11-11-2019, 09:33 AM
2002 30' Classic S/O
Melbourne Beach
Dill TPMS Sensors Failing (Batteries?)
One by one the sensors for my Dill TPMS are failing. At first they don't work until the tire warms up and then they don't work at all. They were installed nearly 5 years ago so I'm assuming the batteries are failing.
The choices seem to be:
1. Buy new sensors and have the tires (Michelins not yet aged out) dismounted and new sensors installed or,
2. Buy a TPMS like the TST or TireMinder and use that at least until the tires age out. At that point I can decide whether I want to install new Dill Sensors or just continue with the external sensors. The Dill sensors are metal stems so they should tolerate the external sensors with no problems.
I'm leaning toward replacing the system. The cost is about the same as the dismount/replace sensor option and if I do that I'll be faced with what to do when the tires age out.
Suggestions?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
11-11-2019, 10:15 AM
2012 25' FB International
Trent Woods
, North Carolina
Well, when I installed the TST external system, my thinking was that a) there are years of experience on the externals and they do not hurt anything if you have metal stems b) I will never have to remove a wheel and tire if there is a problem with the sensor or its battery.
I think your problem validates my decision. Proactively, I remove my sensors for winter storage and replace the batteries before installing in the Spring.
Larry
11-11-2019, 10:35 AM
Melbourne Beach
Thanks, Larry.
Al
S/OS #004
11-11-2019, 11:36 AM
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
Al,
Dill Air tel:1-800-815-3455 might want to check with Dill directly.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
11-11-2019, 12:03 PM
Melbourne Beach
Originally Posted by GCinSC2
Al,
Gary
Gary,
Thanks. The batteries have a stated life of 4-5 years. It has been that long. I have found the best price for the sensors, but by the time I buy the sensors, take the wheels off and transport them, or take the trailer to a tire shop, get tires dismounted and sensors changed, and remount the tires, the cost is comparable. Then in 2-3 years when the tires age out I have to buy new sensors, or just mount the new tires and do this all again in another 2-3 years.
I'm thinking changing the coin cell batteries on external sensors is a lot simpler.
Al
S/OS #004
11-12-2019, 10:38 AM
2007 23' Safari SE
ROSWELL
, Georgia
My coin cell battery type (TST) sensors are still working at 6yrs.
I change batteries yearly.
Mike & Nancy Gore WBCCI #2914 S E Camping Unit 012 Roswell,Ga.
11-12-2019, 10:40 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
I, like Isbrodsky, went through the same throught process (internal vis external). I too decided on TST TPMS flow thru with metal stems - works well, has alert if batteries need replacing
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
Blog Languages: English/French/Spanish
11-12-2019, 01:53 PM
Melbourne Beach
Ordered a TST507 Cap system. Should be here Thursday.
Al
S/OS #004
11-12-2019, 02:07 PM
Trent Woods
, North Carolina
Smart move
Larry
11-12-2019, 02:50 PM
BradT
2007 27' Safari FB SE
Milton
, Georgia
My thought would be to replace the Dill sensors. That way you still have the same system to deal with. I could never get the Minder system working properly and switched to the Dill to solve all that. Has worked great.
It would also be an opportunity to rotate and balance, so maybe not all wasted effort at the tire shop.
I've had mine 3 years, so I guess I will be replacing mine in a year or 2.
Good luck with what you decide.
11-12-2019, 03:56 PM
2017 25' International
1968 17' Caravel
Los Osos
I switched from Dill to TST. I renew the TST batteries every 12 to 18 months.
11-12-2019, 10:47 PM
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth
I have used PressurePro TPMS since '07 and still have not had to change any due to discharged batteries. Now, my dog loved to chew on them when she was a puppy and I replaced several for that reason, but not for the batteries. Guskmg
11-13-2019, 09:07 AM
1995 34' Limited
Sarasota
The customer service at TST is superb. Send my regards to Jim when you need the sensors set up.
11-27-2019, 03:54 PM
Anna Maria
Larry
I have the Eez tire externals going on 5 years all I ever needed to do is change a battery now an than. Reading your post I am going to make it an annual maintenance routine. The batteries are inexpensive.
Thanx for the tip.
11-27-2019, 05:03 PM
1968 17' Caravel
Los Osos
I threw my Dill system away and use a TST system with the new color display on both trailers. Batteries are much easier to change than with the Dill, and can be done on the fly instead of visiting a tire shop. I like the people at TST. They tend to serve the trailer community as well as truckers. Dill seemed to be more trucker oriented.
