM   #1
FCStreamer's Avatar
2014 30' Flying Cloud
Distance between tires?
I am going to purchase a rubber mat so I can park my TT on top of it instead of the bare concrete. I am hoping someone knows the distance between the two tires on either side of a 2014 30' Flying Cloud? I am not wanting to buy too much of this stuff if I can help it.
http://www.amazon.com/Rubber-Cal-Dia...ds=parking+mat
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-05-2016, 10:13 AM   #2
richw46's Avatar
Lexington , Kentucky
When I put mine in storage I just put 4 wood slats behind the tires, then back up onto them. I'm not sure that rubber mats are good for long term storage.
I've heard that asphalt leaches out stuff from the tires
I've heard that concrete leaches out water
Is this true? I don't know, but the simple solution was these 4 wood slats that are easy to use and I store them in the bumper. I take it out of storage every 2 months and drive it home then back to storage, about 42 miles round trip.
From the Goodyear site:
[http://www.goodyearrvtires.com/tire-storage.aspx]
Ideally, a vehicle in storage should be placed on blocks to remove all weight from the tires. If the vehicle cannot be put on blocks, follow these steps for tire protection:
  • Completely unload the vehicle so that minimum weight will be placed on the tires
  • Inflate tires to recommended operating pressure plus 25%. Ensure that the rim manufacturer’s inflation capacity is not exceeded
  • Be sure the storage surface is firm, clean, well drained and reasonably level
  • Avoid moving the vehicle during extremely cold weather
  • Move the vehicle at least every three months to prevent ozone cracking in the tire bulge area, as well as “flat-spotting” from the prolonged strain of sidewall and tread deflection
  • Adjust inflation before putting the vehicle back into service
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-05-2016, 03:50 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
On a concrete pad you really just need to keep the contact patch of the tire as dry as possible...drainage tile works well.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 05-08-2016, 09:00 PM   #4
1990 32' Excella
jonesboro , Arkansas
I park on a piece of rubber conveyor belt . if you live near a farm community or co_op they give old belts away makes great mud flaps to.
joel is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
Distance between bunk beds? PA BAMBI II Interior Restoration Forum 3 07-13-2014 05:03 AM
Distance Between Tires Olie Tires 1 03-05-2013 02:16 PM
Distance between fridge burner and water line? mimiandrews Refrigerators 1 04-09-2009 11:53 AM
Distance Between Axles joopkeizer Axles 3 11-04-2007 05:22 PM
