02-27-2016, 05:50 PM
2007 27' Classic FB
Richfield/SLC
, Utah
Dents in side wall of tire
Will be replacing my four GYM tires on my AS soon, before the start of camping season. In looking over the trailer, starting to get ready for de-winterizing and season prep, I noticed two of the tires have abnormalities (indentations) in the sidewalk - see photos. I assume this can't be normal or good. I check the tires and TP regularly when in-use, but I wonder if I was somehow overlooking this last year.
I'll be getting a better set of replacement tires, given the obvious problems being reported with GYMs. I also will be looking much more closely in the future.
02-27-2016, 07:45 PM
2013 31' Classic
billings
, Montana
Them dents are normal, replaced my gyms with 16" michelins, gyms were 3.5 yrs old with 22000 miles.....
02-27-2016, 08:09 PM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Don't change your tires because of these indents. They are normal. Change them because they are GYM's and have a horrible history.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
02-27-2016, 08:23 PM
2007 27' Classic FB
Richfield/SLC
, Utah
I agree - the indentations prompted me to search on the AS Forum, and I found this thread. These tires have done enough miles / trips already, so I will upgrade to something more reputable. No reason to tempt fate...
02-28-2016, 11:07 AM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Dents are OK. Bulges are a sign of tread separation. I also got rid of my GYMs for Michelins.
guskmg
02-28-2016, 11:11 AM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I don't think those are normal. They make me think the belts/plys are separating.
I might travel with them on a utility trailer where a blow out wouldn't cause expensive damage, but I wouldn't travel with that on my Airstream.
Talis gentium ceciderunt.
02-28-2016, 11:25 AM
2012 25' Flying Cloud
Battle Lake
We replaced the GYM's with Michelin LTX M/S 16 three years ago but I remember uneven sidewalls where the belts overlap during construction. I don't recall they went into the tread though. If these are original, maybe eight year old GYM, probably a good reason to replace them anyway.
Doug and Cheryl
02-28-2016, 11:31 AM
1967 22' Safari
MILAN
NOT belt seperation !
These "dents' occur during the tire manufacturing process. The rolls of rubber that are used for each ply layer are fused together using a "Hot Knife" that fuses the ends of each layer to itself temporarily. Then when the tires are vulcanized they become permanently sealed and the treads are applied. I was a tire builder in my early 20's @ a Kelly/Springfield tire plant ! Ed
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
02-28-2016, 11:33 AM
1977 31' Sovereign
Lynnwood
What you've got is casing separation. This is a tire that's about to fail. Luckily, you just happened to catch it in time.
This is not unique to Goodyear. It occurs across the board, with all brands of tires.
This is why it's important to thoroughly inspect tires as part of your maintenance regimen.
Tom
02-28-2016, 12:42 PM
2005 22' Safari
Half Moon Bay
So which is it, normal or potential failure?
This thread underscores what I especially appreciate about this forum: a vast number of very well-informed and experienced people have a wide variety of opinions. Most are correct, a few are dead wrong, but seldom is anybody in doubt!
As for me, whenever practical, I wear a belt AND suspenders, and hope to always err on the side of safety. jsutro
02-28-2016, 01:05 PM
Lin
, Ne
Those indentations are normal, bulges are not.
02-28-2016, 01:06 PM
2004 28' International CCD
Cocoa
You have definitely gotten a lot of different views. Sorry. But one thing seems agreeable across the board is to get rid of those Goodyears now. I'm in the market myself and am looking at the "Maxxis"
Good luck
02-28-2016, 04:36 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
On the 2013 25FB International Serenity, I replaced the stock 15" GYM ST225/75R15D with 15" Michelin LTX (P) 235/75R15 XL tires on the stock wheels.
On the 2015 23D, we upgraded the stock 14" wheels and GYM ST215/75R14C tires with 15" SenDel T03-56545Tb wheels and 15" Michelin LTX (P) 235/75R15 XL tires.
On the 2014 Classic, we replaced the stock 15" wheels and 15" GYM ST225/75R15D tires with 16" SenDel t03-66655T wheels and 16" Michelin LT225/75R16/E LTX M/S2 tires (part number 05681). These are the same 16" tires and wheels now installed as stock on 2015 and later Classics. the Eddie Bauer models and for sale at the Jackson Center customer service center for 25' and longer trailers.
02-28-2016, 07:25 PM
2012 30' Flying Cloud
San Antonio
Good luck
You won't go wrong with the 15 inch Maxxis "E" rated ST tires. Many have gone the $$ route with 16 inch wheels and Mich MS 10 ply tires. The Maxxis carry the most weight and are strong sidewall ST tires designed for your trailer.
02-28-2016, 07:41 PM
2013 31' Classic
billings
, Montana
Why would any one change Chinese gyms to twainese maxxis??
02-28-2016, 07:59 PM
1969 29' Ambassador
brooksville
Good luck
I just bought a set of Maxxis, I'll post an update once i roll them down the road.
Not all those who wonder are lost.
02-28-2016, 08:16 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Because they are better.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
02-28-2016, 10:34 PM
1967 22' Safari
MILAN
Normal !!!!
The other posters who have added their replacement information is great but the bottom line question you have asked has two answers. 1) The "dents" you see on your sidewalls are Normal and do not pose a failure issue! And, 2) The Goodyear Marathon tires have a long history of not being a reliable tire product. The fact of where they were manufactured is that many of the failed Marathons were not made in this country! Hope this helps, Ed
02-29-2016, 05:30 AM
Sag Harbor
, New York
Originally Posted by Utah Man
I'll be getting a better set of replacement tires . . .
Excellent news!
