Old 11-07-2015, 10:02 AM   #1
1967 22' Safari
Pearland , Texas
Angry Dill TPMS Tire pressure monitor valve stems
Hello everyone. I purchased the Dill TPMS for my 67 Safari (single axle) I took tires and wheels with the valve stems to be mounted / balanced. When I returned to pick them up Discount Tire had mounted them without using the Dill valve stems. The units included with the kit are the smaller diameter .4xx and the 15" steelies on my AS have larger .625 valve stem holes. Does anyone know where I can pick up replacement valve stems that are compatible? I want to get this wrapped up this weekend if at all possible. I am sure my neighbors love seeing my AS on jackstands in the driveway.
TexasToaster is offline   Reply With Quote
Old 11-07-2015, 10:26 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Any tire shop should have them. They would be a common stocking item.
MICHAEL
Old 11-07-2015, 10:32 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I have a Dill TPMS on my Safari. I thought the valve stem was a part of the transmitter, and they made both sizes. Can you exchange them where you bought the system?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-08-2015, 05:24 AM   #4
1967 22' Safari
Pearland , Texas
You would think the stem is the same. However it appears that it isn't. The transmitter/ sensor is separate and attaches to the stem with a screw. Rather than a 1 piece unit like most OEM systems. purchased from Dill authorized distributor Tirerack.com since they had the best price. I guess I may have to wait until Monday and see if I can order replacement units. May be handy to order more than 2 if that's the case.
Old 11-08-2015, 05:53 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I have been able to get questions answered by calling Dill directly.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-08-2015, 05:18 PM   #6
1967 22' Safari
Pearland , Texas
I guess I will have to call tomorrow. I went to try and find correct replacement units locally only to be looked at like an idiot. It does look like Dorman had some promising items but not in stock locally. I can probably expect a nastygram from the city soon if I can't get them pretty quick. Or plan B scrap the idea and sell/return the kit and go with regular rubber stems and no tpms.
Old 11-09-2015, 02:12 PM   #7
NC Camper's Avatar
2018 27' Globetrotter
Greensboro , North Carolina
I may have missed something here, but if you took the valve stems when you took the tires and wheels to Discount tire, what happened to them? Maybe they should be the one's finding replacements.
NC Camper is offline   Reply With Quote
Old 11-10-2015, 07:17 AM   #8
1967 22' Safari
Pearland , Texas
Discount tire didn't use them because they were too small. I need to get larger diameter valve stems. I have the ones that came with the kit they just don't fit the 67 wheels. Sorry if I was confusing.
Old 11-10-2015, 09:35 AM   #9
2006 30' Classic
Milton , Florida
Dill TPMS Valve Stem Size
...The units included with the kit are the smaller diameter .4xx and the 15" steelies on my AS have larger .625 valve stem holes...
Dill makes the valve stems in both sizes. You are expected to specify the size that you require at the time that you place the order. Most of the time, Tire Rack will ask you which size you need. However, sometimes they forget.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 11-13-2015, 02:45 PM   #10
1967 22' Safari
Pearland , Texas
The only option I had was for 2 or 4 sensors...
Old 11-13-2015, 02:49 PM   #11
1967 22' Safari
Pearland , Texas
Do you have a name or an extention number? I'm going to throw in the towel on this system soon. 2 calls, 2 messages, 1 email, and no response. I even stated I wanted to buy the stupid things. I have also checked Napa, etc and purchased about $40 worth of valves that I need to return since they don't work. Great idea but I am not real thrilled with not being able to get parts or service. I am also sure that I can't return it to tire rack since it took forever to get wheels back from powder coating.
Old 11-13-2015, 03:18 PM   #12
I got prompt responses from e-mails and phone calls. I used "custserv@dillaircontrols.com" <custserv@dillaircontrols.com> for e-mail contact.
Al
S/OS #004
Old 11-13-2015, 04:54 PM   #13
GCinSC2's Avatar
From Dill website. Main Number: (919) 692‐2300. I don't remember a name, but it was pretty easy to get Tech Support.
S/OS #001
Old 11-14-2015, 05:21 AM   #14
1967 22' Safari
Pearland , Texas
Thanks. I doubt they are there today but I will call this rather than the 800 number I have. I did actually speak to one person but she didn't have a clue of what I was talking about. I was transferred to tech support where it rang several times and went to voice mail.
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Tire Pressure Monitor System (TPMS) curmugeon Sprinter and B-van Forum 58 12-29-2015 10:21 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Dill TPMS PJohnson Tires 20 05-15-2014 12:02 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
