09-07-2008, 10:13 AM
1965 26' Overlander
Edgewood
, New Mexico
Different sized tires front and rear
Originally Posted by CA Streamer
A lot of Airstreamers have switched to Maxxis tires. You don't need more than a D load Range...
Thanks for the info CA Streamer!
I have a couple questions. I'm looking at their website for 225 75 R15's for my '65 Overlander. They offer 8-ply and 10-ply for this, but don't indicate load rating. Here are my questions:
1.) Is the 8-ply equivalent to a D-rating and the 10-ply an E-rating?
2.) Can any 225-75-R15 D-rated automotive tires be used? I ask because walmart has a variety in that range.
3.) Finally, currently on my trailer, the rear tires are 225's and the front are 205's. Is this a normal thing, or a fluke? (the original owner towed her with a 4-cylinder Ford Ranger).
Thanks in advance!
09-07-2008, 12:48 PM
Corona
Thanks in advance!
1. Yes
2. Check your present tires, If they are load range "C", then you cannot change to "D". If you do, you will split every wheel. Once a wheel has been in service for an extended period of time, you cannot increase the tire load rating, since all wheel manufacturers will tell you that the wheels will split. You can down grade the tires, but you cannot upgrade on old wheels.
3. All trailer tires "must" be the same size, and at the same air pressure. If not then you place different loads on the axles that can cause handling problems, up to and including a sway.
4. Since you have a 65 trailer, you should consider replacing the wheels, if they are the originals. If you do that, then you can go to the "D" tires, if you wish. Never "E's".
Also because of different size tires, you are placing a greater load on one axle and a smaller load on the other axle. Again, that is asking for trouble.
Then if your axles are bad, and they probably are if they have not been replaced, you will moreso punish the trailer by having more weight on one axle than should be. All Airstream axles from 1974 and older, will fail, due to the wrong rubber rod composition.
Check your axles out to make sure that they are ok. The following article will teach you how.
http://www.inlandrv.com/articles/dur...xle-92001.html
09-07-2008, 02:20 PM
1965 26' Overlander
Edgewood
, New Mexico
Thank you Andy.
I just checked the tires. The rear ones Are Load Rating C. These are the 225's. The front say 1742-lb, which I assume is a Load Rating C as well. They are the 215's.
As far as load rating C, These unfortunately appear to be unavailable from Maxxis, however these can be had in automotive tires at WalMart--will these have the same lateral load capability as trailer tires? If not, does anyone have any recommendations on tires aside from the Goodyear Marathons?
Since there is no spare, I need to order at least one wheel--I notice you have them on special right now.
I'll check into the axles and your article.
Thanks again!
09-07-2008, 05:30 PM
1965 26' Overlander
Edgewood
, New Mexico
Andy,
One other question--should the axles be alright, how much for replacement drum assemblies? (It's raining here & the A-S is up on jacks with the wheels off the ground, so I haven't checked the axles)
-JP
09-07-2008, 06:12 PM
1984 31' Airstream310
Ajo
Andy,
-JP
Having owned four Airstream trailers + two mo/hos, I'd say go through the
entire suspension system..do it right once and for all.
09-07-2008, 10:26 PM
1965 26' Overlander
Edgewood
, New Mexico
The more I have been thinking about, and going through the other portions of the Airstream, the more I come to the same conclusion--Especially considering the condition of the other items.
That said, do you have any suggestions on shocks?
09-08-2008, 03:02 PM
Corona
You can get replacement shocks at NAPA stores.
09-09-2008, 08:22 AM
1965 26' Overlander
Edgewood
, New Mexico
I think I've got it taken care of. I went ahead and ordered a pair of new 3000-lb axle/brake assemblies as well as shocks and a Prodigy P3 controller for the brakes. It was a big dent to the wallet, but should provide a sound foundation for the trailer. I ordered some Goodyear marathons as well--and based on what I've read regarding tires, I'll make sure I get walmart's warantees on them!
09-09-2008, 09:16 AM
1963 28' Ambassador
Smiths Grove
, Kentucky
agPnut,
Which axle did you go with Dexter or Heschen? The Marathons you purchased at Walmart, are they trailer tires or just car tires?
63silver
09-09-2008, 09:23 AM
Corona
Originally Posted by 63Silver
agPnut,
63silver
You must not ever use auto tires on a tandem trailer.
The first or second tight turn you make, will typically damage the sidewalls.
Auto tires are not intended to take twists that occur when you make tight turns.
09-09-2008, 09:24 AM
Corona
agPnut,
63silver
He purchased 2 complete Henschen axles rated at 3200 pounds each.
09-09-2008, 09:30 AM
Princeton
, New Jersey
Would you please back up this statement with some documentation from a wheel or tire manufacture.
Yes there are limitations for tire widths to rim widths but I have never heard of a limitation for tire ratings on a given wheel.
2004 Excursion 4x4
09-09-2008, 09:42 AM
Corona
Unfortunately, I do not have the time, to provide documentation everytime someone asks for it. There are many owners out there that have tons of time to do that kind of research.
The wheel failure problem has been going on, that I know of, for over 40 years.
If someone doesn't believe me, that's certainly their choice to make, in what ever the subject maybe. My information, that I chose to share, is based on experience and/or facts. I don't have time to dream up stories, or to publish nonsense.
They will be the one inconvenienced, not me.
The last person that didn't want to listen to facts, but had his own opinion, bought 3 new wheels, between Corona California and Phoenix Arizona, because the wheels split, since he put "E" tires on old wheels that always had "C" tires, in spite of the fact, that "he was warned."
He called us and was apologetic, stating that he "should of listened to facts."
And so it is.
09-09-2008, 11:42 AM
Retired.
, At Large
I have had several wheels that could only use a C rated tire, because the wheel clearly states "maximum inflation 35 psi", or "maximum inflation 50psi" That is load range B and C respectively.
The older wheels such as found on 1960's and 1970's era trailers did not have this stamped on the wheel, making it a guessing game as to which you have. It is better to err on the side of caution, and only re-install what is currently on the wheels, or replace them with wheels that have the weight and pressure capacities stamped on them.
09-09-2008, 03:23 PM
1965 26' Overlander
Edgewood
, New Mexico
Andy,
Are you sure they were 3200#? I was considering getting these, but they were only available direct from Ohio. However, I was told that you all had a pair of 3000# in stock and ready to ship out today for less overall shipping cost. So I went for the 3000#'ers. Unfortunately I never received any confirmation summarizing the order (I was told when I ordered that one woudl be sent). Could you check on this?
Thanks for your help!
-JP
